Question about LG GD510 Cell Phone
Hello, i activate my alarm on the gd510, and at the mentioned hour the phone only shows the alarm message on the display but it does not ring
You have to activate the alarm tone
Posted on Mar 24, 2011
Accidently activated the alarm clock on Gigaset phone A400/A400A and now I cant work out how to deactivate it. Sorry cant understand manual it doesn't seem very clear to me. I am a 67 year old pensioner so...
Hello
This tells you how to set it, but not how to turn it off, so my guess is that once set, and the alarm goes off, it is then turned off. Or, there is a toggle on it, so press OK to Set, and OK again to Disable. The sequence is
Menu ₪ Alarm Clock ₪ OK ₪ Activation ₪ OK and I reckon OK a second time to switch OFF
Setting the alarm clock
Activating/deactivating the alarm clock
Menu
Alarm Clock
OK
Activation
OK
= activated)
If activated
Enter wake-up time
OK
When the alarm clock rings, press any key to switch it off for 24
hours. If the alarm clock is set, the wake-up icon will appear on the screen and the wake-up time will be displayed instead of the date.Entering/changing the wake-up time
Menu
Alarm Clock
OK
Wakeup time
OK
Enter the wake-up time in hours and minutes, then press
OK
. The alarm clock is automatically activated after the wake-up time is entered/changed.
It is easier to read on Page12 of the manual.
Good luck
Andrew, age 65 (almost)
http://gse.gigaset.com/fileadmin/legacy-assets/A31008-M2201-L101-2-7619_en_UK.pdf
Dec 10, 2017 | Lands Phones
Cannot fax message ringing
Hello sir; try to replace another phone cable should be tak care your problem, good luck
Nov 01, 2012 | Epson Office Equipment & Supplies
My cim card is replaced at 11.30 today i.e 11.10.2011 but not still activated what is the problem? what is a standard time for the activation?
Sometimes it could take longer than 24 hours to activate a simcard. Call your service provider to be sure of the status of your account.
Oct 11, 2011 | LG GD510 Cell Phone
I do not know how to set the alarm for my Sangean RCR-1 alarm clock.
Alarm settings can be made with clock/radio on or off.
The Alarm Clock/Radio is equipped with two independent alarm
systems each of which can activate the Human Wake System Buzzer
or turn on a preselected radio station.
Using Alarm with a Preselected Radio Station:
Select desired station using + or - Tuning Button [18] or select one
of the 1-7 presets.
Set the desired volume level using Alarm Level Adjustment [9]
Select alarm system 1 or 2 by pressing the alarm button [14] or [15].
Display will blink with selected alarm
Press alarm set button [16]
Display will blink showing selected alarm hour and alarm mode
and beep
Press alarm Mode button [20] to select alarm mode
Use + or - button [18] to set alarm time hours.
Press set button [16] to set minutes using + or - button to
set minutes.
Press alarm days selections 1-7 (Sunday-Saturday) to select
alarm days.
Display will show the days on which you wish to be awoken by the
radio alarm.
Pressing alarm button 1 or 2 will confirm settings and a beep and
display indicates radio alarm is set.
Note:
If alarm days or alarm mode are not selected display will blink
all the days for a few seconds indicating the alarm is not set
and the alarm will not be activated.
If you would like to be awoken to the station you are presently
listening to press alarm button 1 or 2 for more then 2 seconds.
This allows the station you are listening to be stored into
memory. Then follow above procedures.
Using Alarm with HWS Alarm Beep:
Display will blink with selected alarm Press alarm set button [16]
and beep
set minutes
alarm days.
buzzer humane alarm
display indicates buzzer humane alarm is set.
Note:
Cancelling Alarm Setting:
Alarm functions can be cancelled:
and beep
Press alarm Mode button [20] one or two times (depending if you
were in the alarm radio or alarm buzzer mode) till display blinks.
Press alarm 1 or 2 button again to confirm alarm cancellation.
The symbol will stay on the display for about 2 seconds
and disappear.
