Question about Zanussi TC180W Electric Portable Dryer
I have a kenmore dryer it will heat up but it wont blow out the heat what should i do
  • Zanussi Master
  • 43,501 Answers
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Posted on Apr 02, 2011
SOURCE: Kenmore dryer (electric )
NOT ELITE HE4..... Model 96595400. Replaced thermistor and Hi-Limit Stat. Probably the thermistor.
Posted on Jun 29, 2008
jumptrout51
  • 3361 Answers
SOURCE: KENMORE DRYER MODEL NUMBER 66912690 WONT HEAT
Check the voltage at the terminal block where the cord hooks up for 220 volts.
Remove the rear panel and check the thermal fuse located on the upper portion of the heat canister.
Check the Hi-limit thermostat on the bottom portion of the heat canister.
Check all the wires for a burned or loose wire.
Check continuity of the heating element.
Posted on Mar 08, 2009
SOURCE: I have a Kenmore Heavy Duty, super capacity, quiet
It sounds like your heating element has broken. There are several links provided on this site on how to replace it. You might want to take a look at davesrepair.com to purchase a new one. He has pretty good prices on the element.
Posted on Mar 28, 2009
SOURCE: Kenmore dryer model 110.74832400 does not blow heat
It's most likely, one of several thermal limit switches/thermostats or the heating element. If you want to pursue further, let me know.
Posted on Apr 30, 2009
dragonsthatk
  • 547 Answers
SOURCE: Older dryer just stopped heating. Air still blows
Sound like you need to replace the heating elament you will need to take your model number and make to repair shop for replacement parts or have a repair person come out and fix it for you . thanx for using fixya
Posted on Jun 19, 2009
My dryer doesn't have heat anymore, and i already got the new heater but the new heater still doesn't work. Please help.
have you taken the vent hose off and felt to see if it is blowing hot air? Here is a website that has possible solutions to no heat:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Oct 29, 2010 | Kenmore Dryers
Kenmore dryer won't heat up.
can you describe the issue isn detailed or is the issue aiready resolved.
Oct 15, 2008 | Dryers
Wont heat at all
On top of the element is a limit that blows if the venting or ductwork is clogged from fluff. I have a few repair photos HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 10, 2010 | Kenmore 62602 Electric Dryer
My kenmore dryer will not heat up and timer will not shut off on auto
`check ur restricted vent, or bad coils, is the vent is restricted the heat would built , but won't exit the machine, the gas valve shuts off, an wont come back on till it cools down then the same thing will happen over an over and that wont let the timmer advance an finish its cycle, take the backvent off an turn ur leaf blower an blow the lint off the duct, new houses with a roof vent specially here in chicago have problems when the lint an ice combine create a big vent problem. if you have a roof vent, u can remove the screen on the vent at the roof, birds will not go in,seeking for heat, because the new dryers dont have a stand by pilot like the old ones, so they don't provide heat 24/7, and when they inuse they blow so much air is impossible for a bird to stand the temp an the speed of the hot air
Feb 01, 2010 | Kenmore 73952 Gas Dryer
Dryer heats, tumbles clothes, blows air out exhause vent, but wont dry clothes
what type is this electric or gas? have you removed the exsaust from the wall and ran a load like this? if you have heat and this is an electric dryer it sounds like you have a blockage in your house. if the dryer runs fine without the exsaust attached then that is your problem. let me know
Jun 02, 2009 | Kenmore Dryers
Apr 30, 2009 | Kenmore 73952 Gas Dryer
Dryer blowing cold air only
Check your heat sensors, one or more must be OPEN.
Mar 26, 2009 | Kenmore 84052 Dryer
Mar 17, 2009 | Kenmore Dryers
Dryer wont heat
Hi.
Check thermostat Make sure you are getting power to the element and stat.
If not , then timer probably faulty
Nov 22, 2008 | Kenmore 62602 Electric Dryer
Zanussi TC180W Electric Portable Dryer Logo
Top Zanussi Dryers Experts
Tim Whalen
Marvin
Marvin
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
