Video Game Consoles & Games Logo
Posted on Mar 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I try to start the Equilibris mod for Heroes of Might and Magic IV on my new pc in Windows 7, it comes up with an error saying: ...h4mod.exe is not a valid Win32 application What can I do to change that and start playing again?
STEVEN SEATON
Level 3:
Master:
  • Master 525 Answers
  • Posted on Mar 23, 2011
STEVEN SEATON
Master
Level 3:
Master:
Answers
525
Questions
0
Helped
71404
Points
1400
Right click on the game icon and select windows compatibility mode. Select xp. If it doesnt work try uninstalling and reinstalling the game. If it still doesnt work that means that it is not compatible with windows 7.
2helpful
I can't play the game Heroes 4 with Windows 7. I loaded the game. When I started the game it said " Microsft C++ Runtime library Runtime Error Abnormal Program termination " . I can play...
Run the game in compatibility mode it will help surely.
Right Click the game then choose TroubleShoot Compatibilty then click Start Program
Don't forget to click the like button
Thank You friend
How do i make heroes of might and magic v work on windows 7? I installed that game (original game not using crack or pirated version) on win7 everything installed correctly but it wont start the game i...
Try running it in compatibility mode, and if that doesn't work you could also try messing around with some other settings near compatibility mode. I had to do this for an old game called Diablo 2, but it's easy enough to do.
Find the game's launcher, either the desktop icon or the .exe file. Once you find this file, right click on it and in the menu that comes up, select the tab that says compatibility. Here, check the "run in compatibility mode for" and select Windows XP, since that is the OS that you are sure it works on. If that doesn't work, try messing with some of the options too, like the resolution and display scaling. For some odd reason, those make a difference sometimes. I remember Diablo 2 having a strange combination required to work on Windows 7 for me.
I recently picked up an older game, Heroes of Might and Magic IV get home and install. Install wizard runs fine except for one thing despite the fact it correctly identifies all my hardware, it tells me...
I have Heroes of Might and Magic 5 Running on Win 7. There were many patches to install before this title worked(on my computer). Have you installed all the available updates for it?
Here are 2 sites that have the compatibility options:
http://techpaul.wordpress.com/2009/06/28/compatibility-tricks-for-old-programs-new-machines/
http://www.sevenforums.com/tutorials/316-compatibility-mode.html
If that does not work, you can also try to set up XP mode in Win 7: (Note: you need to have Win 7 Pro, Enterprise, or Ultimate for this one) Win 7 Home Premium does not support XP Mode.
http://arstechnica.com/microsoft/reviews/2010/01/windows-xp-mode.ars/
I cant install the heroes iv might and magic it said, old file doesnt exist thx my pc is windows vista
i dont know how to play this game...........................................................................................................................
3helpful
Im trying ti install heroes 4 and it say I need 128mb of memory... i have 2 gb of memory and says it fails to meet requirements...should i look for a patch? Im using windows 7. thx for ur help
Your using Windows OS 7, which is fairly new. This is great for programs but not for games. Heroes 4 is a older game, so there are some compadablility problems.
As for your memory and HD space you should be fine since the requirements are low.
Solutions: Look for programs which allows you to run virtual OS of pervious generations of windows (such as windows xp). This should solve your problem. Otherwise if you have 2 HDD on your laptop/computer you can make one drive into a older OS. Then run the game from that HD.
Good luck, and rate my response.
Hoa can i play my heroes of might and magic iii on vista
Put the disk in your tray, the explore it, right-click the setup.exe, select properties, and run it in Windows XP SP2 compatibility mode.
11helpful
2answers
Problem s with Barbie Magic Hairstyler on Win XP
You can try running it in compatibility mode (rightclick the shortclick and select properties)
It may simply not work
Minimum Requirements
It appears the game doesn't support your memory!??
Never heard of that before...
You should check for new mainboard drivers, or maybe the memery isn't correctly inserted on the pins on your mainboard.
If that's not it, you should probably reinstall your PC. Probably a little error in some Windows library that can't be solved by rebooting...
I suppose you can play other games on that PC, right?
Good luck,
Yannick
Top Equilibris Team Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you an Equilibris Team Video Game Console and Game Expert? Answer questions, earn points and help others
