Question about Vacuums
Shark iron; when you turn it over to iron, water pours out. iron gets hot, but water leaks out
    Genius:
  • 1,157 Answers
Hi Sicnoramoore,
If your having problem with your shark iron and it leaks drops of water while ironing, it might be the water holding tank has a crack. Here are some steps that you may apply to check what's causing the leak issue.
1. Check the water. If you put wrong water it will cause the iron to spit the water out. So try to use good spring water or bottled water. Also make sure that the iron is empty before storage.
2. Check the two front screws ( they are hidden ). The two screws are holding the tank to the base. Sometimes iron developed a crack caused by tightening the screws.
--> if the unit has crack, I will recommend to call the manufacturer if warranty is up to have it be repaired for free.
Hope it helps.
Thank you for using FixYa.
Posted on Mar 23, 2011
Tip
My Shark is leaking water and not passing steam to the heaad. I've also...
I saw a post about no steam coming out of the head of a Shark Steam Mop. So I had to go and checkout my wife's shark....
Here is what I found and how you can check it out and fix it
If you pull the attachment off and look inside you will see that there is a small hole that the steam travels through into the flexible hose with the spring around it and then on to the head and out the smaller holes...
Now if the first hole gets plugged then no steam will get through to the head...however if there is something stuck in the hose or the smaller holes in the head are plugged it still could act the same...also check that the hose has not come off... there have been cases of the hose coming loose then the steam will not get to the head....you may have to remove the head to actually see that it is not connected properly.
So, first look right inside and check that out, then if that is okay, take out the four screws that hold the swivel joint into the head...then you can take out the last two screws holding the swivel joint to the head...
This will allow you to blow back through the hose to make sure it is not obstructed or to blow the dirt back out... a small wire or pipe cleaners will also work well.
If that is open the take a tooth pick or some small like that and open the holes in the head....blow through the head to make sure that they are open, try to make sure all of the holes are evenly opened so that you get good distribution of the steam to the whole head.
Then replace everything back like it came apart...make sure that you replace the two screws first then drop the swivel into the slots and replace the four screws.
Reinstall the head onto the mop and give it a minute or so to heat up after plugging it in.
Now the steam should be going out the head like it was intended...
If you still do not have any steam from the mop then the heating element has probably has gone bad. As far as I can tell there are no heating parts available for these. You will have to junk your mop and buy a new one.
The mop does have a 1 year warranty and details of that are on the link I have below for the manuals.
All of the Shark Manuals and much more, can be found by clicking on the highlighted text
heatman101
Check out these other related tips...
http://www.fixya.com/support/r6740629-shark_steam_pocket_mop_cleaning_problems
http://www.fixya.com/support/r6896271-find_shark_parts_accessories
on Jul 30, 2011 | Vacuums
How do I clean my iron?
I am assuming that you have scale or lime build up on your iron. Make a solution of half white vinegar and half distilled water. Pour it in the water container on your iron. Turn your iron on its highest setting and set for steam. Wait about 15 minutes and turn off the iron. When water cools pour off the remaining water/vinegar solution. Fill the iron with distilled water and turn on. Let it heat and then cool then pour off that solution. Do this till the poured off water runs clear. If you have scale on the bottom of the iron you can clean that with an old toothbrush dipped into warm white vinegar. There may be easier ways to do this but this is eco friendly and it works the best of anything I have tried.
Apr 08, 2011 | Vacuums
Shark steam mop will not syeam grey pruple shark steam mop
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Nov 04, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Makes steam. Leaks where pad goes into pad attachment. Pad doesn't get hot steam...just water but the pad doesn't really get wet but the floor does.
heatman101
Oct 10, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Steam does not come out when we pump the handle.Water just pours out from the bottom. Water does heat, but steam does not release.
heatman101
vn
Sep 13, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Has stopped steaming. Water gets hot but nothing coming out. model S3101 Shark I have tried pumping the handle as I mop but no steam even though water is very hot.
heatman101
Sep 01, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My Europro shark steam mop won't steam, light on but no steam.
Hard water deposits. I ran some white vinegar through mine, like a coffee maker, and it worked for a while, but clogged again. So I unplugged it, let it cool and turned it over in the bathtub and squirted a small amount of Lime-Away into the hole where the steam comes out. Let it soak for 5- 10 minutes and it is working like is is brand new.
Sep 15, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Can't get it open
had same problem. Tried pouring boiling water over cap and it seemed to loosen some so I boiled more water and put the steamer top down in a bowl in the kitchen sink and pour the boiling water in and let it sit about 5 minutes. It came loose with some effort. The grooves are the opening are metal and they had started to corrode.Once open coat with wd40.
Jan 31, 2009 | Kenmore Euro-Pro Ultra Steam Shark II Hard...
Vacuums Logo
62 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
