Question about Acer Aspire 3680 Laptop
Which key is the enter key - Acer Aspire 3680 Laptop
    Genius:
  • 1,542 Answers
Hi
Think its on the far middle right hand side downward faciing rectangle key just below the backspace key it normally has enter written on it
Posted on Mar 23, 2011
Sharp mx-m264n how to enter simulation mode
1. Entering the simulation mode
Perform the following procedure to enter the simulation mode.
"#" key "*" key "C" key "*" key
OR
"#" key "INTERRUPT" key "C" key "INTERRUPT"
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Sep 14, 2015 | Sharp Office Equipment & Supplies
Tip
Toshiba Laptop BIOS Password Removal
<span><b>ESC Key BIOS Password removing procedure</b><br />1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the Esc key. The computer will display the "Password = " prompt.<br />2. Enter the correct password, and press the Enter key. The computer will display "Valid password entered, system is now starting up. Check system. Then press (F1) key"<br />3. Press the F1 key. The BIOS setup program will appear.<br />4. Using the arrow keys or the tab key, move to the password field, and highlight REGISTERED.<br />5. Press the spacebar, enter the correct password, and press the Enter key. The Password field will change to NOT REGISTERED.<br /><b><br />F2 Key BIOS Password removing procedure</b><br />1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the F2 key. The unit will display the "Password = " prompt.<br />2. Enter the correct password, press the Enter key. (You may need to press the F2 key after you hit the enter key.)<br />3. The BIOS setup program will appear.<br />4. Using the arrow keys, move to the Security tab, and to Set User Password.<br />5. Press the F5 or the F6 key to navigate to the Password section. Enter the current password at the Old Password prompt, and press Enter. At the New Password prompt, press Enter (without typing anything into the password field). At the Confirm Password prompt, press Enter again (without typing anything into the password field). The password should now be removed.<br />6. Press F10 to save and exit from the BIOS Setup program.<br /><br />In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.<br /><br />If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.</span>
on Jun 09, 2011 | Computers & Internet
HOW REMOVE IT FROM THIS Defective power supply ERROR
Reset C6400 ERROR
turn the power switch off and open the front cover.
Then, turn the power switch on and press the system menu/counter key to enter the maintenance mode.
Select Service setting using
the up/down cursor keys.
While pressing the start key and the # key,
press the enter key..........Maintenance mode is entered.
Select Maintenance mode using
Press the enter key.
Enter the maintenance item
number U163 using the up/down keys.
Select Execute using the up/down cursor keys.
Press the enter key. The fusing problem data is initialized.
Apr 15, 2014 | Kyocera FS-1118MFP Laser Printer
On the display access cod
Enter in the User mode set menu screen 6/6,touch the Copy Track.Used to turn ON or OFF the copy track function per account.When ON is selected press the Enter key.Press the UP/DOWN key to acces the Account#to be administrated.Press the Acces#key and register the acces number corresponding to the above Account# from the 10-key pad(max.4digits)If the access number has been changed or the number entered is wrong,press the CLEAR key to clear the number and re-enter.Press the ENTER key to enter the access number.When the copy is to be made after the acces number has been entered,the access number must be entered and the access# key pressed to enter the copy mode.Factory initial setting to Copy track mode is OFF.
Jan 03, 2013 | Minolta EP4000/5000 CS/PRO Copier
Kyocera 1018 me sale error c6400
Zero-crossing signal problem
• The engine board (KP-5238) does not
detect the zero-crossing signal for the
time specified below.
At power-on: 3 s
Others: 5 s
Usually something wrong with electricity..
Try to clear this error:
Enter maintenance mode:
1. Press the system menu/counter key.
2. Select "Service setting" using
3. While pressing the start key and the # key,
4. Select "Maintenance mode" using
5. Press the enter key.
6. Enter the maintenance item
number using the up/down keys.
You need maintenance item 163
1. Press the enter key. A selection item appears.
2. Select "Execute" using the up/down cursor keys.
3. Press the enter key. The fixing problem data is initialized.
May 20, 2011 | Kyocera Mita LaserPrinter FS-1018MFP...
I just replaced all the moving parts in my Sharp AR-M620 copier including the finisher and drum etc...I have the service codes and sub codes to reset the print counters, drums, developers etc but don't...
* Entering the simulation mode
1) Copy mode key ON ? Program key ON ? Asterisk (*) key ON ?
CLEAR key ON ? Asterisk (*) key ON ? Ready for input of a main
code of simulation
2) Entering a main code with the 10-key ? START key ON
3) Entering a sub code with the 10-key ? START key ON
4) Select an item with the scroll key and the item key.
5) The machine enters the mode corresponding to the selected item.
Press START key or EXECUTE key to start the simulation opera-
tion.
To cancel the current simulation mode or to change the main code
and the sub code, press the user setup key.
* Canceling the simulation mode to return to the normal mode
1) Press CA key.
