Question about AT&T 1717 Digital Answering Machine
It comes on on the first ring and I want to set it so it comes on after 4 rings. I need a manual
  • 449 Answers
Here is the manual
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000017395.pdf
Press and hold SET UP for two seconds,
press annc/skip or memo/repeat until the number of rings you want is announced, and then press play/stop to exit.
Posted on Mar 23, 2011
Panasonic KX-T7668 handsets. How to make different extensions ring / not ring on an in-coming call.
The first thing to check is the total "Ring Equivalent Number" or "REN". This is a maximum number that your line will support. For example if the line REN maximum is 4, then it will support 4 phones with a REN of 1 (4x1=4). If, however, you have 3 phones with a REN of 1.5 each then it won't work (3x1.5=4.5). It may work on 2 of them and not the 3rd one, but equally it may work on one or none at all.
The REN is usually on a label on the phone or in the manual, but the line REN is set by your supplier and you will need to contact them for that number.
Jan 24, 2016 | Lands Phones
Hooking up fax to KX TG7871 Panasonic Phone
There is excellent support here on basic fax setups. You have what is known as "Distinctive Ringing Service". There are pros and cons to the various setups. I assume you recognize the rings and answer only when the ring for the landline talk comes on. The fax will pick up the faxes, and the answering machine will pick up the voice.
Need model number of your fax - google that!
Service manual for your phone.
http://service.us.panasonic.com/OPERMANPDF/KXTG7841-MUL.PDF
This link shows various configurations of setting up your phone/fax/answering machine or using an answering service.
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c00059780#Dist_ring
Distinctive Ringing Service setup While it is not available everywhere, a distinctive ringing service can be purchased from most telephone companies. With this service, more than one phone number is assigned to the same phone line. Each phone number will ring differently. The main number will ring with a normal single ring and the additional number will ring with a distinctive ring pattern assigned by the phone company.
When a distinctive ringing service is used, set the Rings to Answer to 2 and then follow the steps below to set the distinctive ringing pattern:
  1. Press Setup , press 4 , and then press 1 to enter the Answer Ring Pattern setup of the Advanced Fax settings.
  2. Use the Right Arrow to scroll through the available settings. When the ring pattern assigned by the phone company displays (double or triple rings), press OK .
Mar 06, 2014 | Lands Phones
I need to reset the amount of rings before my answering machine comesd on,it;s model# 1719
Press and hold [SET UP] until the system announces "Number of rings is..." Press and release [ANNC/SKIP] or [MEMO/REPEAT] until the system announces the desired number of rings. Press [PLAY/STOP] to exit. Full details are on page 2 of the manual.
Jun 10, 2012 | AT&T 1719 Digital Answering Machine
I can not locate how to limit the number of rings; and the answering machine does not come on even after 20 rings; I can hear my message recording- when I play it back; but it does not come on for incoming...
Ring count You can change the number of times the phone rings before the unit answers calls. The default setting is "4 rings". "Toll saver": The unit answers on the 2nd ring when new messages have been recorded, and on the 4th ring when there are no new messages. If you call your phone from outside to listen to new messages, you will know that there are no new messages when the phone rings for the 3rd time. You can then hang up without being charged for the call.
1 {MENU} 2 {V}/{^}: "Answering device" i {OK} 3 {V}/{^}: "Settings" i {OK} 4 {V}/{^}: "Ring count" i {OK} 5 {V}/{^}: Select the desired setting. 6 {OK} i {OFF}
MANUAL http://service.us.panasonic.com/OPERMANPDF/KXTG1032.pdf
HOPE IT HELPS GILES102
Jun 27, 2011 | Panasonic KX-TG1033S Cordless Phone
Would like to increase number of rings before answering machine comes on.
Setting the Number of Rings (Excerpt from the Uniden Dect 1580 Phone manual
The ring time setting allows you to set the number of rings the caller hears before your answering system plays the outgoing message. You can set the ring time to answer after two, four, or six rings. If you enable the Toll Saver (TS) setting, the answering system picks up after two rings if you have new messages, and after four rings if there are
none. This way, if you make a long distance call to check your messages, you can hang up after the third ring to avoid long distance billing charges.
  1. Press Menu/Select.
  2. Select the Ans. Setup menu, and then the Ring Time submenu.
  3. Move the cursor to select a ring time (Toll Saver, 2 Times, 4 Times, or 6 Times).
  4. Press Menu/Select. You will hear a confirmation tone.
Feb 02, 2010 | Uniden DECT 6.0 Cordless Phone ID
Change number of rings
There is a switch on the back(IE:TS(Toll Saver, 2 or 4 rings)
Apr 01, 2009 | Casio Lands Phones
Group forwarding after a delay
In memory block 4-1 for the extension's port, The Lkey for the CO line is lit green for immediate ringing, red for delayed ringing, and off for no ringing.
In memory block 1-1-77 you enter the CO's delayed ringing timer in seconds.
I wouldn't try and deal with seperating into tenants.
What I would suggest is in 4-19 restrict outbound trunk access (corresponding Lkey for CO line is lit to restrict)
For example:
Stations 1-4 would not be allowed to dial out on CO lines 5-6
Stations 5-6 would not be allowed to dial out on CO lines 1-4
This way Company A is not tying up Company B's CO lines for outbound calls and vice-versa.
Apr 09, 2008 | NEC Electra Professional ETW-16DC-2
How to program a line to ring keysets
Not sure if I understand your question correctly, but I think I just learned how to do that on an electra professional. Memory block 4-1-1 lets you go through each of the internal extensions, and you can set each extension to ring when a call comes in from any/some/all of the outside lines.
to reach memory block 4-1-1, I used a multi line terminal connected to ports 1. Press fnc => hold => # => 0 => * => line key 4. Use the fcn(?) key to cycle through the internal ports, the line key buttons to map each of the 4 lines (presumably line keys 1 through 4 on your system).
As to where to get a manual, I am not sure, I have 3 thick binders... good luck
Apr 08, 2008 | NEC Electra Professional ETW-16DC-2
Fax
This si str8 from the manual! The Ring Delay sets the number of times the MFC rings before it answers in Fax Only or Fax/Tel mode. If you have extension phones on the same line as the MFC or subscribe to the telephone company?s Distinctive Ring service, keep the Ring Delay setting of 4. 1 If it is not illuminated in green, press (Fax). 2 Press Menu/Set, 2, 1, 1. 3 Press ▲ or ▼ to select how many times the line rings before the MFC answers (00, 01, 02, 03 or 04). Press Menu/Set. (If you select 00, the line won?t ring at all.) 4 Press Stop/Exit. Full Manual URL http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000219/MFC-210C_UsaEngUsr_B.pdf Hope this helps! Regards, Babb
Apr 28, 2007 | Brother MFC 420CN All-In-One InkJet...
AT&T 1717 Digital Answering Machine Logo
310 people viewed this question
Top AT&T Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
