Question about Vacuums
Water container - Vacuums
  • 34 Answers
Will need your make, model, and manufacture and what the problems is to find a solution. This information will be located on the manufactures tag or by a bar code on the item.
Posted on Mar 24, 2011
Water from clean water tank is getting into soap container ???????
There is an electric solenoid that may be stuck open allowing the water to flow into the soap container.
Jan 24, 2015 | Royal Procision 7910 Carpet Extractor
How do I stop the cleaning solution from leaking water everywhere.
Clear all filters and make sure the water container is fitted properly
Jan 09, 2018 | Vacuums
I am at my daughters trying to clean her carpets and i want to know if i set it up right to shampoo her carpets . i only put water and solution in the small container in the back,but i didn't add it...
The smaller container in the back under the release handle it the cleaning solution resevoir. The larger one in the front is for the hot water. It has an internal bladder that holds clean water in this larger container, while returning the dirty to the outer bladder chamber. Both need to be filled with water at the very least in order for the machine to work. If either goes empty, the machine will stop working.
Sep 01, 2011 | Bissell ProHeat Turbo Deep Cleaner Upright...
Wear do you put the water
Inside the main tank is another container for clean water.
To fill it, lay machine all the way down. Lift handle and remove container. Take to sink, turn handle, and remove lid. Fill with hot, clean water. Replace and lock the lid. Place container back into tank and put handle down.
Sep 29, 2010 | Bissell 1699 ProHeat Clear View Upright...
I was using the upholstery attachment on my Hoover F7220900 and the water and soap container had emptied out all over my floor.
Sometimes it's to put the lid on the water and soap container so that's it's not completely sealed. This can happen due to the gasket in the cover becoming dislodged or it's also possible to screw the cap on in an uneven manner. I would check the seal inside the cap/cover and make sure that it is screwed on properly. If it isn't the container leaking, it could be a broken hose, etc. I would check the container first. Good luck!
Mar 14, 2010 | Hoover F7220900 SteamVac V2 Upright Vacuum
Sprayer is not working, but leaks water
I think you have two problems. The leaking is old seals on either the containers, or on the other end (the machine). Try replacing them. There are various part websites for these.
The problem with the spraying could be the belt that turns the pump. Check it. If it's there its probably not it. The next thing could be the little plastic tubes that go to all the componets inside the machine tend to accumulate buildup. Make sure they are all flowing free. Next try the heating element (its inside the handle area) take it apart and clean it. If all those things are checked and it still doesnt work, it might be what was wrong with mine. The all on one container that holds fresh water and dirty water has a leak. I found mine would spray correctly if i had the lid off the container, and as soon as i would put the lid back on it would stop spraying. I found out that The suction going through the container to **** the dirty water in was also putting a suction on the clean water bladder which caused the water to stop flowing out of the clean water bladder. I ended up getting an all new container with bladder because i could not get anything to seal right due to its age and warpage of the plastic. So to determine if yours is the same issue. Just take the lid off the container and then try to spray water. It may take 10 seconds to get all the tubes primed again because the suction will actually **** all the water back up to the container. If you dont want to replace the container, just spray a few passes with the lid off, then put the lid back on to **** the water back up. Hope this helps. I might not write clearly for everyone to understand, but i hope it helps someone.
Mar 01, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
I HAVE A HOOVER STEAMVAC DELUXE 1500, HOW DO I PUT THE CLEANER IN AND WHAT PART
I have the same series - The steamvac deluxe 1500 has two containers, one that is on top is for putting the cleaning solution/water in and the bottom container pulls up the residue/dirt. The top container has a nozzle that you twist out, you put the water in until it reaches the line which is 3/4's up the way. You then measure the nozzle (it has two lines) and put the cleaning solution in there and then into the water.
Hope this answer's your question.
Jul 15, 2008 | Hoover Vacuums
Hoover Steam Vac Dual Rinse Model F7205-910
MOST COMMON PROBLEM IS THE ATTACHEMENT VALVE IS BROKEN WHERE YOU CONNECT FOR WATER ON SIDE OF MACHINE. THESE MODELS USE AN ELECRONIC SOLONOID TO ACTIVATE WATER TO NOZZLE IF IT IS COMING OUT THERE SOLONOID MAY BE BAD
Mar 27, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Vacuums Logo
14 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
