Question about DISH Network IR Remote Control
How to i program a direct tv remote to my digital tv converter. dt250 model apex
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 358 Answers
Nucklebuster
I have provided a link with instructions on how to program yoru remote to your TV. The Webpage also has links for the codes. I hope this helps.
http://2getdtv.com/directv/remote_codes.html
Ray Calo
DISH Network
Posted on Mar 26, 2011
SOURCE:
We have a naxa converter box with a GE universal remote searching for the code
About 17,100 results (0.72 seconds) Search Results
    GE Universal Remote Codes and Instructions ' direcTutor
    www.directutor.com/content/ge-universal-remote-instructions
    Enter the three or four digit code for your device using the number buttons in the GE Universal Remote. After your code is entered the INDICATOR LIGHT will ...Missing: naxa
    Apex Digital TV Converter Box DT250 code ' ManualsOnline ...
    tv.manualsonline.com/support/...digital/tv-converter-box/code-1082992
    Nov 15, 2008 - Brock Search data: Universal remote control code apex dv converter... 4 I NEED CODE FOR APEX CONVERTER BOX FOR GE UNIVERSAL ...
    Trouble programming Universal Remote to a DTV Converter ...
    www.fixya.com/.../t2045188-trouble_programming_universal_remote_d...
    Apr 21, 2009 - So I'm trying to program my GE Universal Remote to work with my Digital Stream Converter Box but I can't find the codes to do it... If someone ...
    Control It All With Universal Remote Codes - Digital Landing '
Feb 08, 2016 | GE Televison & Video
How do i program a vibe unversial remote for apex digital converter box
Use the code search feature to find something that can handle some or all functions of your Apex STB. If a search through all codes contained in the Vibe remote fails, you may have to try a different universal remote. All universal remotes do not contain all possible codes.
Jan 13, 2016 | Televison & Video
How do I program RCA universal remote to my apex dt250 digital TV converter
Programming procedure is too much to type in here, and is not practical. If you wish to get more details, check the site linked here. It has setup code list & setup instructions to many popular brand remote controls. Pull up older posts.
Nov 27, 2013 | Televison & Video
Programming
0956,0977,0923,0954 are the codes to check. If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
Apr 15, 2013 | Toshiba Ct9952 Remote Control
PF2020 RESET CHILD LOCK
Turn your television and Apex DT250 receiver on.
Push the "Menu" button on the Apex DT250 remote control.
Press the remote's "Up" and "Down" buttons to scroll through the menu options. Stop when "Parental Controls" is highlighted. Press the "Right" button to select this option.
Enter your four-digit password. If you have not set your password, use the default code of "0000."
Use the "Up" and "Down" arrows to change or set the parental control movie ratings. You can select from "None," "G," "PG," "PG-13," "R," "NC-17" and "X." Once your setting is highlighted, press the "Right" button to go to the next screen.
Use the "Up" and "Down" arrows to change or set the parental control TV ratings. You can select from "None," "TV-Y," "TV-Y7," "TV-G," "TV-PG," "TV-14" and "TV-MA." Once your desired setting is highlighted, press the "OK" button to save your settings. Once the settings are saved, you will be taken back to the main menu. Press the "Exit" key to exit the main menu.
Oct 31, 2012 | Apex Digital PF2020 20" TV
Need remote code for apex dt250
Hello
It is very difficult to get a remote control which have codes for Apex. There is one model that have the codes for Apex tv. It is "COMCAST ON DEMAND CUSTOM-3 UNIVERSAL REMOTE CONTROL"
The setup codes for Apex Tv with this remote are:
0748, 0765, 0767
All prceedings and other dvices' code list will be there with this remote, when you buy it. No other way other than buying this model remote control. OK.
Sep 18, 2011 | Apex Digital LD4088 LCD TV
I have an Apex Digital TV Converter box # DT250A. Today, all of a sudden my TV screen went greenish and then the picture on my TV went out ( static looking screen ). The light that's on my Converter Box...
The DT250 likely has one or more bad 470uf 25v capacitors. You should replace all four. Look at some of these youtube videos for how do do the replacement.
http://www.youtube.com/watch?v=on_2CP52cW4
http://www.youtube.com/watch?v=YCSNWi3UHf4&NR=1
Order 4 new 470uf 25v capacitors from digikey.com P/N P10274-ND
Use first class mail as your shipping method. Will be under 10 dollars total.
Jul 05, 2010 | Apex Digital Televison & Video
Need Universal code for RCA remote with Apex DT250 Digital Conver
Use cbl/sat button. Your remote might use more or less than 4 digits. Use 749 or 00749. It'll probably work. It worked for me.
Jul 30, 2009 | Televison & Video
Need a Philips universal remote code for Apex digital tv convertr
try going to this Philips site and using their universal remote control finder tool ...
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?tmplt=ePlatform%20-%20Philips&scy=US&slg=AEN&sct=REMOTE_CONTROLS_SU1&cat=REMOTE_CONTROLS_CA1&session=20100815184715_64.252.199.203&grp=SOUND_AND_VISION_GR&ctn=SRP4004/27&mid=Link_RCCodeFinder&hlt=Link_RCCodeFinder
Feb 20, 2009 | Televison & Video
DISH Network IR Remote Control Logo
402 people viewed this question
Top DISH Network Televison & Video Experts
Steve Allison
Steve Allison
Jaime Hernandez
matt martin
matt martin
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