Sep 06, 2010 | Sharp AR-M620N Copier
Enter bios password
If you want to add the BIOS password:
  1. Restart the computer.
  2. At the SONY screen, press the F2 key.
  3. In the Setup Utility window, press the RIGHT ARROW to select Security .
  4. On the Security menu, press the DOWN ARROW key to select Set Machine Password .
  5. Press the ENTER key.
  6. At the prompt, in the Enter New Password field, enter the desired password.
  7. Press the ENTER key.
  8. In the Confirm New Password field, retype the same password.
  9. Press the ENTER key.
  10. At the Setup Notice prompt, press the ENTER key. NOTE: To set a user password, repeat steps 4-10, selecting the Set User Password option.
  11. Press the F10 key.
  12. In the Setup Configuration window, press the ENTER key.
  13. Press the RIGHT ARROW to select Exit .
  14. Press the DOWN ARROW key to select Exit Setup .
  15. At the Exit Setup prompt, press the ENTER key.
If you want to remove the forgotten BIOS password:
Please call 888-476-6972 and speak directly to a Sony® support representative for further assistance. A resolution for this issue is available, but for security purposes, this resolution can only be provided by a support representative.
Jun 12, 2010 | Sony VAIO VGN-N385E/W Notebook
I have the code but only says on screen that it is waiting? on my kenwood kdc 6090r
• Security-related information
1. Forced Power ON mode (All models)
Even when the security (Mask key) is approved, resetting
the unit while holding the ATT and Preset 4 keys makes it
possible to turn the power ON for 30 minutes. After 30
minutes have elapsed, it is not possible to return to the
previous condition unless the unit is reset again.
2. Method of registration of the security code after EEPROM
(Tuner Unit ***'y) replacement
(Code security model)
(1) Enter the test mode. (See " 1. How to enter the test
mode")
(2) Press the CLK key to enter the security registration
mode.
(3) Enter the code using the Preset 1/2/3/4 keys.
Example: To enter "3510"
• Press the Preset 1 key 4 times.
• Press the Preset 2 key 6 times.
• Press the Preset 3 key twice.
• Press the Preset 4 key once.
(4) Press and hold the DISP key for 3 seconds until
"APPROVED" is displayed.
(5) Exit from the test mode. (See " 2. How to exit from the
test mode")
(Note) All Clear is not applicable to the security code of
this model.
3. Simplified method of clearing the security code (K Type
only)
(1) While the code entry is requested, press and hold the
VOL UP key for 3 seconds while holding the DISP
key pressed. (This should turn "----" off.)
(2) Enter "KCAR" from the remote. (Same way as the 00
model)
Press the 5 key on the remote twice, then press the
Track Up key. (This enters "K".)
Press the 2 key on the remote 3 times, then press the
Track Up key. (This enters "C".)
Press the 2 key on the remote once, then press the
Track Up key. (This enters "A".)
Press the 7 key on the remote twice, then press the
Track Up key. (This enters "R".)
(3) The security code is cleared and the unit enters the
ALL OFF mode.
(4) If you commit a mistake in the code entry, the unit
enters the code request mode again.
4. Method of writing the Mask key while the EEPROM is in
the initial status
mode")
(2) Press the CLK key to enter the Mask key registration
mode. "TRANSMIT1" should be displayed now. The
display at this time should show " < > " in place of " [ ]
(3) Point the Mask key remote toward the light sensor,
and press and hold its key for more than 0.5 second.
(4) When "TRANSMIT2" is displayed, press and hold the
key on the Mask key remote for more than 0.5 second
again. The first and second counter codes are not
compared at this time.
(5) When "APPROVED" is displayed, the write operation
is complete. Now the demonstration mode is initiated
and the test mode is terminated.
(Note) In the same way as previous models, if 30 minutes
have elapsed with no code written, an error occurs
and the power is turned OFF.
5. Method of initializing the Mask key
(How to reset the unit from the Mask key approved condition
to the factory condition)
mode")
(2) "TRANSMIT1" is displayed and the Mask key entry
request mode is initiated.
The display at this time should show " ∗ ∗ " in place of
(3) Press and hold the key on the Master key remote for
more than 3 seconds.
key on the Master key remote for more than 3 seconds
again.
(5) When "APPROVED" is displayed, the Mask key is
cleared, the demonstration mode is initiated, the test
mode is terminated and the unit returns to the factory
condition.
6. Method of clearing all Mask key-related data
mode")
(3) Point the Master key remote toward the light sensor,
and press and hold its key for more than 3 seconds
(until the level display shows the full condition).
(4) When "TRANSMIT2" is displayed, hold the key on the
Mask key remote for more than 3 seconds again.
If "TRANSMIT1" is displayed in place of "TRANSMIT2",
restart the procedure from step (3).
(5) When "APPROVED" is displayed, all security data is
cleared and the unit returns to the condition before
Mask key writing with the EEPROM in the initial status
Apr 05, 2010 | Kenwood KDC-6090R
Copystar
Press the Printer key.
Use the up / down keys to find "Menu", then select with the Enter Key.
Use the up / down keys to find "Others", then select with the Enter Key.
Use the up / down keys to find "Printer Reset", then select with the Enter Key.
Use the up / down keys to find "OK", then select with the Enter Key.
Sep 25, 2008 | Copystar CS-1650 All-In-One Laser Printer
Acer Aspire 3680 Laptop Logo
100 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