You may also select days you wish to be or not to be woken after
pressing the Set button while display is blinking. Press 1-7
(Sunday-Saturday) of button [19] to make a selection.
This is the figure of your device and you can find which button where is:
Thanks.
gylacz
Jun 10, 2011 | Sangean RCR-1 Clock Radio
When i open my gallery and my stuff the display show the message "maximum limit of application reached"
Try this...
Shutdown your phone;
Get the sd card out,restart the phone,shutdown again,put the card in ,and restart again.
I believe this message will not show again.("maximum limit of application reached").
Nov 25, 2010 | LG GD510 Cell Phone
I have a Uni-com wireless doorbell, model 55075/SC352R. I would like instructions as I'm not finding it easy to reset things and have inadvertantly set the alarm and don't know how to turn it off!
With the display in normal mode showing the time, date and temperature and with the double dots flashing each second, press the MODE button. The first press will give you the option for setting 12 or 24 hours on the time display. The second press should bring up the setting for the alarm time. Press the SET button once and it flashes the hour for the alarm. Press it again and the minutes for the alarm will show. Pressing the SET button a third time lets you set the number for each musical tone choices for the alarm. A fourth press will ' set' the alarm so the alarm time will show, plus the number representing the ring tone you selected below the alarm time. Normally what you would do next is press MODE again 3 times to return to the ordinary time display. But if you want the alarm off, instead of doing this, press SET a fifth time and this will set the alarm time to 'off' and the display for the alarm will show '-:--' now press MODE 3 times or until you see the ordinary time display with the double dots flashing. You can check the alarm is off by pressing the ALARM button - it should still show '-:--'. The ALARM button is only for showing the alarm time which has been set, not for actually doing the setting. A quicker way, starting from the normal display with the seconds flashing on the time, is to just press the ALARM button once, then press SET 5 times then MODE 3 times.
Aug 27, 2010 | Vacuums
I cant find the manual so I dont remember how to set the weekday alarm. Also can you show a picture of what the display should look like when the alarm is set? Or describe it? Thank you.
Press the Alarm button. The weekday alarm symbol will appear. Then press and hold the Alarm button for 2 seconds to enter the set mode (the hour will blink). Use the up/down buttons to choose the hour for the alarm (note the A.M./P.M. if in 12 hour mode). Press Alarm again and the minute will blink. Again use the up/down arrows to set the desired time. Press Alarm once more to exit the set mode.
To activate or deactivate the alarm, press the Alarm button until the weekday alarm icon appears. Then use the up/down arrows to activate or deactivate the alarm. When the alarm is set and active, the time will show. If the alarm has been deactivated, then dashes will appear instead of the time.
The single alarm is set and checked similarly.
I hope this helps.
(I suspect that the weekday alarm icon continues to display when the alarm is active.)
Aug 25, 2010 | SkyScan 31983 Clock Radio
How to turn off hourly alarm on Gap Sport watch?
Click reset button (lower right) - this shows you the alarm time as indicated by a large letter 'A' that appears in the display.
Keep holding the reset button and simultaneously press the mode (lower left) button.
This toggles the days of the week at the top of the display.
All days shaded in black means the hourly alarm is on.
All days clear means the hourly alarms is off.
Now, if I could just figure out how to choose the exact days the alarm can be set to ring ... it seems like it is possible.
Aug 16, 2009 | Watches
PHONE WILL NOT RING
Hi it sounds like your problem is that the call diverts are set to divert all calls what you need to do is goto settings then goto call settings then look for call divert settings what you need to do is cancel all diverts and then go through them one by one and just
activate divert if off (activating this one goes to ans phn if phn off
activate divert if busy ( goes to ans phn if your on phone call)
activate divert if out of reach (goes to ans phn if no signal)
After doing these settings then your phone should ring when someone calls you.
Before you activate any divert setting select cancel all diverts then get someone to ring you and make sure phone rings the screen will now display whos callind and the phone should also ring.
Let me know if you need further assistance ok let me know how you get on
Feb 15, 2008 | Pantech C120 Cellular Phone
LG GD510 Cell Phone Logo
42 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
