Question about Samsung (SP0411N) 40 GB Hard Drive
Rakesh here. hi, i can notice several changes with my samsung SP04IIN HDD as mentioned below.. 1. more noise from my hard disk these days. 2. primary master hard drive s.m.a.r.t command failed, press F4 3. few times i get kernel stack inpage error (BSoD) Is there any serious problem with the same ????
    Scholar:
  • 138 Answers
The drive sounds like it is failing. Noisy drives are a classic sign of impending failure. I would back up all of my critical files and replace the drive as soon as possible. The longer you wait, the more damage can be done and you might not be able to recover files. Good luck
Posted on Mar 23, 2011
  • Daniel Fiore Mar 23, 2011
    Im just wondering why you gave me such a low rating. was my answer not satisfactory or accurate?
  • rakeshp1610 Mar 26, 2011
    wt abt response regarding 2nd and 3rd point as per my last comment.. u just considering noise and concluding ?
Procedure For Installation Of Hard Disk In Bizhub 363
Procedure for Installation of Hard Disk in Konica Minolta bizhub 283/363/423 Photocopier Machines,
1-Get a SATA hard disk. NOTE: SATA HDD is supported in the above mentioned models. IDE or PATA are not supported.So get a SATA HDD.
SATA HDD have two main connectors. 1 is for Data and the other one is for power as shown in the image.Two separate cables are used.Data cable and the power cable.Get both the cables.Image of the cable is shown below.
bffe98cc-9b42-4878-b7d2-80a65e264546.jpgData Cable for SATA
107b626c-ac31-4927-b142-6dd8674309f2.pngPower cable for SATA Hard Disk
3-Connect the cables in their respective areas.
4-Now place the hard disk on its fitting. HDD mounting kit is fitted at the main control board of the machine.For this, open the back side cover of the machine and you will get the fitting.It will be on the main board in front of you. Now fit the HDD on its mounting and tight the four screws at its sides to keep HDD safe from shocks / jerks.
5-Now connect the data connector and the power connector to the control board.There will be two separate jacks for power connector and the data connector.
6-After fixing both the connectors to the main board, close the rear cover of machine with the screws.
7- Now turn the machine ON.
8-Go to the service mode and click on "SYSTEM 2"
9-Now click on "HDD" and select "ENABLE" and press "OK"
10-Now click on "state confirmation"
11-Select "HDD"
12-Now click on Format Hard disk.Select "Logical Format" not the physical format.Press "START" button and wait for few minutes.
13-When formatting is finished press "OK" and restart the machine.
14-Your new HDD installation is complete now and its ready to use for box operations.
Jan 12, 2014 | Minolta bizhub 250 Black and White Copier
Hi, i bought my Asus U46E-BAL7 one year and several mounths ago and i have noticed some unknown noise. It seems to be from hard disk, but I am not sure. So the system stops working and even rebooting, the...
Its probably that the hard disk has some clusters with damage , but you need to do test directly with the hard disk, its posible one time to ron the scandisk search from the tools by propierties in the Disk ( Button right) when try to see the disk from my computer. Ok
Sep 24, 2013 | ASUS U46E-BAL7 14in Laptop i7 2.8GHz 8GB...
Hi , seagate 1tb Expansion portable drive S/H: 2GHY01LD error in page operation plz help
Go to Start, right-click on My Computer icon and select Manage
When you go to manage, select Disk Management.
Click on Disk Management and you will notice all the disks (HDDs and any removable devices on your right column.
Click on the Seagate 1tb HDD,
(1) Note the file system
(2) Note the Status of the drive
(3) Note Fault Tolerance
(4) Then Notice the HDD if it is Basic or Dynamic
If the HDD is Basic, right click on it and create a partition.
Then move some of the Data on to the new partition to free up the old partition. Restart the computer and abserve the results...
That usually happens when the Hard Disk driver is running out of space or you have less RAM..
Aug 23, 2011 | Seagate 1TB 7200RPM 64MB CACHE...
Hi, i have a Seagate Expansion 1 TB USB 2.0 Desktop External Hard Drive and i want to backup my macintosh by using disk utility. However it seems like as i plug the hard drive in, i cannot put anything...
Hello!!
The MAC is not recognizing HDD because it may not be in FAT or MAC OS X Journeled Format.
