I have a indesit washer dryer. works fine except its just started to make a weird sound when water drains out. It sounds like broken metal nin drum. washes and spins ok. just makes sound when pumping out water
    Brigadier General:
  • 6,277 Answers
(try these instructions!)
Sorry but I do not know your particular machine BUT I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 23, 2011
We have an Indesit washer dryer WDG1295. When switching on, it fills with water, hums away as though it is working (including draining) but the drum doesn't turn. The belt looks fine, and if you move the...
Immediate thought was the belt but you already checked that. Reading your message, you seem to be indicating the washer goes through the wash cycle and does everything except turn the drum, i.e. it fills and drains and the timer control knob advances as you would expect. This machine has an electro-mechanical timer rather than electronic, so if it advances through the program correctly, I would exclude this from my initial checks, but I'd still come back to it later.
Washing machines aren't that complicated, so if all of the above is true, the obvious assumption would be the drive motor. You've obviously opened up the machine to check the belt, so have you tested the motor with an ohm / multi-meter?
Please confirm the correct operation of the timer and whether you have tested the motor and I will try to assist you further. I check messages regularly, so if you post back here I should reply fairly quickly. Make sure you reply from within this page - don't post a new help request!
Regards,
BElectric
Nov 27, 2010 | Indesit Washing Machines
The drum is very noisey and is leaking grease on items.
hello sorry to say that it sound like the bearing have gone you can do quick test open the door grab hold of the drum pull up and down if this moves freely then the bearing have gone
regards
shaun
May 28, 2010 | Washing Machines
Indesit washer dryer starts cycle, waters then
If the heater element is not working, then the cycle will not progress.
You need to test the element to see if it is o/k.
Hope this helps.
Jan 05, 2010 | Indesit Washing Machines
Dryer will not start, just humms
sounds like the drum belt maybe broken or worn out.
May 25, 2009 | Kenmore 98702 Stacked Washer/Dryer
Indesit wd125 drum wont turn
check your pump it may not be working
Dec 18, 2008 | Indesit W 123 Front Load Washer
Indesit washer dryer 'omega 1200' WDG1295W won't drain!
Sounds like the pump is possibly faulty, or there is a blockage
There should be a removable plastic cover at the bottom front of the m/c, behind this you will see a round plastic cover.
This is the pump filter, unscreit and unblock it if it is full of ****!!!
Hopefully this should solve your problem.
Please leave feedback.
Dec 02, 2008 | Indesit W 123 Front Load Washer
My Indeset widl102 washer dryer
sounds like a faulty water valve if not pcb or pressure switch sorry cannot be more precise but thats indesit for you regards jason
Jun 12, 2008 | Indesit W 123 Front Load Washer
Indesit Washer/Dryer WD125 wont take conditioner
sounds as tho may not be draining. have you checked the filter? also check for foreign objects in the pump impellor
Apr 27, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
