Question about Maytag Refrigerators
Water supply to ice maker stuck open? - Maytag Refrigerators
    Sergeant:
    Champion:
  • 202 Answers
Sounds like you need a new water valve if its stuck
Posted on Mar 23, 2011
Ice maker not getting water on new refrigerator
Check if the unit has a cold water dispenser that it will fill a cup. If so than problem is with Ice Maker. If not than problem is with water supply to unit.
If water to machine works make sure that the arm on the ice maker is in the down position. If it is up it will disable the ice making unit. Cycle the am a few times to insure that the switch connected to the arm has not gotten stuck in the off position.
On some ice makers there is a separate switch to disable the Ice maker usually right on the ice-maker not easily missed.
It is possible that the water feed tube into the Ice Maker has become frozen where it enters into the back of the freezer at the top. You can look through to see where the water fills into the cube tray. If ice is present it would be an indication that the feed tube has become frozen If suspected the safest way to fix would be to turn off the unit and allow for a manual defrost.
Next check the operation of the ice maker. Locate the arm in the up position prohibiting the ice maker from cycling. Wait three hours or more. Open freezer door and return the arm into the down position. After a few minutes you should observe the ice fingers rotating to release the cubes into the tray. If the fingers do not rotate I would suspect the ice maker or the connecting electrical circuit. Remember after dropping the arm the Ice Maker has to warm up to melt the ice cubes from the tray before the fingers are told to rotate,
If the fingers rotate then I would expect that the water supply solenoid has failed inside of the unit near to the location the the water supply is made. Replacing this part needs to be done by a qualified experienced technician.
Nov 15, 2015 | Refrigerators
Leaking pure source 2 ice and water filter
Hi-
Three things
  • Water supply valve may not be completely open.
    Open valve completely.
  • Water supply valve may be blocked by foreign material or may not be large enough.
    Supply valve must have a 1/4" opening for water to fully supply ice maker. Many self-piercing valves do not have this big of an opening. Replace water supply valve with one that has a 1/4" opening.
  • Water filter may need changing.
    If equipped with a water filter, replace filter canister or cartridge.
Hope this help
Thanks for using Fixya!
Jul 14, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice maker stopped working
run service test with volt meter hooked up to the two terminals on water valve if you get a 110 volts to water valve when it is called for and water valve dose not open then the valve is bad. make sure the water valve screen in the end of it is not stopped up.
Jun 19, 2013 | Kitchen Appliances - Others
Ice maker stopped making ice. Water line is hooked up and working. Just won't eject ice
Ice maker stopped making ice. For this problem you have check few things. First thing, is the water filling in the ice maker chamber and then ice maker not making ice? Or, the water is not filling in the ice maker chamber so it's not making ice. If the water is not filling in the ice maker chamber then it's clear that ice is not getting made due to no water in the chamber. For no water filling, the problem is either water supply valve turned off so water is not filling. Turn on the water supply and it will fill. But if the water supply is turned on then the other possibility is ice blockage in the water fill tube. There is a tube from which the water runs and enters the ice maker chamber. If this tube is blocked then water will not enter the chamber. The tube needs to be defrosted, by using hair dryer. This procedure melts the ice collected in the tube and water starts running again. But if water fill tube is completely clear and no ice blockage or any other blockage. Then other possibility is water valve at the back of ice maker unit. This water valve is for letting the water in the ice maker. The water valve open only for 7 seconds and in this time the water fills in the ice maker chamber and then water valve closes and the same procedure runs again in the next water filling cycle.------- For your information I will mention that there are two valves. One is the main valve the back of the fridge section. This main valve lets the water enter the refrigerator and other valve is at the back of ice-maker section. This other valve lets the water to enter the ice maker. In most of the cases the fault is water valve at the back of ice maker section. ------------- The other above possibilities which I gave you is water not filling in ice-maker chamber so it's not making ice. But now consider that water is filling in ice maker chamber but it's still not making ice. Then the problem is ice maker unit itself. This unit is controlled by main board. But in most cases if water is filling the ice maker but it's not making ice then its faulty ice maker unit. So see if the problem is water not entering the ice maker then the water fill tube is frosted by ice or the water valve at the back of ice maker is faulty. Replace the valve. ------------But if ice is getting made in the ice tray,but the ice is not ejecting out then there is blockage to the ice ejecting blade.May be some ice is got stuck below inside.Clear all ice frost collected under the ice chamber.And then see.---------------
You can get required parts from sears part direct online site or from repairclinic.com site.