Please Follow below steps to Reformat the HDD to make it Compatible with MAC.
1. Connect the HDD.
2. Open Disk Utility from Applications -> Utilities
3. On left side of Disk Utility you'll find your HDD.
4. Click on HDD and select the Format TAB.
5. Reformat the HDD in Mac OSX Journeled Format.
6. Click Apply.
7. Done.
P.S. : It will erase everything from your HDD so remember to backup all data before doing this.
Hope it Helps..!!
Jul 13, 2011 | Seagate (ST310005EXA101RK) 1 TB USB 20...
Hi, I have a Toshiba 80GB MK8037GSX 2.5" SATA in
1) have checked bios cannot see hdd mounted.
That is BAD -- the disk-drive could have "died".
2) tried a seagate hdd works fine so connections in laptop seem to be working
That shows that your motherboard is GOOD, but that your disk-drive is BAD.
3) can hear hardrive trying to do something as can hear harddrive usual noise, continous noise for about 5 sec before getting the error message
That is BAD -- the disk-drive is "dying".
4) no rattling or crackling noise from drive apart from the above
That is BAD -- none of the files can be read from your disk.
i have created a ubuntu boot up disk which allows me to access laptop but does shows error when locating hdd,
That is BAD.
once in ubuntu i can access internet but it does not show the windows partition of the harddrive, only shows ubuntu as opearing system, confused.
That is BAD. Only the CD/DVD disk has been mounted -- Ubuntu could not mount the disk-drive.
In regards to ubuntu working does this mean the hdd is ok?
No, it means that your motherboard is working.
and is there anyhting i can try via ubuntu to locate the files?
No. The disk-drive is "dead".
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 13, 2010 | Toshiba 80GB MK8037GSX 2.5" SATA II SATA...
Hi! I have a laptop samsung r70, in which I have recently re-installed Windows Vista. Suddenly the computer started making a weird noise just before the system collapsed. Now Im trying to re.install...
I would suggest that it is most definitely a hard ware failure most likely your hard disk drive failed do to the fact that it only makes the sound when you try to access it. All you need to do is go purchase another HDD install it and then just reinstall windows. HDD's are fairly cheep now a days and you can pick one up for 20 or 30 dollars. also attached i place a link to directions on how to change out your HDD.
http://www.ehow.com/how_4424308_replace-hard-drive-computer.html
I hope this helped.
Thank you,
Norse
May 18, 2010 | Computers & Internet
Dear Sir, my problem is as follows when i switch on my PC it says boot disk failure. so i checked the BIOS. I saw there is no Hard disk name in the list though i have attached the HDD perfectly. I have...
hi,
there are many chances of HDD boot sector gone dam.
do some work to know whats wrong--
boot your computer using another HDD and make your old HDD as a slave disk; if the old HDD is serched as a slave thats mean your HDD is fine.
for any question ask me.
Thanks for your question
Jan 03, 2009 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Installing 2 hard drive
if ur hard drive is IDE port then
attach the 1st end of ide cable to the motherboard and second end of ide cable {IDE1}to the hard disk {make this hard disk MASTER by change the jumper settings }
attach the second hard disk to ide cable {IDE 2} make this hard disk SLAVE by remove the jumper from hdd
Mar 20, 2008 | Computers & Internet
SAMSUNG IDE HDD SP0411N (40GB)
Three possible reasons:
1. Your IDE cable is defective or is not seated/plug in correctly. Try to replace or re-seat/re-insert;
2. The on-board disk management of the hard disk is corrupted/defective. There is no remedy except to replace the PCboard or the entire hard disk;
3. Your motherboard BIOS/CMOS needs to be flashed and/or something is wrong with the IDE interface.
Of the 3, # 1 is the most common.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
good luck and kind regards.
Jan 06, 2008 | Samsung (SP0411N) 40 GB Hard Drive
Hard disk problem
Change the other HDD to either Cable Select or SLAVE.
Then make sure you partition it correctly, Windows does a decent job at it.
Right click on My Computer, go to Manage, then under storage, click on Disk Management; you should see the HDD here.
Dec 09, 2007 | Toshiba (HDD2188) 80 GB Hard Drive
Samsung (SP0411N) 40 GB Hard Drive Logo
108 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
