Question about Cooktops
My Defy Gemini glasstop back plate does not regulate, After switching it on, the plate stays red hot.
2 Suggested Answers
  • 52500 Answers
SOURCE: I have a Defy Gemini 900 hob solid plates. When it is turned off the plates get red hot and I have to put it off at the mains. Can this be fixed and how?
no doubt it can , by a factory service repairman
Posted on Nov 11, 2015
Whirlpool schott ceran induction plate doesn't get hot
magnetic gradeI have a SCHOTT Ceran glass ceramic cooktop as well, and soon realized that induction cooktops like this require that your metal cookware be in contact with the surface for them to heat up. Best cookware:
  • Cast iron pans
  • Any black metal pans
  • Stainless steel pans, if base is magnetic grade (magnet sticks to bottom)
Read more: http://www.us.schott.com/hometech/english/products/ceran/dailyuse/index.html
Jul 15, 2012 | Whirlpool 30-inch Electric Ceramic Glass...
Hot plates not heating up
Hi kennycrocket,
You might be looking at dead plates or faulty regulators. I'd suggest lifting the cooktop of, and turning it over. Then very carefully, while still on at the main, testing at the power points with a multimeter.
First test incoming power to the regulators (The devices found under the knobs), then testing power to the plates. If power gets to the regulators, but not to the plates - The faulty part is the regulators. If however power goes to the regulator as well as the plates, then the plates are faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Aug 08, 2011 | Belling 23 in. SHU53 Electric Cooktop
Kenmore "Hot Surface" light
hot surface light is turned on by a auxiliary switch across the plate. it is possible that the switch has stuck in the closed position. it is also possible that the plate is not turning off. feel the plate and check if it is at all warm. if not, then the auxialuary switch is stuck closed. not dangerous. to fix means replacing the limiter which is the rod you can see across the plate. sometimes you can only get the complete plate with limiter which is a bit pricey
Jun 26, 2008 | Kenmore 30 in. 42701 / 42702 / 42709...
Burner gets hot even when not turned on
sound like you have a shorted element, it will stay hot but not high heat hot (glowing) red, other posibility is bad infinate control switch that switch could be bad
Apr 13, 2008 | Cooktops
Cooktop light stays on when cool
the "hot top" indicator lamp is switched by a contact on the plate cut-out. sometimes this cut-out is available as a separate part but often must fit complete plate. by plate i mean the bit that gets hot!
Mar 28, 2007 | Kenmore 30 in. 42701 / 42702 / 42709...
Cooktops Logo
Top Cooktops Experts
Marvin
Marvin
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
