Question about Whirlpool 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice & Water - Satina Stainless-Look
I have an IKEA version of the Whirlpool side by side (2010) model. The water dispenser decides about every two weeks or so to simply stop dispensing water. After about a week or two goes by it suddenly comes back to life and works as though nothing was ever wrong. I have changed out the water valves unplugged and checked the computer, looked at he hardwired relays but have not tested them. Unplugged the refrigerator for times and plugged it back in, removed reinstalled the filter cartridge all to no avail. What could be going on here. When I push the dispenser it will send a signal to the valve, you can here it click on but no water dispensed. I swapped buttons behind the levers to see if it was a faulty switch but no change. The ice dispenser works flawlessly. I'm stumped???
  • fohveh Mar 28, 2011
    Anyone in my situation with this refrigerator I have found that IT IS ABSOLUTELY a FROZEN water line inside the door. I had gone through everything to fix this over the last four months and was going crazy. It happened yet again but this time I raised the freezer temp to its warmest setting and the spout began dripping a day or two later and runs smoothly again. Problem diagnosed correctly but bad Whirlpool design. I'm going to reroute the water line or insulate it in the door better.
  • 1073 Answers
SOURCE: GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Posted on Apr 30, 2008
sdmc73
  • 121 Answers
SOURCE: in door ice dispenser does not work but the water dispenser does.
the module on the icemaker may be bad or the emitter-recever
Posted on Nov 29, 2008
  • 56 Answers
SOURCE: ed25rfxfw01 whirlpool fridge water dispenser ...I have a slow drip from the dispenser hose. I assume I need a new water inlet valve. How do I access the inlet valve for replacing?
It should be on the right hand side in the back take off the compressor cover on the back should be 8 or so 1/4 screws nutdriver type and then two more hold on the water valve. If you have a RO system hooked up to refrig you may need to change the filters on the ro or just change the filter on the refrig. those two will also cause the water to drip thru the valve allowing it to drip on the front
Posted on May 30, 2009
Sea Breeze
  • 4655 Answers
SOURCE: whirlpool refrigerator ice dispenser no longer workds
Ok, I show parts that are available for that model, sounds like the control board is defective for your dispenser, or possibly the Ice maker control board. It also could be a break in the wiring or the control itself. Below is a break down for those parts, wiring and the control behind the push to dispense ice or water. Hope it is not that control because some places don't provide that part. Now if it's a connection problem that we can find, I will do mu best to help you solve this.Could you insure the model number is correct as this is very important? appliancepartsse@yahoo.com
Posted on Jun 05, 2009
TheMobilian
  • 8220 Answers
SOURCE: Refrigerator Ice maker stopped working after power outage
Check THIS out
Posted on Jul 26, 2009
The water dispenser on 2014 Ikea (whirlpool) refrigerator stops working at random times.
I would replace the water inlet solenoid valve, that solenoid valve is what allows water to flow on demand. The valve is likely full of mineral deposits and this causes it stick closed at times.
Oct 28, 2016 | Refrigerators
Or Whirlpool refrigerator model GS5SHAXSB00 has stopped dispensing water. What can we do?
Most times the dual water control valve is defective and you can run the simple test found HERE. Click Here for the part that fits your GS5SHAXSB00=> W10408179 Water Inlet Valve
All it takes is for either the ice maker side or the dispenser side of the water control valve to become defective and the complete water control valve will need to be replaced. I will be here should you have any questions, Thanks Sea Breeze
Here is a link to your
GS5SHAXSB00 Repair Parts List
Oct 03, 2012 | Whirlpool Refrigerators
Very slow drip from water dispenser. How do I fix
Good day,
A slow continues drip, but still dispenses O.K. is caused by the dual water valve on the bottom rear of the machine not closing completely.
Only fix is replacing the water valve assembly.
Mar 04, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I need to replace the water line tubing in the
the front dispensor panel can be removed by lookin under the panel you see too little spaces in which ti insert a screw driver,by pushing down on the top, you cantwist the screwdriver in the opening eleasing the tabs, and simply lifting off the top tabs, dependingon model you may need to un plug a wire or 2.. the tubing should be able to be removed be releasing the connector undeer the door and simply refeeding the new hose back into unit
Jan 26, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My whirlpool suddenly stopped dispensing water.
most fridges stop dispensing water when you open the door. Find the door switch and make sure fridge interior light goes on/off when you manually press door switch. This would show you that the door switch was faulty.
If the water connection to the appliance is one of those watts flood-safe water lines, it may have stuck shut. I've seen this happen when the house water pressure is too high.
Does it still make ice?
If so, then the water connection is good, and either the switch in the water dispenser has failed or the water shutoff valve for the water dispenser has gone bad.
Some models have a problem with the water line getting frozen, such that simply leaving the light on in the water dispenser compartment overnight and/or manually defrosting the unit can get it working again.
Nov 02, 2009 | Refrigerators
The water dispenser has stopped working!!!
could be a water solenoid problem (at the back portion where water from the sink enters ), or a micro switch in the dispenser area problem.
also, check if u have a water filter. could be clogged already.
tnx 4 using fixya,
drcool
Oct 09, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water dispenser not working
THERE IS A SWITCH ON THE DISPENSER BY MOVING THE LEVER WITH YOUR HAND YOU WILL NOTICE,ON OST SITUATIONS,THERE IS ABRACKAT HOLDING SWITCH.IF ITS WORKING,CHECK WATER VALVE IN ABCK OF REFRIGERATOR,
Jan 03, 2008 | Whirlpool ED2FHEXN Side by Side...
Whirlpool 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice & Water - Satina Stainless-Look Logo
282 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
