Question about HP LaserJet 3330 All-In-One Printer
I get the error message "Scanner Error - Power On/Power Off" but it when I do that it does not fix the problem. What should I do?
  • HP Master
  • 1,915 Answers
Either the scanner is dead or it is dirty. Cleaning the scanner requires some technical comfort as the machine needs to be disassembled somewhat and there is no guarantee that the fix I have will resolve your problem. Please post a comment if you are comfortable taking your machine apart and I will post details on how to perform a cleaning.
Posted on Mar 23, 2011
Epson 610 Workforce Printer Error; Light Bar won't reset
Sound like the scanner is the issue, is it under warranty? OR the Scanner may be locked, check for the scanner release device unlock it,.
Dec 17, 2012 | Epson Workforce 610 All-In-One InkJet...
"I get an error "Error in the back shading motor (4431) and the scanner stops. How can I fix it?
This error can be caused by a mechanical problem during the return of the shade. After many attempts, problem was fixed cutting both springs from pressure roll behind reading unit. The amount of spring removed changed from machine to machine. I cut 1 quarter of turn from spring and test the scanner. Procedure was repeated until problem was fixed. In worst scenario 2 turns were cutted. Be aware that cutting these springs will affect the scanned image quality.
Nov 22, 2011 | Canon DR-5010C Scanner
I am using a software package called Readsoft Forms. I create form definitions for different surveys using this software. when I change to a different form definition to scan I sometimes get an error...
Please try USB connectivity instead of SCSI. It is lot easier and unlike SCSI, there is no sequencing required. (With SCSI, you need to start the device before you start the Computer). You can switch on the scanner when you want!
S. Mohan, Chennai, india.
Jul 26, 2011 | Canon DR-9080C Path-Through Scanner
Scanner posts message "unable to
Don't give yourself grief. Don't argue with it.
Uninstall and reinstall printer prog
Download your complete version up-dated from www.hp.com
Mar 10, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
I am unable to scan with epson stylus SX105. It says, "cannot communicate with the scanner. Make sure the scanner is on, correctky setup and connected with no errors in the scanner. If using an...
Did you ever get a resolution to your problem? I have exactly the same problem with same error message - and very loud clicking noises coming from the scanner. Powering it down - allowing it to "cool" for 5 minutes will get probably 1 or 2 documents through the scanner before the error message reappears. But this is only a workaround rather than a solution.
Jan 22, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Printer will not print showing error 2200. How do l fix it?
This is a scanner error. You could try the following...
Power off and remove the power supply(Power Cord) from the back of the unit.
Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid.
Open the top cover
Using the carrier belt, move the cartridge carrier to the middle of the unit.
Remove both cartridges, close the top cover, reinsert the power supply, and power on.
IF THE ERROR MESSAGE DID NOT COME BACK....
Power off and remove the power supply from the back of the unit.
Open the top cover
INSERT THE COLOR CARTRIDGE ONLY,
Close the top cover, reinsert the power supply, and power on
IF THE ERROR MESSAGE RETURNS.. GET A DIFFERENT COLOR CARTRIDGE AND REPEAT THIS PROCESS....
IF THE ERROR MESSAGE IS GONE,
Power down as before, do all the same to get the carrier to the middle of the unit and RE-INSTALL THE BLACK CARTRIDGE.
Power back up as in previous steps...
NO ERROR? SHOULD BE GOOD TO GO..
ERROR?? TRY DIFFERENT BLACK
If after trying all of the above and the error message does not go away, you unit would need serviced (if it's under warranty, it's worth it; if not, you might want to replace it.)
Nov 15, 2010 | Lexmark P6250 All-In-One InkJet Photo...
Error message "Can not find camera.Please connect Omnivision SuperCam!" on my Vista laptop. Scanner works fine on my friend's XP desktop. Have tried all steps outlined in manual (several tim
On my Vista desktop it worked directly, but I had the same error message on my Vista laptop when the scanner was connected through an USB hub. Perhaps the power is not sufficient?
Then i plugged the connector directly into the laptop usb port 2.0, and the driver was automatically installed and works fine!
May 10, 2009 | Office Equipment & Supplies
Error 2200
Error 2200 is a scanner stall error.. there are a couple things for you to try to fix it:
Power off the AIO and remove the power supply from the back of the unit.
Open the top cover of the AIO.
Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
Close the top cover, reinsert the power supply, and power on the AIO.
Maggie B
Feb 12, 2008 | Lexmark P4350 All-In-One InkJet Printer
HP LaserJet 3330 All-In-One Printer Logo
27 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
