Question about Sony PSPgo Black Console
My psp go battery ran dead I am assuming because it was about out of battery, and now it will not start again or charge. I have had this psp for about six months now, and it has little to no damage. ear pods were plugged in at the time of the incident.
    Master:
  • 525 Answers
Its still under warranty. Send it to sony and have it repaired.
Posted on Mar 23, 2011
Took car for a drive and had it up to 95 mi per hour and the car died. Battery was completely dead. Jumped it and it ran for about a block and died again. Replaced the batter and check alternator and both...
If the battery was completely dead, then you either have an immense power drain (unlikely) or your battery or alternator are faulty.
When you say you replaced the battery. Was that with a brand new one?
Assuming your battery is fine and fully charged, then the vehicle should start.
If the vehicle starts, then check your instrument cluster for a charge warning indicator.(typical red battery sign). If this is on, then your battery is not being charged.
You can also check with a multimeter across your battery terminals when switched off. You are looking for a voltage around 12.6 volts.
With the vehicle running, run the same test across the terminals. A healthy alternator should be charging at anywhere around 14Volts.
When running, if the battery voltage is constantly dropping, then you have a faulty charging circuit.
Oct 31, 2012 | Chevrolet Cars & Trucks
I was using my psp while it was charging and the charging light turned off, so i naturally assumed that it was fully charged. But a few minutes later the battery died and it wont charge when i plug it in....
Have you tried to remove the battery and put it back in and try to turn it on. Try removing the battery and putting the charger in and starting the PSP. If it starts, it might be the battery. If it doesn't, it's either the plugin for the charger or the PSP is just dead. If it does start with the charger, try putting the battery back in, if it charges awesome. If it doesn't the battery might be dead.
Sep 27, 2011 | Sony PlayStation Portable (PSP) Console
I HAVE A PSP 1002 (ORIGINAL MODEL). the problem is that i tried charging the battery with the wrong charger (i had temporary lost the proper psp charger) this seemed to work for a little while until one...
i do believe you have burnt out the inverter within the system :( i dont have an answer for you on how to persue a fix but i do wish you good luck .......keep in mind these are very cheap new nowadays so dont pay a big amount to fix it if possible ok :)
Jun 03, 2011 | Sony PlayStation Portable (PSP) Console
I was jumping someone else's car and I had the jumper cables on the battery and I try to start the car but it didn't start. The car went dead. Then I jumped it and the car ran fine but it will not...
If the terminal connections are good and tight and it has a good ground then it appears the battery would be at fault. To be sure, charge the battery with a charger on a low setting over night and test it again.
Sep 03, 2009 | Saab 9 5 Cars & Trucks
My PSP's not working. I haven't used it in 2-4 months. So I charged the PSP to about 1 bar of battery. Played on it till the battery ran out. Tried to charged it again but the light wouldn't light up and...
Have you tried removing the battery and run the PSP off the mains? If it works then, the battery may be faulty. You can get a new battery from most major retailers of games.
Aug 12, 2009 | Sony PlayStation Portable (PSP) Console
PSP CHARGING PROBLEMS
The way to properly break in a lithium Ion battery is to run it dead before you recharge it. Then fully recharge it and run it until it's dead again. Do this about 3-5 times and then the battery is properly broken in. If you charge it before it dies on a new battery you can build what they call a "memory" where the battery thinks it's fully charged however it's only maybe half charged and you will lose alot of life out of your battery. So make sure you properly break it in.
Feb 02, 2008 | Sony PlayStation Portable (PSP) Console
Psp worked fine until it ran out of charge. it will not charge. have tried other chargers.
Look for a new bigger battery on eBay, there are some very reasonably priced ones there. Rich www.everything4psp.com
Aug 07, 2007 | Sony PlayStation Portable (PSP) Console
Battery Or Charging Problem.
Have you updated your firmware recently? Check your PSP to make sure there aren't any loose connections. If you're comfortable with it, you could open it up and make sure the plug for the charger didn't come loose somewhere. It may just need a touch of solder to put it back into place.
Jul 06, 2007 | Sony PlayStation Portable (PSP) Console
Sony PSPgo  Black Console Logo
123 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
