The washer leaks water. Not much and not connected to the hook-ups. The water seems to be coming out of the door.
  • 2,382 Answers
Hi, check the door seal for holes or for wear and tear. If the seal has a hole or it's broken, then the leaking water could be originating from the inside and coming out from under the front of the machine. There also could be something stuck in between the door seal and the glass that could have broken the seal.
Posted on Mar 23, 2011
2 Suggested Answers
  • 149 Answers
SOURCE: Washer is leaking. If facing washer, water is on
probablly water pump or hose tilt machine to view where water is coming from
Posted on Jan 18, 2010
F20 error code
copied from the net..............
The "F20" fault code is indicating NO WATER IS BEING DETECTED ENTERING THE WASHER OR THE PRESSURE SWITCH IS NOT TRIPPING OR SENSING A TRIP.
If there is no water in the unit:
Make sure that both valves at the water source(s) are turned on all the way and water enters.
Check for plugged or kinked inlet hoses or plugged screens in the inlet valves.
Verify inlet valve operation.
If there is water in the unit:
Verify drain pump operation.
Verify that the pressure switch hose is in good condition and properly connected to tub and pressure switch.
Verify there is not a siphon problem.
Press STOP twice to clear the display. The machine will drain for 3 minutes before unlocking the door.
Unplug washer or disconnect power.
Verify wire harness connections to inlet valves, pressure switch, drain pump and Central Control Unit (CCU).
Check all hoses for possible leaks.
Plug in washer or reconnect power
Verify pressure switch operation.
I recommend calling a service technician to diagnose and repair your washer if water will entering the machine and not siphon out.
cheers
Aug 03, 2017 | Kenmore HE2 Plus Front Load Washer
Cold water leaks into tub when machine is off
Try to identify roughly the area the leak is coming from. This will eleminate some of the following
Hose Connections
Check the rubber washers or replace if the hoses are leaking at the WATER INLET valve
Door Seal
This is a common place for leaks. Carefully check by partially pulling seal inside out and check for punctures, pens, pencils... Additionaly if the door is not closing properly it may need a door adjustment. This can easily be done by loosening the hinge bolts on the front panel, adjusting and retighten. The seal is also known to get lightly snagged by zippers or rub by heavy items when close are being removed. This tends to cause the seal to get damaged at the six o'clock position. This is sometimes hardly noticeable but if it is leaking from the bottom of the door replace door seal.
Water Inlet Valve
If the hose connections are good to the water inlet valve check that water is not leaking from the valve itself it is replace inlet water valve
Drain Pump
Check the drain pump housing and all hose connections. The drain pump is behind the lower panel, behind the back panel, and sometimes removal of the front panel. Hoses can be tightened. If hoses or pump housing is leaking replace pump .
Outer Drum
The outer drum is 2 halves bolted together some washers have a seal between others do not. If the washer is leaking between the seems disassembly of the washer will be necessary. The top panel, console, front panel, door seal, struts. 9696d86e-1b8b-4b2e-af2c-6f3a3ae921dc.jpg
May 23, 2013 | Siemens WK61420GB Front Load Washer /...
Hi, I have a Hotpoint Aquarious washing machine (UK). It has developed a leak and seems to be overfilling however it does stop filling. Hope you can help.
I can not see the entire front of your machine, are you sure its over filling? I use a front loader also, at the bottom of my front loader is a small door, when I open it there is a drain pipe inside, sometimes the drain needs to be cleared. I am hoping this is your issue and that this is a quick fix for you.
If not, you can check the back of your washer where your water hose connects to washer. Inside the hook up is a screen (on your washer) sometimes these become clogged due to mineral deposits in the water.
Jan 07, 2013 | Washing Machines
How to remove powder drawer indesit w1a101
see this causes and fix it. God bless you
Hose Connections
Check the rubber washers or replace if the hoses are leaking at the water inlet valve.
Door Seal
This is a common place for leaks. Carefully check by partially pulling seal inside out and check for punctures, pens, pencils... Additionaly if the door is not closing properly it may need a door adjustment. This can easily be done by loosening the hinge bolts on the front panel, adjusting and retighten. The seal is also known to get lightly snagged by zippers or rub by heavy items when close are being removed. This tends to cause the seal to get damaged at the six o'clock position. This is sometimes hardly noticeable but if it is leaking from the bottom of the door replace the door seal.
Water Inlet Valve
If the hose connections are good to the water inlet valve check that water is not leaking from the valve itself it is replace the water inlet valve.
Drain Pump
Check the drain pump housing and all hose connections. The drain pump is behind the lower panel, behind the back panel, and sometimes removal of the front panel. Hoses can be tightened. If hoses or pump housing is leaking replace the pump assembly.
Outer Drum
The outer drum is 2 halves bolted together some washers have a seal between others do not. If the washer is leaking between the seems disassembly of the washer will be necessary. The top panel, console, front panel, door seal, struts. Follow the video for the strut replacement and remove the top springs and the inner and outer drum will pull out the front
Sep 27, 2012 | Washing Machines
Jan 17, 2010 | Kenmore HE2 Plus Front Load Washer
Whirlpool fron loader washer leaks at the door
The water should be able to come up to the door level without leaking. Chances are you have build up on the bottom side of the glass on your door. If so take a razor blade and scrape the build up off. Your door will quit leaking.
Aug 12, 2017 | Whirlpool Duet GHW9150P Front Load Washer
LG WM2487 Leak Front Left
Not sure if this machine is similar to the WM2277, but here is the procedure for that - my leak was in the "baffels" hose that connects the drum to the drain pump:
1. Drain the machine - pry the panel at the front left lower corner to get access to a stoppered tube. drain as much water from here as possible.
2. Remove screw visible inside this area and remove the white molded plastic - also remove the screw behind that plastic.
3. Open the washer door and remove the spring loaded wire around the door gasket. Carefully pull the door gasket away from the panel push inside and then reclose the door.
4. Remove the detergent drawer and the two screws visible behind it.
5. Pull the top of the electronics panel away from the machine and lift up - place on top of machine or hook it out of the way
6 Remove the 4 screws that are visible holding the front panel to the machine. Left the entire front panel up about 2 inches and swing to the right (there is a wire connecting the door to the machine on the right)
Jan 16, 2009 | LG WM-2277HW Front Load Washer
Leak
found the problem. the leak was in the drain hose in the upper part of the washer
Mar 18, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
