Question about Vacuums
The dyson handheld cuts out almost immediately after pulling trigger, Some times runs a little longer before it stops. Keeps doing this constantly. What is problem? Thanks G
  • 34 Answers
Depending on the model you have:
Thermal cut out Most Dyson vacuums have a built in safety system that stops the machine if it begins to overheat. This usually happens because the filter needs washing or your machine is blocked. If your machine turns off on its own, unplug it and leave it for at least an hour to cool down. Remember to check the filter and look for blockages before re-starting
If that doesn't work shake your cord and see if there is a short in it.
Posted on Mar 23, 2011
When I press the trigger the green light comes on but motor does not
Hi Perry, it's Jack at Dyson.
If the green light comes on when your DC35's trigger is pulled, but the machine does not run, this would usually signal that the battery has no charge.
The battery should recharge fully from depleted in 3.5 hours. However if your machine has been connected to the charger for at least this long and still won't run, it could mean there's an issue with either the charger or the battery.
We're happy to talk you through some simple diagnostic checks when you have your machine to hand, to help determine which part is at fault. At your earliest opportunity, please call us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Jan 26, 2015 | Dyson DC35 Handheld Vacuum
Hello, I have a Dyson DC31 and she keeps shutting down. Most of the time she will shut down as fast as you pull the trigger, other times she will only power up for about 5 seconds before shutting back...
Hi there, it's Jack at Dyson.
If you need some help with your DC31 Animal handheld, we'd like to put you in touch with our experts for some diagnostic checks. Can you let me know where you're based so I can supply the correct contact details?
Oct 26, 2013 | Dyson DC31 Bagless Handheld Vacuum
Motor just makes 4 or 5 small clicking noises when you pull the trigger, then stops. The little lights illumintae around the "max" button as well. However, the motor does not engage in the slightest. ...
fiter is dead clogged up inside. you could wash it 50 times still wont unclog. simple fix, just buy a new filter and empty bin more often in the future and wash filter every month and fit new one every two years
Jul 15, 2017 | Dyson DC35 Handheld Vacuum
DC44 Animal Cordless Vacuum power cuts on and off while trigger is pulled
This doesn't address the intermittent power cut offs...power cuts off intermittently and you have to keep recycling the power 'trigger' to get it to work...total PIA
Dec 17, 2012 | Dyson DC44 Animal Cordless Vacuum
DYSON DC16 STOPS & STARTS
go to http://content.dyson.com/support/
and see the complete information for troubleshooting, manual, videosetc.and fix it.
God bless you
Sep 25, 2012 | Dyson DC16 Bagless Handheld Cyclonic...
My dyson handheld charges fully, but keeps cutting out when using. About 7 seconds is the longest continual usage time
Your battery is losing voltage too quick. It has probably developed a 'memory'. Dyson claims that their handheld has the best suction out of all the handhelds out there. In order to maintain that claim the circuit board will shut off power to the motor when the voltage drops below adequate charge for full suction.
We need someone who can teach us to bypass that part of the circuit so it won't cut power to the motor or you need to replace the battery.
Shorting the battery like an Aircraft battery then re-charging won't fix it.
May 21, 2011 | Dyson DC16 Root 6 Bagless Handheld...
My dyson dc 16 hand held vacume stops & starts while in use, each time you pull the trigger it will start again but then stops after a short while untill i pull the trigger again.
Cutting out can be due to a few things , motor overheating due to dirty filter, Faulty mains cable or plug..sealed type also..Faulty Switch/trigger.May need to seek pro help to fix.
Apr 01, 2010 | Vacuums
My DC 16 will only run for a second each trigger pull. The battery is fully charged, it has plenty of suction, just wont run for more than a second. I cleaned the filters.
I had the same problem with my Dyson DC16, where it only runs for a few seconds at a time with each trigger pull. My husband called Dyson (Canada) and without hassle they shipped us a replacement part which I just received this morning. The replacement part sent to us is: DC16 Main Body with Rating Plate. It is also under warranty for 1 year. The great customer service makes up for the flaw in the machine. Also, Dyson is aware of the problem. Hope this helps.
Oct 25, 2009 | Dyson DC16 Root 6 Bagless Handheld...
Vacuums Logo
449 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
