Question about HP Photosmart C5180 All-In-One InkJet Printer
Printer off line please help! - HP Photosmart C5180 All-In-One InkJet Printer
    Guru:
  • 78 Answers
Hi-
This problem usually is due to communication problem
Here's the step:
1. Click your start button
2. Go to Control Panel -> Printers
3. Right Click on your printer and uncheck OFFLINE.
IF the above steps did not work try these:
1. Disconnect your printer
2. Click Start
3. type RUN on Start Search (VISTA/W7) or Run (XP)
4. Type services.msc
5. Go to Print Spooler
6. Stop the service then Start the service again. Under Recover Tab - Select Subsequent Failure and toggle it to Restart the service.
7. Restart your computer and plug the cable back
Hope this helps
Good Luck!
Add a comment
Posted on Mar 23, 2011
Every time I print or receive a fax, it kicks me off of the internet.? PLEASE HELP!! Thank you :)
Try it:1..Telephone line straight away to system modem line in socket.. from modem line out socket to printer line in socket(marked as box symbol)dont insert tele phone line in phone symbol socket.. 2..Telephone line straight away to printer line in socket.. from extension socket(marked as phone symbol) to system modem line in socket...Note:dont split telephone line like branch.. Describe this issue with telephone operator because of both fax & internet will work in digital signals, result conflict may happen..
Jan 31, 2012 | HP Laserjet CM2320nf All-In-One Color...
Hi, i got my canon mx340 printer in february and was just looking for some help with faxing, i would like to fax a reciept, would you be able to help please?
should you have in your manual when you bought the printer utiizare (telephone line cord connects to the printer - line-connection and telephone handset to the other printer located somewhere in the back of the printer)
May 25, 2011 | Canon Office Equipment & Supplies
Our MFC 7840 printer when faxing keeps saying
Depending on your location the line coulod well be poor quality for a sensitive fax. Any spurious sounds on a fax line will cause it to fault.
May I suggest you try the fax on the mainline first before assuming the unit is at fault.
Length of line from point a to b can also reduce the efficiency of signal. It may sound ok to the ear, but resistance may be the factor in reducing the level of the tone that the fax requires to hear and then activate send or receive.It reports poor line condition and even poor memory because it keeps loading to send.
If it does it on the mainline as well then I would be considering a technical call for help. There may be a fault in the unit.
please rwte my help++++Thanks for using FIXYA
Nov 24, 2009 | Brother MFC 7840W Printer
Printed pages have white lines
Adjust the properties of your print mode the default is normal change it to best. the printing speed will change but the print quality will be good.
Apr 27, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Vertical lines through my text and photos
Either clean the print head nozzles or select a higher print quality and turn off High Speed mode.
Jan 04, 2009 | Epson Stylus Photo R300 InkJet Printer
Printer is offline the hole office they can't print can your please help guys please
Is there an Ethernet cable plugged directly into it or does it connect to a computer?
Does the printer show ON-LINE or OFF-LINE on the display?
Oct 14, 2008 | HP LaserJet 2100 Printer
PRINTER NOT WORKING PLEASE HELP!!!!!!
Uninstall and reinstall the printer driver
S. Mohan
Mar 07, 2008 | Computers & Internet
Blurred printing printer i255
Hi, check the nozzle and test , if the result not in solid color there are spaces within the color means need head cleaning after head cleaning twice test print .
Jan 23, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
HP Photosmart C5180 All-In-One InkJet Printer Logo
97 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
