Question about Danby D9604 Refrigerator With Ice Box
I have a Danby small fridge and it had alot of ice so I let it defrost,ice is all gone now I replugged and pressed red restart button it's clicking but does not go on it seems to try but does not stay on not cold either? help
    Sergeant:
    Champion:
  • 202 Answers
Hi.... sounds like you have a starting problem.... The start and reley is bad if the fridge is clicking
Posted on Mar 23, 2011
Testimonial: "thanks makes sense what you are saying"
Red light
Try firsd doing a complete defrost, leave fridge unplugged at least 24 hours
May 28, 2008 | Samsung RS2630SH Side by Side Refrigerator
My maytag mf12569yem0 has been icing up in the freezer section and leaking since I bought it new. Now the unit FREEZES everything in the fridge. Any suggestions?
Yes more than likely u have a bad defrost terminator in the freezer , its connected to the evaporator coils its a small round like object with 2 wires going into it. the other source may be the defrost timer itself. U can check it by locating it in ur fridge usually top middle area. under it u will see a tiny hole or slot, if u stick a small screwdriver into the slot and turn clockwise slowly till u hear a click 1 click not 2 if its stuck out of defrost, it will not go into defrost? the second click should take it out of defrost cycle. Another thing which may be wrong is ur heating element itself has gone bad u can also check it with a multi meter for continuity.
Mar 21, 2015 | Maytag Refrigerators
Not cooling in fridge,fridge temperature in freezer
Self defrost mechanism has a problem. Check the defrost timer and defrost heater element for proper operation. Ice buildup is the culprit.
If you unplug and defrost overnight, replug, it will work fine till the ice builds up again.
Nov 26, 2013 | Refrigerators
DANBY dbc657bls This is a beverage fridge by Danby Designer. I have 2 of these fridges and one is just starting to get ice build-up at the back. I have defrosted it a couple of time and the problem of...
you have a door seal leak, the ice is from outside air getting into the cooler, you might also check for an air leak it the service door in the bottom back of the cooler.
Jan 21, 2011 | Danby DWC610BL Wine Cooler
Accidental defrost
I did the same thing. I know it's a little late now but for anyone that does this again here's what to do. There's a thermostat in your actual freezer you might not be able to see it, because it might be covered in ice. It looks like a tiny tube, To stop the defrosting all you have to do is warm up the thermostat either pressing a hot towel agaisnt it or meltling the ice with a dryer (but be careful)! After a minute or so the red button should pop out again and the refrigerator will start humming again. Unplugging the refrigerator will not reset anything and don't try to pop the red button out of your own!
Feb 27, 2009 | Danby Compact Refrigerator DCR-101W
FREEZER WORKING BUT NOT THE FRIDGE
stop fridge and manually defrost it make sure all ice is gone,restart it,if the fridge then gets cold you have a problem with the defrost cycle,after defrosting you should feel air flow into the fridge,if not it could be a problem with the fan
Aug 10, 2008 | Refrigerators
Pressed a button, now fridge won't work
you have pressed the defrost button that is why the compressor stops and would not come back on. there could be a temperature sensor on the thermostat or a timer where in it would only reset back after the temperature of the fridge warms up. try to remove all the food and let is sit for a while, plugged and watch if the compressor would kick in after about two hours or untill the fridge warms up. if the button is stuck, you may have to spray lubricant in the thermostat or replace the thermostat .
Feb 21, 2008 | Danby DCR34 Compact Refrigerator
Danby D9604 Refrigerator With Ice Box Logo
1,101 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
