Question about Brother Office Equipment & Supplies
TerI've replaced the drum and laser cartride, but I'm still getting about 1/2 of the page printed. The entire right side is still blank. What should I do?
  • 52 Answers
Clean the laser scanner glass
Posted on Mar 24, 2011
Brother MFC-6800 1. Prints with 3/8" blank vertical line down the entire page; 2. Prints with a couple of 1/16" blank vertical lines down the entire page; 3. Prints with some gray shadow...
This solution is unconventional but it worked for me. The black roller on my MFC had irregularities on it and was creating horrible printouts. I pulled out the drum and cartridge and cleaned the large black roller. I used furniture polish to make the roller very smooth. Now it prints really nice.
Nov 29, 2010 | Brother MFC 6800 All-In-One Laser Printer
Toner is printing on right hand side of each page printed
Most likely it is the drum cartridge. The other causes such as toner on the laser optics would not produce an on again off again print area. It would be blank the entire way down the page. Since the toner prints in patches down the right side it means it is coming from something that is "rotating" and that narrows it down to the drum.
Good Luck and Thank You for using Fixya.
Mar 31, 2010 | Dell 1700 Laser Printer
Dell 3100cn printer leaves a blank strip
The following table should help
Contamination in the laser path - 1. Clean the laser path. (Remove the laser/scanner assembly and clean the lens.) 2. Replace the laser/scanner assembly
Defective fuser - Replace the fuser assembly.
Lack of toner or faulty toner cartridge - Redistribute the toner in the toner cartridge. If the problem continues, replace the toner cartridge.
Dirty Corona Wire - Clean the Corona Wire.
Defective Drum - Mostly applies to B&W printers. Clean the drum or replace the drum.
Sep 20, 2009 | Dell 3100cn Laser Printer
Printing blank pages
Hey,
Try installing the toner/pc drum once more, then print something and when printing open first cover and take out pc drum, look the pc drum, if the pc drum is clean, then the laser wount reach it. laser is located above the pc drum. when you close front cover then there is a little swich in right side what opens laser cover, try to makse sure that it works.
if there is a print marks in pc drum, hten the problem is in transfer rollerits located behind the pcdrum.
Oct 05, 2008 | Konica Minolta PagePro 1350W Laser Printer
Black line on right side of prints
the drum life is over, change PC drum, also you may clean laser glass whats under the pc drum
Jun 06, 2008 | Konica Minolta magicolor 2400 Laser...
Streaks on left side
REPLACE DRUM CARTRIDGE THE CLEANER BLADE IS BAD
Jan 20, 2008 | Dell 3100cn Laser Printer
Print with vertical print gap on entire page
There are a couple of issues here.
1 You may, unlikely but may have a bad drum cartridge.
First thing to try though, is to print out a report.
Billing meter report, system settings, any report and see if the defect it still there on a print.
If it is, then you have either a drum or laser issue.
If it is not on the printed report, the problem is in the scanner. Most likely just a dirty mirror.
If it occurs on the printed reports, remove the toner and look into the left hand area of the machine. There is a slot about 6 inches wide and about 5/16th in height, see if there is anything in that path. That is the laser opening. If there is an obstruction there, then remove it. Take a cloth or q tip and clean that slot.
the laser itself may be dirty.
But here once again.
If you run a report and the defect IS on the image. You have a drum or laser problem,
If you run a report and the defect IS NOT on the page, then you have a scanner issue.
Jan 10, 2008 | Sharp AL 1631 Copier
Consistent, faded and streaking vertical lines across entire page, from top to bottom.
Toner issue getting to drum - use gen toner cart.
or Drum blade stuffed (lines are down page fro top to bottom- replace drum assy
Drum has been exposed to light faint or blank across copies repeated 4 times down page - replace drum assy
or upper fuser roller stuffed, down page, smudgy print -  replace fuser
LSU(laser) or boards rarely cause issues
Oct 25, 2007 | Samsung ML 2010 Laser Printer
13 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
