Question about Toshiba RD-XS32 DVD Recorder
Every time I try to use the remote on my Toshiba RD-XS32SU Video Recorder I get the following code displayed on the unit: DR-OFF I do not know what it means and how to resolve the problem.
  • Toshiba Master
  • 508 Answers
It is confusing to many people this function, but not impossible to investigate (perhaps experiment with some of the functions). You can get a copy of the INSTALLATION GUIDE (if you don't have a copy for any reason) from the following:
http://tacpservice.toshiba.com/consumerproductsupport/Manuals/dvr/RD-XS32SU_Inst_E.pdf
and if you don't have a copy of the original OWNER'S MANUAL, you can also download that from the following:
http://tacpservice.toshiba.com/consumerproductsupport/Manuals/dvr/rd-xs32_om_e.pdf
(copy and paste into your browser if required - these are both FREE documents)
(Page 48 of the installation guide (not the owner's manual) tells you about IR CODE setup option using remote - read that first if you like, then try your recorder).
Hopefully this helps you a tiny bit.
Posted on Mar 24, 2011
Front Display is saying DR-2 and will not let me use remote to control anything...only thing I can do is shut power off with front panel..I have unplug from outlet and let set for 30mins and plugged back...
I received an attachement from the Toshiba Repair folks several months ago, when we had the same problem. To resolve it, do the following:
While pressing the Easy Navi button on the remote, press 2. The remote control mode will be set to DR 2, which is what the recorder is telling you it is set to.
We encountered this problem for the first time, for no apparent reason. It happened again today, after the operator dropped the remote. This fix worked both times.
Nov 07, 2010 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Toshiba RD-85DTSB recorder remote control wont work, getting DR-Off when pressing any buttons?????
Press the HDD and DVD bottons on the player at the same time it will then show DR2 when remote is pressed. Press mode key and the number 2 key on remote, this should now work
Oct 01, 2010 | Toshiba RD-XS34 DVD Player/HDD Recorder
Don't know how to set channels w/new cable box.
Use channel 3 or 4 or hook up the RCA jacks. If you use 3 or 4 leave it on that channel and use the cable box to change channel. Use RCA jacks (best) turn the channel on the recorder to line in ether LINE1 or LINE2 with one you plug it up to and leave it on that channel.
Jul 23, 2009 | Toshiba RD-XS32 DVD Recorder
A/V Signal Outout through Onkyo TX-SR705
Are you trying to record cable programming with your DVD recorder? If so, you might want to try using component cable as HDMI does have a copy protection circuit that might be preventing your recorder from receiving the image. Just try to connect the cable box component (RED/GREEN/BLUE) cable to your DVD recorder. If that doesn't work, then try to change everything over to component cables. HDMI is a great cable to use but it the only required to display 1080p images and the only current source that uses 1080p is a bluray player. Everything else, such as your cable box and DVD recorder is 1080i and component cables are perfect for it.
Mar 14, 2009 | Toshiba RD-XS32 DVD Recorder
Toshiba Hdd/Dvd video recorder. Moved unit to a static caravan,comes on ok but when using the remote to use it ,no matter what button I press I get the message 1. DR-OFF Can you please help ? I have the...
Got the same problem today. I found the solution online on the installation guide. You need to push the two channel changing buttons on the recorder at the same time for 3 seconds.
Jan 11, 2009 | Toshiba RD-XS32 DVD Recorder
Toshiba RD 85-DT dr-2 error code
Hold the easy nav button and the number 2 down for a few seconds then try using the remote.Hope this works for you too.
Nov 28, 2008 | Toshiba D-R2 DVD Recorder
Toshiba RD 85DT DVD recorder
ok you need to press STAR Button which says mode above it and either 1,2 or 3 to find which freqency is being use. The dvd and the remote need to be on the smae on.
Oct 18, 2008 | Toshiba RD-XS52 DVD Recorder
Hold both the channel up and down buttons on the front of the recorder for 3 secs until DR1 shows in the display. Try it and let me know if it worked..
Apr 16, 2008 | Televison & Video
Toshiba RD-XS34
Hold down the easy-navi button and number 1 on the remote.
Sep 13, 2007 | Toshiba RD-XS34 DVD Player/HDD Recorder
Remote control problems
Answering my own question,Switch on recorder manually then hold down SETUP KEY and No 2 key at the same time.As this is a common fault with this recorder would advise taking note of this solution.
Oct 21, 2006 | Toshiba RD-XS34 DVD Player/HDD Recorder
Toshiba RD-XS32 DVD Recorder Logo
193 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