This will help. Thanks. Helpmech.
Feb 21, 2011 | GE Refrigerators
Amana, bottom freezer, Model No. BX21TW, MFG No. P1196515W W, Serial No. 9804248558, ice cube maker water flow exceeds the capacity of the ice maker and excess water floods the ice cube tray, forming a...
Sound like your water pump is stuck open just follow the water line at the back of the fridge and you will find the pump .Change it out and you should be fine
May 26, 2017 | Refrigerators
How do i turn my ice maker off? i have a viking side by side and the ice maker is just pouring water in my freezer...its a mess!
Turn the water off under the sink where the small line starts that goes to the fridge or there may be a cut off directly behind the fridge in the supply line.
Your water inlet valve may be stuck open. It's where the water supply connects to the fridge.
Dec 11, 2009 | Viking VCSB423 Side by Side Refrigerator
Ice maker not making ice
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips and replace it if it does.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Sep 03, 2009 | Freezers
Ice maker does not trigger water supply
trigger solenoid is probably stuck shut you will haft to free up use cooking spray it is nontoxic to lube valve! Good Luck!!!
Jun 21, 2009 | Frigidaire FRS26ZSG
Ice maker only makes cubes. It will not make crushed ice.
Hi
Kindly check it could be because of following reasons :
  • Freezer may not be cold enough.
    Temperature must be 5 degrees (Fahrenheit) or colder to work properly.
  • Normal ice making capacity.
    The ice maker will produce between 2.5 to 4.0 pounds of ice a day depending on your model. Side-by-side models come with a large ice bucket and it may take up to three days to fill this container.
    Please feel free to contact for further assistance
    Thanks
    Rylee
  • Jan 24, 2009 | Maytag MSD2651 HE Side by Side...
    Side by side refrigerator
    The ice maker is not producing ice or not enough ice
     Refrigerator connected to a water supply and the supply
    shutoff valve turned on?
    Connect refrigerator to water
    supply and turn water shutoff valve fully open.
     Kink in the water source line? A kink in the line can reduce
    water flow. Straighten the water source line.
     Ice maker turned on? Make sure wire shutoff arm or switch
    (depending on model) is in the ON position.
     New installation? Wait 24 hours after ice maker installation
    for ice production to begin. Wait 72 hours for full ice
    production.
     Large amount of ice recently removed? Allow 24 hours for
    ice maker to produce more ice.
     Ice cube jammed in the ice maker ejector arm?
    Remove ice from the ejector arm with a plastic utensil.
     Reverse osmosis water filtration system connected to
    your cold water supply?
    This can decrease water pressure
    OR
    The water dispenser will not operate properly
     Freezer door closed completely? Close the door firmly. If it
    does not close completely, see “The doors will not close
    completely.”
     Is the water pressure at least 30 psi? The water pressure to
    the home determines the flow from the dispenser. See “Water
    Supply Requirements.”
     Kink in the home water source line? Straighten the water
    source line.
     New installation? Flush and fill the water system.
     Water filter installed on the refrigerator? The filter may be
    clogged or incorrectly installed.
     Is a reverse osmosis water filtration system connected to
    GOOD LUCK TO YOU!!! LET ME KNOW IF THIS SOLVED YOUR PROBLEM
    Jan 31, 2008 | Whirlpool ED2FHEXN Side by Side...
    Refrigerators Logo
    32 people viewed this question
    Top Maytag Refrigerators Experts
    John Tripp
    John Tripp
    Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
