Question about Briggs & Stratton Garden
Hi, I am having a surging problem on a b&s 407677 ohv engine when it gets hot.
    President:
  • Briggs & Str... Master
  • 1,545 Answers
The simplest solution is to purchase some good fuel system cleaner. I recommend Chem-Tool's Berryman B-12 (found at auto parts stores). Add about double the suggested rate to your fuel and use it. Double is about 2 ounces/gallon. Strong solvents in the solution will help clean the carburetor without disassembly and may cure the surging problem.
Posted on Mar 23, 2011
Briggs and stratton 21 hp model# 407677 type#0258 governor is stuck wide open. I bought the motor used . I disconnected the lever off the governor shaft and can manually lower the engine speed. Also the...
The governor shaft must turn freely. You will probably have to remove the shaft and clean it and the bushes it runs on with some wet & dry emery cloth and lube it. You could try some CRC penetrating oil on the shaft position it so the oil runs down the shaft and keep spraying & working it but that may not work.
Aug 22, 2014 | Measuring Tools & Sensors
Engine surgings after running 1hr
You're on the right track its definitely fuel starvation. Try cleaning the fuel tank breather (it's probably in the tank filler cap). This allows air in to the tank as the fuel is used, if it's blocked you get a partial vacuum in the tank and the fuel wont come out.
Jan 02, 2014 | Poulan Snowblower 205cc 8.0 TP Briggs OHV...
Engine is surging and then stalls
You may have air coming in around some gasket on the carb.
Jan 01, 2014 | Mtd Gold 31AH65LG704 357CC OHV 4 Cycle 28"...
My Kohler lawnmower engine is surging and then shutting off. Is this a choke problem?
Hi, the carby needs to be stripped down and all jets cleaned out, regards Phil.
Jun 13, 2012 | Yard Man YardMan 11A41K3001 21Inch 173cc...
I have a craftsman gt 5000 with a briggs 22 hp ohv els725 engine. the engine starts hard, then seems to act like its going to die, then i can partially choke it and it seems fine. then when its put under...
indicates that there is a blockage in the main jet
or a restriction to the fuel flow
or a low float setting
the run on effect ( dieseling) is from hot spots in the cylinders igniting the mixture that is coming in through the idle circuit when the throttle is closed and the ignition turned off
you can have the valve clearances checked ( .010"hot inlet and .012" exhaust hot ) but as it runs ok- no missing or backfiring etc- it will not be a valve problem
Jun 25, 2017 | Garden
How do you adjust the valves on the v twin model 407677
remove the valve covers and pull the spark plugs. so you can find the compression stroke. when you fill air coming out of the head. make the piston come all the way to top. watch rocker arms so that they the same hieght. use a filler gauge ( .005 ) put betwen the rocker arm and the valve. tighten rocker arms to the gauge. make sure you cheek again after tighting the rocker nuts
Jun 18, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Straton 20 HP, two cilinder engine idle speed
Surging is usually caused by a lean condition You can try to turn the mixture screw ccw about 1/4 to 1/2 turn. If this does not solve the problem your carb will have to be removed, cleaned thoroughly, and reinstalled.
May 17, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and stratton platinum 5.5 hp ohv i/c engine
The carby probably has a block either in the idle, jet or float valve. These are both internal to the carby. To fix this, you will need to pull the carby off the engine and get it serviced by a tradesman. If you feel keen, split the carby apart, then run a very small drill bit (.38-.7mm) through the Jets by hand. Also spray carby cleaner in there and blow out with air blower.
Mar 14, 2010 | Mtd Troy-Bilt Bronco OHV Tiller
Briggs & Stratton 18 hp v-twin engine surges while running.
I put a new carburator kit in a Briggs & Stratton 18 HP Twin. But did not replaced the needle nor the new seat that came with kit, because I did not know how to remove it and did not to damage it. now the gas over flows
Jul 12, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
185 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
