Question about Libec Photography
High hat for Libec T98C
I'm looking for a high hat to go with my Libec T98C. Any recommendations?
    Problem Solver:
  • 7 Answers
Try the site www.transfilm.com they are a repair facility and reseller of used equipment and might have what you are looking for.
Posted on Aug 04, 2008
How can I replace the quick release head for the libec th659dv tripod. A student has lost the plate but UK retailers do not seem to stock libec replacements.
Try a plate from another tripod. I have three different tripods, and the quick-release plates are all interchangeable.
Jul 08, 2015 | Libec Photography
Yamaha dd55c hi hat foot pedal not working
This could be caused by a number of things.
1) Socket on DD55 could be broken
2) Cable could be broken
3) Plug at end of cable could be broken
4) Switch in foot unit could be broken
Eliminate each by working through 1 - 4 using a multimeter and then repair accordingly once you have found the fault.
Jun 30, 2014 | Yamaha DD55C 7-Pad General MIDI Digital...
I have a round face. What hat will suit my face shape best?
If you have a round face, you should choose hats that have a wide brim and a high crown as they will help give proportion to your face
Mar 04, 2013 | Clothing Accessories
I am going to buy an electronic keyboard for my kids, maybe with a drum set etc too. Are there any makes that people can recommend that I look for?
I always buy Yamaha or Casio when it comes to electronic keyboards for kids. I think their products are well made but also are more affordable than some of the more professionally aimed products.
Feb 25, 2013 | Toys
My 185 ingersol compressor runs fine for 30-45 minutes, then it cuts off. If I wait 10-15 min it will crank and run for 3-5 minutes then shut off. I have all new fuel filters. What do you thibk could be...
From your description I think you are shutting down on high air end temperature. I recommend the following, Check the oil cooler. you want to make sure you are getting good air flow thru it. If not wash it with a pressure washer. I like to use my flash lite to check and make sure I can see thru it. dont look just at the middle check around the sides. If cooler is OK next check the amont valve (thermostat valve). This valve mixes oil from the cooler and bypass to get the temperature where it needs to be so condensate does not form in the oil. Next you may have a bad HAT switch which is located on the end of the air end. If you have a meter see if the switch opens when you have the shut down. you will need to make sure you really don't have a high temp situation. If the temp is high 228 F or higher the switch is doing its job. The temp limit should be located on the HAT switch. It could be 215,245 etc. If the unit is not hot and the switch opens replace the switch. Hope this helps you with your compressor problem.
Aug 02, 2011 | Ingersoll Air Tools & Compressors
We have an Ingersoll Rand- 100hp air compressor. We only run this periodically- when we have a power curtailment and trying to reduce power consumption or if our primary air compressor faults out. When...
replace the hat switch. hat = High Air temp. This switch is located on the end of the air end and usually has 1/2" flex conduit on it. Remove the conduit. It goes to a box located on the frame near and under the airend. Remove the cover from the box tug on the wires at the hat switch to see which two wires need to be disconnected.disconnect wires unscrew hat switch. Put a new oring on the new hat switch and install new hat switch. Hat switch is the only switch that will give high temp and lose control power. Let set a while and can reset unless probe is broken off.
May 31, 2011 | Ingersoll Rand Stationary Air Cooled...
Libec THM20
The leg is slightly off the track, which is a curved piece which fits along the tripod support rail. If you're not careful when collapsing the legs you'll force the leg to go off-track like this.
Sep 07, 2007 | Libec ST30 Tripod
Libec T58 Tripod
I had a Porter-Cable that I was able to repair using three small pieces of lexan and a bandsaw. I took off one of the latches that were good and traced the pattern on the lexan and sawed out the handles. Cleaned them up with sandpaper andthen stacked them and drilled out the holes. Then I drilled two more holes for clearance for two 6-32 machine screws and nuts. Put the whole thing together and installed it - still working after four years.
Aug 21, 2007 | Libec LS-55 Aluminum Tripod System -...
Photography Logo
151 people viewed this question
Top Libec Photography Experts
pontelemon
pontelemon
Tony
Are you a Libec Photography Expert? Answer questions, earn points and help others
