Question about Minolta Di2510 All-In-One Laser Printer
Tengo una konica minolta y meaparese con error co500 la maquina es modelo DI2510 me puede alludar a des bloquearlo gracias
  • Minolta Master
  • 6,696 Answers
First open the right side cover where the image unit is located. Check the two latches that latch the door ensure they are not broken, especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel will go thru some screens when you see the screen with the copiers on it on the left side of the screen in the middle you will see a small "." When the dot appears touch 3 button. Then the machine will continue to the code screen. Press the Utility button you should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset you are messing with the Fuser the Hot part. Continuing to reset without a technician looking at and or replacing it, the fuser can catch on fire and that would ruin a perfectly good day.
Try this site for parts
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Nov 21, 2015
geemarie
  • 876 Answers
SOURCE: LEXMARK X3550
Quite los cartuchos. y asegúrese que las pequeñas cintas protectoras han sido quitadas de los contactos. Entonces examine donde los cartuchos caben en la impresora. ¿Es limpio en allí? ¿Hay allí alguna tinta secada o gotas de la tinta en allí? Si hay, usted puede apagar y desenchufar la impresora y usar una cantidad diminuta del alcohol desinfectante en un Qtip para limpiar la tinta.
Si no sustituyen los cartuchos que se los aseguran adecuado cómodamente. Ahora continúes su computadora a - Principio> Panel de instrumentos> impresoras y faxes> chasquido DERECHO en su icono de impresora y elija preferencias> servicios. Cuando usted está en servicios abiertos y mira cada opción allí. Haga cualquier prueba o limpieza de los cartuchos a los cuales esto le pregunta. Cuando usted es terminado, apaga su impresora y reanuda su computadora. Si el problema no es ido, contestarme. Espero que mi español sea comprensible. Gracias.
Posted on Aug 20, 2008
  • 117 Answers
SOURCE: error CO500
This error code indicates low temperature at warmup.Can somestime be reset IF you can find the reset switch.On earlier models it was behind a small panel on the innards of the machine after you open the front door.Good Luck!
Posted on Apr 02, 2009
herminio_hal
  • 210 Answers
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Posted on Jul 09, 2009
firecontrol7
  • 6696 Answers
SOURCE: Konica Minolta C350 colour copier T096 error code??
Transfer belt code C096 mite try open and closing the front door where you put the toner. Also remove the image transfer belt and then reseat it.
Posted on Jul 19, 2009
SOURCE: Konica Minolta Magicolor 2300 DL - Fatal Error Code 0EH ????
I had the same problem one time, they told me to pull out all of the toner cartriges, power off, power on, power off, replace all cartridges and the problem went away.
Who knows why. If this doesn't work....
Call Konica Minolta tech support.
http://ewpm.eu/konika-minolta-2300-w-fehlercode-0eh-17h
Posted on Jun 02, 2013
Singer 5932
Hola tambi?n tengo una m?quina singer modelo 5932 tengo problemas al momento de enebrar la aguja, la m?quina se salta puntadas, el zigzag no lo hace bien y por la parte de atr?s se ve la costura suelta o los hilos enrollados, no se que hacer, no tengo manual y no encuentro nada en YouTube, ni en Google, no se si el problema sea la bobina, la tensi?n (la tengo entre 4 y 5), el enebrado, la aguja o yo!! Jaja ayuda!!! Graaaciasss mi correo es roselix.fernandez@gmail.com
Jan 06, 2014 | Sewing Machines
Tengo una cannon power shot sd600 digital elph, en ella tengo 15 fotos y dos videos de 2 minutos cada uno la memoria es de 500 mb, pero el display dice memoria llena y no me deja sacar fotos ni capturar...
¡Hola!
Bienvenido a Fixya. Posible que sus videos y fotos se guardan en su memoria interna no en la tarjeta SD / tarjeta de memoria. S?lo tienes que seleccionar la tarjeta de memoria de dolor o guarda sus im?genes.
Gracias por usar ou Fixya,
seancarlisle
May 13, 2011 | Canon PowerShot SD600 Digital Camera
Tengo una television sharp y no se como programarle el control universal dish podrias ayudarme con los codigos y la manera en la que se programa
Hola mi nombre es Kimberly Escobar con DISH Network. Seria un placer ayudarle proveyendole la informacion que necesita para programar su control con su televisor Sharp. hay ciertos codigos que se pueden integrar a su control permitiendole funcionar con la T.V. Para la marca Sharp tenemos los codigos 628,739,741,605, y 835. El procedimiento es el siguiente: oprima el boton de T.V localisado en la parte de arriba en el control hasta que los demas botones se prendan en rojo una vez esten iluminados ingrese uno de los codigos seguido por el signo de numero, (por ejemplo 659#) el boton de T.V debe iluminarce 3 veces. Despues de esto puede intentar usar su control tambien puede entrar a nuestro link aqui puede encontrar mas codigos e instrucciones a como programar el control http://www.dishnetwork.com/SupportSection/remote-setup si necesita mas ayuda o tiene preguntas adicionales por favor contactenos directamente al 1800-333-DISH. Gracias y espero esto le sirva de ayuda.
