Hello, in order to remove the coil it will require some work, you need to cut into the plenum first then either pump down the refrigerant into the condenser or recover the refrigerant. Then cut the line set close to the coil to remove the coil. If you are familiar with hvac work then it is pretty simple, however if you are not to familiar with it I would call a hvac to do the work.
