Question about Alfred Karcher K255 Electric Pressure Washer
My pressure washer keeps tripping out after a short while in use.?
My Karcher MX720 pressure cleaner keeps tripping the mains power.
Jeff, the specs say it is 230 volt, 16 amp minimum, start up would be more, probably minimum 20 amp.or larger, check your manual. Are you using a small gage/ low capacity extension cord this could blow a breaker or may have an internal short have checked by a Karcher repair center. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Any idea why my new 13 amp pressure washer is tripping 15 amp circuit...
http://www.garagejournal.com/forum/showthread.php?t=203916
http://www.electriciansforums.co.uk/electrical-forum-general-electrical-forum/54098-problem-pressure-washer.html
Jun 17, 2016 | Karcher Garden
I own a stanley pressure washer and it keeps tripping out
The pump will cycle on/off but if it works properly when you pull the trigger and it keeps working then its working correctly.
Jul 20, 2014 | Stanley Air Tools & Compressors
Simoniz S2000 XE02 internal cct breaker keeps tripping after 30secs tried to get a parts break down but that info is really ****** and nothing on line anywhere. Any idea what causes the cct breaker to...
First be very careful because the unit is protected by a ground fault internal circuit interrupter and may trip if there is a short circuit to ground. Even a very small short circuit will trip the circuit breaker.
Something else: If you are plugging it into an already existing ground fault outlet then that may also cause one of the breakers to trip.
Like I first mentioned, if you don't know what your doing be very careful. Electricity and water are not friends, especially if the circuit breaker is tripping.
Good luck,
Marty
Jun 26, 2014 | Coleman Powermate DuraBuilt 1400 PSI...
Clarke power washers 150
Need more info:
What fuse? the one at the end of the cord on the pressure washer? Or the circuit breaker on your house?
If it is the one on the cord it may have gone bad. To test replace it with normal plug (non-GFI) and plug it into an outdoor or bathroom GFCI (GFI) outlet. If it still trips that outlet then there is a ground fault in the device which may be minor or major.
If it is a home circuit breaker remember that electric pressure washers use a lot of power - typically 1500 watts. If anything else is plugged in it can trip the house circuit breaker.
Jun 04, 2014 | Garden
When I pull the trigger on handle the breaker in the house trips.
if the breaker in the house does not trip with any other appliance connected to it ie another electric motor say a pool pump or electric motor from a circular saw and does not trip
then it sounds like your blaster has a electric phase to earth short circuit
it will be pulling a very large current
i suggest you take it to your local electrical repair shop to check this out
cheers pauly46
Apr 09, 2011 | Karcher K3.68MR Electric Pressure Washer
My Nobel dishwasher keeps tripping the circuit breaker. I think it is when the detergent door flips open it shorts the sytem? anybody know what I can do?
Something to try. Get a short HD extension cord and plug the washer in to a outlet just outside of the kitchen and see if a different breaker trips. Turn off and or unplug all small appliances when using washer. Could have a defective breaker. Good luck, best regards.
Feb 01, 2011 | Dishwashers
The wt714g keeps tripping the electrics off, have checked and cleaned filter but still doing it
if it keep triping the power supply at the mains box there is a serous short in the washer, get it looked at fast before it bites you, if the trip ever fales the washer will become the killer in your kitchen
Oct 18, 2009 | Washing Machines
Kicks off imediately ground faught on karcher pressure washer
This is a serious situation. It means there is a short circuit somewhere. You need to have a certified technician or electronics person look into it.
Aug 21, 2009 | Karcher 1750 psi Electric Pressure Washer
Dryer keeps tripping breaker. slight burning
The heating element is shorted. This is an electric dryer, right? replace the heating element. Make damn sure it's un-plugged when you work on it!
Jul 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The gfci on cord keeps tripping
GFCI's trip because theire is current leaking to ground. This often can be be caused simply by electrical components getting wet.
Or, it can be caused by a serious short to ground.
Fist, check to see if the inside circuits are getting wet from an internal leak. If so, fix leak, dry off components with a har dryer, try again.
If GFCI trips, it should be serviced by an experienced appliance repair person.
May 13, 2009 | Karcher K2.26 Electric Power Washer
Alfred Karcher K255 Electric Pressure Washer Logo
397 people viewed this question
Top Alfred Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you an Alfred Garden Expert? Answer questions, earn points and help others
