Question about Sony ST-SA50ES 2 Channels Tuner
Want to reset sony genezi as it is sitting in protect mode.
How do I remove the 5 way ribbon and 7 way cable from the main amp module of my mini hifi?
That unit looks like an economy model that is mass produced. It would probably not have quick connects on the boards. You are going to have to use a soldering iron.
Jun 27, 2014 | Audio Players & Recorders
How can I get Dynex TV out of "protection mode"?
the protected mode kicks in when there is a safety issue with the receiver. This usually comes from an overload to the system via a short in the system or perhaps a surge in power. Your receiver shuts down, and you'll need to shut the entire system down to fix it.
In some older homes, some of the wiring doesn't deliver the "cleanest" power, delivering minor power surges to the items you plug directly into the wall. If your receiver is plugged directly into the wall, purchase a surge protector to stop this
Read more: http://www.ehow.com/about_5516888_problem-sony-receiver-protected-mode.html#ixzz2ZYa9W0Mi
God bless you
Read more: http://www.ehow.com/about_5516888_problem-sony-receiver-protected-mode.html#ixzz2ZYZm8THG
Jul 20, 2013 | Dynex 32 in. LCD Flat-Panel HDTV
How to reset my sony mhc-gs100??? it keep saying power protect...
Your stereo went into protect mode to prevent complete failure of the amplifier inside that radio. Most of the time this happens from playing the stereo real loud for a real long time and it overheats. Most of the time disconnecting the receiver/stereo and letting it cool all the way down or at least 5 minutes and then reconnecting it to the power source will reset the protection mode. You want to make sure you are keeping the radio cool. Don't stack anything on top of it and try keeping a small fan blowing on it to expedite the heat out from the unit. Also turning it down every now and then to let everything cool down a bit will help prevent it from going into protection mode as well.
Mar 24, 2011 | Sony MHC-GS100 CD Shelf System
I need then service manual for my Sony GENEZY MHC-GT555. I must clean the cd lector.
I used a long wooden stick and put a peace of cotton in one end (weeted with tap water, just moisted).
Then I introduced it through the open CD tray and wiped the sensor twice or three times.
It worked OK.
Hope it can help.
K.R.
Feb 07, 2010 | Sony Audio Players & Recorders
Ps3 wont turn on
Yes.
Make sure:
1) Its not sitting on carpet
2) has a 3 inch clearance all around it
3) it's dust free - use canned air or a vaccuum
4) it is plugged into an appropriately rated power strip; or an outlet designated specifically for it.
If these simple solutions don't work, I'm sorry but you'll have to send it in. To avoid high shipping charges, take it to the USPS and get a flat rate box.
Sep 21, 2009 | Sony Playstation 3 (PS3) Console
Receiver stuck in protect mode
surely i can reset this myself without paying sony!
Feb 01, 2009 | Sony STR-DE545 Receiver
Stuck in protect mode
Speakers shorted out, blew a fuse. Replace the unit or (cross your fingers and) open up the box and find the blown fuse.
Nov 23, 2007 | Sony STR-DE425 Receiver
Sony ST-SA50ES 2 Channels Tuner Logo
405 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
