Question about Lenovo Computers & Internet
My computer has sound but mic does not work - Lenovo Computers & Internet
  • Lenovo Master
  • 27,725 Answers
Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it hope this helps
Posted on Mar 23, 2011
Output sound
I plugged some speakers into the mic itself, that worked for me. But I cant get the sound directly on my computer
Oct 04, 2013 | SE Electronics SE X1 Microphone
Hi there i have an xps 420 computer and my mic isn't working it says its plugged in and recognizes it but no sound come out and i even tried recording and nothing happens. i tried my mic on another...
first you can check your mic is muted..just open control panel and there will get the option of sound properties after u can check there mic is muted or note.otherwise you must reinstall your audio sound card driver because this issue is same as audio driver problem.if u still have the same issue after reinstall your driver you must reinstall your operating system.if still have the same issue?? you must check your mic port of your computer.thank you.
Sep 05, 2011 | Dell XPS 420 PC Desktop
Losing sound when plug in mic
You are probably plugging the mic in the wrong port, you should plug it in the other port looks the same.
I think the port that you are plugging in your mic is of sound (headphones).
Hope this helps
Mar 30, 2010 | Audio Players & Recorders
My integrated mic is not working how do i check it
Hai,
Right click on my computer, click properties, press hardware tab, then click device manager. Anything with a ? in yellow means the driver is not installed. Is it a mic thats mounted into the laptop? Or did you connect it? If you connected it, try changing mics and see if that works.
Aug 25, 2009 | Computers & Internet
When i plug in a mic, it wont work. under
You need to do the following
1. Open Sound & autido devices from controlpanel
2. Click Advanced button in Volume tab
3. Select properties from Options menu
4. Select Recording & press ok
5. Select External MIC instead of others
Aug 02, 2009 | Intel Celeron D 2.8GHz 478-pin 533MHz CPU...
Mic not detected
Double click the "sound icon" on your windows taskbar. You will be shown with the volume control. Uncheck the control that says "mic" since by default it is Click "Mute"
Hope this helps.
Mar 16, 2009 | Intel D101GGC Motherboard
No Sound Coming out my Microphone
i know this might sound a little obvious and maybe irrelevant to the problem, but did you press the switch on the mic? it will turn the mic on and off. make sure sound and mic are unmuted in windows volume control. if both are these didnt solve the problem, test the mic on another computer. if the mic works, maybe its not the mic that has the problem. if the mic doesnt work, then your mic may be defective or damaged in some way or other.
Mar 28, 2008 | Philips PH62080 Uni-Directional Microphone...
Cyber acoustic mc 1060
For Vista 32 bit. Go to the driver manager. De-instal/delete the driver in the Sound, Video and Game section. In my case it was RealTek High Def Audio ver 6.0.1.5371. (Select Delete the driver files.) Reboot. Vista will reinstall a driver. In my case it was Microsoft High Def audio ver 6.0.6000.16386. I had the mic plugged in when I rebooted to load the new driver. The Cyber Acoustics ML-1060 now works fine. Hope this helps.
Jan 25, 2008 | Cyber Acoustics CV-1064 Microphone
Acknowledging Microphone
Sounds like the mic is bad. The only way to confirm this is to plug a different mic into the computer and see if that works. If the second mic gives no sound then the computer may have an issue. Hope this helps.
Nov 04, 2006 | Logitech (980240-0403) Microphone
Computers & Internet Logo
60 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
