Question about Ricoh Corp Aficio SP 6330N Laser Printer PostScript Kit
How do I set a Ricoh SP 6330N to sense that I want to print 12x17 paper that is in the top tray and not use the 8x11 paper in the bottom tray. Thank you
    New Friend:
  • Ricoh Expert
  • 164 Answers
Do File print select printer. Then in printer preferences select paper tray.
Posted on Nov 21, 2014
2 Suggested Answers
  • 142 Answers
SOURCE: The Ricoh Alicio SP C410dn
You must first try to clean the paper feed roller which you will inside of the printer (bottom) when you pull out the paper tray. If this not works, then I am 100 % sure that the magnetic clutch which operates this feed roller must be replaced. I can tell you the part number for ricoh part catalog:
GX20-0014. If you don't have tech skills please don't do it by yourself because it's a hard and precision work. Call for help tech support
pifonski
Posted on Mar 02, 2011
How do I print envelopes on Ricoh Aficio SP C430 DN?
You will have to change the paper tray settings on ricoh to match the settings in your driver too. Also being a Ricoh you may have to create a custom size with in the driver to get it to work. What size are the envelopes?
Apr 18, 2016 | Ricoh Office Equipment & Supplies
Why is ricoh 6330n making a loud noise while it is printing?
Check the transfer roller (the sponge roller) there will be a gear on that roller. Lubricate is with some spray on lube.
Aug 11, 2014 | Ricoh SP 6330N AllInOne Laser Printer
BYPASS MISFEED, FEED FROM TRAY IS OK
the bypass tray does not have paper sensors, so when you print you need to specify the dimensions of the paper ion the print driver and in the machine system features-tray paper settings..
Jan 20, 2013 | Ricoh Corp Aficio SP 6330N Laser Printer...
Line through print
Perhaps did not specify paper thickness (check control panel and print driver).
Toner getting low.
Clean registration roller with clean damp cloth.
Aug 17, 2012 | Ricoh Aficio SP C811DN Laser Printer
A3 prints - printing on A4 - Ricoh C4500. When users print to our Ricoh C4500 using RPCS the print comes out as a cut off A4 print, so it does not seem to be detecting the fact that it is needing to use...
Enter on the computer the follow path:
1. enter start menu
2. enter printers and faxes
3. enter by right click into properties
4. enter paper size settings
5. set the paper size for the tray or trays and press update then apply and ok
after thet it will work
Also see on the printer menu enter the same paper tray settings and set the trays by size but more important is to set the compute settings
Jul 08, 2009 | Ricoh Aficio SP C410DN Laser Printer
Ricoh/Aficio SP C410DN Tray priority switches on its own
It is pulling paper from the tray specified within the application you are printing from or the driver. For example, from Microsoft word, you would have to go into page setup and select the tray you would like it to pull from. You will also want to check which tray it is pulling from in the driver, however the application generally overrides the driver settings. Both of which override anything you program at the machine.
Mar 12, 2009 | Ricoh Aficio SP C410DN Laser Printer
Ricoh AP3800C "Output tray full"
Check the little black piece of plastic that senses the printed page exiting the machine. Our sensor was stuck and I was getting the same message (an similar Ricoh product). When I gently reset the black piece to center, moving freely, printing worked again. I think the sensor got jammed up when we were trying to remove a bad paper misfeed.
Ricoh manuals very confusing on this error message. They refer to standard tray, tray one, etc. without being clear whether it's a paper feed tray or the so-called "standard OUTPUT tray." The output is not really a tray, it's just the depression where your sheet lands after printing. I wrenched on the paper feed trays and their settings for an hour before I figured out they meant OUTPUT.
Feb 27, 2009 | Ricoh Aficio AP3800C Laser Printer
Want to print on legal size paper from Tray 1 (top) as default
print menu - config and verify paper is being sensed correctly. If paper size in tray is not set correctly printer will ask where to print from
Feb 12, 2009 | Lexmark T640 Laser Printer
Problem with printing document footer text on RICOH SP C811DN
Check the paper size settings and orientation of the driver from the Control Panel, and that match to the paper size in the printer's trays.
Good luck and please rate me, thanks.
May 28, 2008 | Ricoh Aficio SP C811DN-DL Printer
Ricoh Corp Aficio SP 6330N Laser Printer PostScript Kit Logo
171 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
