Question about Vessel Home
Just installed a vessel sink and it leaks between the vessel and under sink.
  • 96 Answers
Use silicone to seal the flange and teflon tape on the threads that the drain flange screws onto. make sure that the sink isn't cracked. make sure that you have a washer under the rubber gasket that seals the bottom of the sink and tighten the nut against the washer snuggly.
Posted on Mar 24, 2011
I installed the sink drain with overflow and water is leaking from behind the sink and under the countertop. What did I do wrong.
a vessel I dont beleive has a overflow. you need a differant waste for that unless theres something your not telling me
Sep 03, 2011 | RTO W/ Overflow Chrome 1 5/8" Vessel Sink...
Installing a vessel sink
Standard Vanity height is approx 34.5". A vessel vanity is approx 31" high. If you cannot remove the legs from your existing vanity then it will have to be replaced or cut down to the correct height. The reason a vessel vanity is lower is because your sink will be approx 3 to 6 inches higher than a standard drop in sink. This may be more work than it is worth. Vessel sinks most often will require a solid surface top, either glass, stone or another type of composite material. The standard laminate vanity top has a particle board substrate which will detiorate quickly at the drain location.
Jul 07, 2010 | Buck 31" Granite Vanity Top for Vessel...
New Vessel sink is leaking at the spud gasket.
well if he is afraid then you take a chanel lock plier and go under the sink and titen it
Oct 02, 2009 | Magickwoods Black Glass Vessel Sink
The sink leaks at the bottom of glass sink where it connects to the piping
THE PART YOU ARE TALKING ABOUT IS CALLED DRAIN TAIL PIECE. THE DRAIN YOU CAN REMOVE BY LOSENING THE NUT UNDER THE SINK WHILE SOME ONE HOLDS THE DRAIN INSIDE THE SINK FROM TURNING THE OART KEAKING IS CALLED A SPUD GASKET WHICH SEALS THE DRAIN TO THE SINK
Aug 18, 2009 | Magickwoods Black Glass Vessel Sink
Vessel sink's drain is leaking
a waste with a over flow does not work well with a vessel sink because the sink is to thin
Jun 16, 2009 | RTO W/ Overflow Chrome 1 5/8" Vessel Sink...
No installation instructions for vessel sink
Usually silicone caulking used as an adhesive is used
May 01, 2009 | Home
Poor Draining of Vessel Sink
have the plumber pop an opening on the side of the drain pipe under the sink. and add a indoor vent.
Apr 10, 2009 | Advent KRAUS Amber Rectangular Glass...
Pegasus Push Button Vessel Sink Drain with overflow
Put plumbers putty around the flange that will be in contact with the sink. When you put it into the hole, try to line up the overflow as good as possible. The nut that goes onto the bottom (tailpiece) has a rubber gasket that will go between the nut & the sink. Adding some plumbers putty here won't hurt. After all is secure, just remove the putty that squeezed out from tightening.
Feb 21, 2009 | RTO W/ Overflow Chrome 1 5/8" Vessel Sink...
Home Logo
246 people viewed this question
Top Vessel Home Experts
john h
Tom Chichester
Are you a Vessel Home Expert? Answer questions, earn points and help others
