I have just used an Ignis AWV 619 M front loading machine but i cant get the door open now that is finished, I have never used a front loading machine before, am i doing something wrong?
    Brigadier General:
  • 6,277 Answers
You are not doing anything wrong; front loaders do basically the same as top loaders- only they can go under units ;-0)
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 23, 2011
My whirlpool duet front load washer thre a code 28 and cant get the washer to finish cycle and can not get door open
Bottom front panel comes off is a release lever you can pull to open the door,inside that panel is also where they hide the manual. Sears repair told me the electronic brain box go/s after 2 years
May 25, 2015 | Whirlpool Washing Machines
My Ignis washer door would not open
This video will show you how to open your ignis washing machine door that is stuck shut
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 20, 2013 | Washing Machines
Washing machine has 1 minute left on cycle stuck door wont open programme not finished
Try the following, may work:
Press the Start/Cancel button together until all the console Led's illuminate
  1. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  2. Default screen should return. Switch off.
  3. Wait for 2 minutes to try the door. If helped click.
Apr 18, 2013 | Hotpoint Ultima WF860 Front Load Washer
I broker the handle of the machine (washing is Finished) cant get the door open for Hotpoint washing machine
Since the door is broken try to break the latch, without damaging the rest of the machine. Will need a screwdriver and drill, to remove the plastic door. Don't drill into any glass or metal.
A new door will need to be sourced.
Sep 08, 2011 | Hotpoint WMA30 Front Load Washer
Cannot open the door
'UE' adalah menandakan " unbalance error ", solusinya adalah set kembali posisi mesin cuci anda jangan sampai miring atau seimbang dari permukaan lantai. jika sudah dianggap seimbang, coba hidupkan kembali mesin cuci anda dari proses pertama.
Jul 31, 2010 | Samsung WF337AA Front Load Washer
Door wont open
I am assuming you have a front loading machine. This is a safety feature so you don't open the machine and water runs out or a child crawls in. You need to turn the machine off (turn the dial to finished and push the switch in)
Oct 29, 2009 | Whirlpool Washing Machine Knob - 3362624
Aquarius 1100 - door won't open
lift lid of top reach to front and pull the wire cable up to the door latch make sure u unplug machine first
Sep 07, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Wd63 door
The main cause with this model is water still in machine. Try a spin and look for water in drum. To empty manually lower drain hose into bowl untill empty. Door should then open.
Nov 08, 2008 | Hotpoint Aquarius WD63 Front Load...
Can not open the door after cycle is finished
i think you are talking about a front loading machine, have you waited for at least 3 mins before opening the door?
these types of washing machines locks the door in order to run. but after a cycle is finished, the door would not open right away, there is a delay on opening the door.
let me know what happened,
tnx 4 using fixya,
drcool
Sep 19, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
