Question about Kitchen Ranges
I have a DV209AEW/XAA Samsung front loader dryer. It stopped heating. Will not heat on manual or senor dry but runs fine other than no heat. I tested the thermistor and thermostat on the heating assemble as well as the heater and exausht theristors. None were found bad. I ordered another PCB main and installed it; now the front panel gives odd characters and won't function properly or start the dryer. Maybe I have the wrong PCB? Maybe I should also replace front panel? Please help. Pictures of this part are hard to find. The old one has same model and reference numbers on it and looks identical to the PCB I ordered with one exception. The new one has a diff. number on the chip. I think this is actually the part number I should look for, but when I search for this part I get TV PCB as well and no picture for the one that is for dryer to confirm. Please clarify as to the function of the PCB and front panel and what may cause these problems..
  • 3 Answers
SOURCE: Maytag Gemini Electric Kitchen Range
maytag double oven model # mer6770acw code f1-1 and
f 1-3 appears on the panel when using the ovens ofcourse when it gets warm or hot the ovens stop working .thanks for help
Posted on Sep 09, 2008
  • 1214 Answers
SOURCE: replacing a dual burner control switch
First, have you removed the wires from the old switch?
If not, then look on the switch, old or new, and see if there are numbers on the terminals. If so, just move the wires one at a time, terminal number to terminal number.
If you have removed the wires, then you will need to find the wiring diagram, which is most likely found somewhere inside the unit or on the back panel. You should be able to identify the correct wire connection from the wiring diagram.
If you can reply the full model number, I might can find a wiring diagram for it and give you more direction.
Posted on Jan 22, 2009
ginko
  • 19396 Answers
SOURCE: cda electric cooker ,fan,
Test heating element continuity using a multimeter, then test temp probe, if there is nothing in ther , then test wiring harness to control panel and timer control board.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Posted on May 04, 2009
  • 208 Answers
SOURCE: my front loader dryer stopped heating,
have a electrician inspect the circuit going to the dryer as it might not be providing proper current to operate the dryer
Posted on Jun 22, 2009
  • 15 Answers
SOURCE: need part number for lower heating element in a JBP26 oven
That doesn't appear to be a complete serial number. You can go to repairclinic.com and click on repair help, or go straight to this page: http://www.repairclinic.com/0089.asp?apptype=13
to find the correct serial number.
Posted on Jul 20, 2009
Dryer heats for maybe 1 minute then stops. Samsung Model DV328AGW/XAA
In the rear of the dryer is a thermal limiter which will kick in when the exhaust temp is too high and can cause a fire. One link will show what the limiter looks like and the other will show how to commonly get to the limiter. Your mileage may vary.
Samsung Dryer Model DV328AGW XAA Fuse Thermal Fuse Breaker Parts Take Apart Samsung Dryer Samsung Dryer Repair Help
Jul 30, 2014 | Dryers
My Samsung DV5451AEW/XAA will not dry cloths. The vent tube is not plugged and air flow is great through the whole vent system. How do I get to the heating element?
  • I am assuming this is electric. Yes?
  • Do you get any heat when there is no clothes in it?
  • Have you checked your voltage at the receptacle? If not 220V, if you have the old tube fuses, then one may be blown. If you are getting good heat with no clothes then replace your high limit thermostat. Lots to check before heading for the heating element. As for heating element they are usually either in the back of the tub or a tube on the right hand side of the dryer. You need to take the front panel off.
Aug 03, 2013 | Samsung White Dryer Dv5451aew/xaa
Dv209aew/xaa where is heating element
Under the drum on the right hand side. To get to it you will need to remove the top panel. UNPLUG it. take out the 4 screws that hold the control panel in place. Take out the three screws that hold the Main control board( on the lefthand side). Unhook the control board connectors from the main control board. Remove the control panel. Take off the 2 bottom screws inside the door, take off the 4 screws that hold the front cover plate. Take off front the front cover. Take off the 5 screws that hols the drum plate. Remove it. Remove the belt, and the metal bracket on top. Take out the drum and you will be able to access the element.
Jan 30, 2011 | Samsung DV218AEW Electric Dryer
I have samsung front loader model #DV328AER/XAA quit heating could it be the heating element or a switch
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 20, 2010 | Samsung Dryers
Samsung DV337AEW/XAA wont turn off by timer. we
The timer has gone out rplaceit and all should be fine
Oct 27, 2009 | Samsung DV337 Electric Dryer
My front loader dryer stopped heating,
Jun 22, 2009 | Maytag MDE9206 Dryer
Kitchen Ranges Logo
123 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