Apr 04, 2011 | DISH Network IR Remote Control
Tengo una vfr 800 2003 de primer instancia me descargaba la bateria o pila le cambie la pila x una nueva y aun sige el problema me le cambiaron la corona y sige igual x favor alguien ayudeme ya no la muevo...
Hola ranajoel_23, yo tengo una del mismo a?o y he tenido problemas con el sistema el?ctrico tambi?n. Este modelo suele dar problemas con el regulador, que si no se detecta a tiempo puede causar aver?a m?s grave en el alternador, por lo que te recomiendo que lo revises. en este foro hay una informaci?n excelente: http://www.clubvfrspain.es/index.php?topic=31881.0
Tambi?n ha tenido problemas por una mala instalaci?n de pu?os calentables, que provocaban una p?rdida de carga a la bater?a, una ver modificada la instalaci?n, no he vuelto a tener problemas.
Espero que te sirva de ayuda.
un saludo
Mar 08, 2011 | 2002 Honda VFR 800 ABS
Programar el contro
Hola mi nombre es Mayra Diaz con DISH Network. Tengo entendido que quiere programar un control. Si por favor me puede dar informaci?n adicional con mucho gusto le puedo ayudar con este problema. La informaci?n que necesito es ala televisor que lo quiere programar o al recibidor de DISH Network, otra cosa seria cual es el modelo del control esta localizado en la parte de atr?s de su control.
Jan 13, 2011 | DISH Network IR Remote Control
Hola , necesito saber si puedo cambiar toda la maquina, excepto el DD y dejar este mismo como master, tengo programas que me costaria mucho conseguir e instalar de nuevo gracias
Muchas Gracias COnstantin, quizas me expresé mal, mira mi problema es que el pc, excepto el disco nos quedó chico, es decir, quiero cambiarlo por una maquina mas nueva core duo por ej, por ende con distinta placa, y el DD tiene toda la informacion y programass con licencia que necesito, entonces necesariamente tiene que quedar como master, me indicaba un tecnico que los driver de la placa podriasn darme problemas, si es así y tengo los drives de la maquina nueva ( placa) no debiera tener problemas?
agradeceré tu respuesta
gracias
Jun 23, 2009 | MSI PM8PM-V Motherboard
TENGO UNA SONY VAIO VGN CS118 E , A LA QUE LE INSTALARON WINDOWS XP , PERO ME FALTA EL CONTROLADOR QUE DICE : MODEM DEVICE ON HIGH DEFINITION AUDIO BUS. SI ME PUEDEN DECIR DONDE ENCONTRARLO , AGRADECIDO....
Para arreglar <<MODEM DEVICE ON HIGH DEFINITION AUDIO BUS>>, puedes encontrarlo aqui: http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNCS118E&SelectOS=7#div_pos_5
"La maquina no anda bien" - No entiendo, la maquina no esta trabajando, o es lento?
Pregunta si tienes mas problemas,
Lo siento por mi espanol, no es muy bueno :).
Apr 29, 2009 | Computers & Internet
NO TENGO EL CD CON LOS DRIVER DE LA PLACA MADRE SE FORMATEO EL EQUIPO
¿Sabes el modelo de la placa madre? Si no lo sabes, aún así puedes conseguir los drivers, pero es más fácil con el modelo. Si es una computadora de marca, solo necesitas el modelo y la marca, y bajar los drivers de la pagina web del fabricante.
Apr 14, 2009 | Computers & Internet
Pc lenta
Los problemas en tus maquinas son de virus y conflictos de software. En el caso de la # 1 es posible que este lenta por problemas de hardware, pero si decis que en las otras hay troyanos es muy posible que toda la red este infectada. Los troyanos la unica manera de erradicarlos definitivamente es formateando las maquinas y reinstalando todo de nuevo. (Los antivirus por mas efectivos que sean no sacan este tipo de problemas y a la larga terminas reinstalando todo de nuevo) Te recomiendo hacer un respaldo de todos tus archivos, y reinstalar todo desde cero.
Sep 24, 2008 | Intel Dot Station (INTC300AIO) PC Desktop
No tengo el cd de instalacion de mi camara web
Hola, MK TECH es una marca propia del comercio mayorista MAKRO, dicho comercio aparentemente solo trabaja en Argentina. Lo que puedes hacer es buscar por internet el modelo de la cámara o el fabricante (posiblemente inexistente) o usar un software monitor de USB para obtener los valores PID y VID de la cámara.
Con los números PID (Identificación del producto) y VID (Identificación del vendedor) puedes buscar en google para dar con el driver adecuado. Seguramente es una marca genérica como SQ.
Saludos desde Santiago del Estero.
May 04, 2008 | Microsoft Office Outlook 2003 for PC
Minolta Di2510 All-In-One Laser Printer Logo
219 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
