Question about Weedeater Gas Powered Hedgetrimmer Ght225le
How do you replace the starter rope? - Weedeater Gas Powered Hedgetrimmer Ght225le
  • 718 Answers
Go to smalleng.com watch video.
Posted on Mar 24, 2011
Starter rope is broken how do i replace it
Remove the fuel tank and starter cowl, remove snapped rope.wind the pulley to put tension on the spring approx 7-8 rotations. Put a screwdriver through gaps in pulley and through a gap in top of cowl in order to stop pulley from releasing tension. Burn end of new rope and twist end with a rag while still hot to make a point at end ( careful not to burn yourself) then feed the pointed end through rope hole on outside of cowl and through the hole in side of plastic pulley. Tie a knot in the rope once its through and on inner of pulley. Fit starter handle to other end of rope.hold rope and remove screwdriver and slowly feed rope back into starter
Jun 19, 2013 | Briggs & Stratton Garden
Starter rope replacement
recoil spring has slipped out of the hole.pull your starter rope out of the wind up mechanism, insert the spring latch on both ends and put back into housing. with a piece of 3/4 square stock or something the will fit mthe hole start to wind the mechanism spring up tight. with apair vishgrips lock it down so it does not move. insert your starter rope anr release the visegrips. the springwii recoil and pull the rope in.cut off excess rope. good luck
Oct 17, 2012 | Little Wonder 6032 10 Inch Pro Lawn Edger,...
Starter cord
remove top starter assy. cut grip from old rope ease rope into spool,
when slack remove center screw and carefully pull out spool, tie knot in rope and thread into spool, wind rope [make sure correct size rope]
around spool until full,carefully turn spool into spring 1 turn then replace screw. put rope into notch on spool and wind up 3-6 turns,
replace grip
May 19, 2012 | Mantis 2-Cycle Tiller
Pull cord will not rewind
  • 1
    Turn the Homelite chainsaw so that the bar and chain are laying flat and the starter cover is facing up. Loosen the four starter cover screws by unscrewing them counterclockwise with the screwdriver.
  • 2
    Take the starter cover off of the engine. Turn the starter cover over to work on the pull starter. Pull the rope out about 6 to 8 inches.
  • 3
    Twist a loop into the end of the rope. Insert the intersection of the two ropes into the notch on the upper flange of the pulley. Rotate the loop back and forth until you notice the recoil spring has disengaged. Unwind the rope from the pulley. Cut off any old rope if you need to replace it with a new rope.
  • 4
    Unscrew the screw holding the pulley to the starter cover using the screwdriver. Take the pulley off the starter cover. Turn the pulley over and remove the recoil spring cassette from inside the pulley.
  • 5
    Inspect the spring inside the cassette to see if it is damaged or overstretched. Replace the recoil spring cassette if it is broken. Lubricate the post on the starter cover using about a dime-sized amount of engine grease.
  • 6
    Put the recoil spring cassette back into the pulley. Set the pulley onto the starter cover and tighten the screw down with the screwdriver. Wind the starter rope back around the pulley in a clockwise direction.
  • 7
    Leave about 6 to 8 inches of rope unwound. Form another loop at the end and insert the loop into the notch on the pulley. Rotate the loop back and forth until you notice the tension is set on the recoil spring.
  • 8
    Remove the loop and place the starter cover back over the engine. Pull the rope out 6 inches and tighten the starter cover's screws using the screwdriver. Release the rope and it should automatically retract
  • hope this helps
    John
    Sep 09, 2011 | Homelite Garden
    Stihl 026 Chainsaw starter rope is "stiff". When pulling the starter rope, it gets harder to pull at a couple of different places in the rope's path. Then, sometimes it doesn't go all the way...
    Sounds like the little wheel that the rope is wound on is dry. Maybe a little rusty. Open it up and squirt a little oil on all the moving parts and see what happens. I have repaired lawn mower engines by doing that.
    Oct 01, 2017 | Garden
    Need to relace starter rope
    Remove the cover from the side of the blower that contains the pull start. This usually involves removing the self-tapping screws that join the two halves of the blower housing together.
  • 2
  • Remove the broken rope from the starter pulley. Usually the rope is attached to the pulley with a simple overhand knot; just grab the knot and pull the rope back through the hole in the pulley. Sometimes the rope is attached to the pulley with a staple or some other fastener, which you'll have to remove first.
  • 3 Remove the handle from the replacement rope, if it's already attached.
  • 4 Thread the end of the rope opposite the handle through the hole in the starter pulley, working from the inside of the pulley (the side facing in toward the engine).
  • 5 Fasten the rope to the pulley. If it attaches with a knot, simply tie an overhand knot, pull it tight and trim off any excess rope sticking out of the knot. If it attaches with a fastener, replace the fastener.
  • 6 Wrap the rope counterclockwise around the pulley until the pulley is full; this usually involves one or two wraps.
  • 7 Thread the free end of the rope through the hole in the blower housing.
  • 8 Replace the blower housing and screw it in place.
  • 9 Trim off excess rope, leaving about 6 inches of rope protruding from the blower housing.
  • 10 Attach the handle to the starter rope. This typically involves threading the rope through one or two holes in the handle and securing with an overhand knot.
  • Read more: How Do I Replace a Pull String on a Hand Held Blower? ' eHow.com http://www.ehow.com/how_6920861_do-string-hand-held-blower_.html#ixzz1DKqEmA1w
    Feb 07, 2011 | Homelite Garden
    The starter rope on my 14PZ push mower broke. How
    The starter rope on my Masport push mower broke. How do I replace the rope and/or starter?
    Sep 27, 2009 | Garden
    Starter cord will not rewind after being replaced. The string will rewind in the housing before it is attached to the motor but not after being attached. How do you pre wind the springs?
    What I do is the following:
    Remove the old rope ( what is left of it)
    Wind the starter rope pulley about 8 or 9 complete revolutions after I am confident that the spring has engaged the starter pulley
    Hold the pulley in place ( align the rope hole in the pulley with hole in the starter housing
    Insert the rope and tie a knot, pull the rope back tight against the pulley
    Pull the rope all the way out and hold slight tension on the rope and release the tension on the pulley but still holding the starter housing
    Starter spring should pull rope into housing... good luck
    Sep 08, 2009 | Garden
    Lawn mower troubles
    You must first remove the cover assembly which houses the starter pulley. Pull the old rope completely out until it no longer moves. Hold the starter pulley and remove the old rope. Try to wind the starter pulley spring tighter if possible. DON'T LET GO. The starter rewind spring must be wound before installing the new rope. After winding the spring, thread the new rope through the cover and into the hole in the pulley. Tie a good knot in the end and let the rope wind slowly into the housing. Once you have this done, replace the cover, get the proper length of rope, thread it through the handle, tie a knot in this end and your ready to go.
    May 19, 2009 | Mtd 22" Yard Machine Push Mower
    Weedeater Gas Powered Hedgetrimmer Ght225le Logo
    239 people viewed this question
    Top Weedeater Garden Experts
    Jim Parker
    Jim Parker
    Morne Olivier
    Matt Olenzek
    Matt Olenzek
    Are you a Weedeater Garden Expert? Answer questions, earn points and help others
