Question about Epson Stylus NX400 InkJet Printer
How do you get an Epson Stylus NX410 out of copy mode?
    Scholar:
  • 52 Answers
The NX400 will automatically go into Scan or Print mode from software. So if you want to scan, launching the Epson Scan software will control the scan functions. Similarly, printing from any application will cause the NX400 to go into Print mode. Copy Mode is the only mode you control from the printer device itself.
Hope this helps.
Posted on Mar 23, 2011
4 Suggested Answers
SOURCE: I cannot get my epson stylus nx410 CD to load my
Epson does not make a NX410, They only make a NX400 and NX415.
Check the back of the printer for the exact model number. If when you check you it is for some strange reason it is a NX410. I would try one of the drivers from the NX4000 or NX415 as drivers for printers typically don't vary too much between similar models and may provide a good temporary fix to your problem.
You can also call epson US (562) 276-4382 6am to 6pm PST mon-fri
Driver link to NX400
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Overview&oid=106004&prodoid=63075469
Driver link to NX415
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Overview&oid=128287&prodoid=63083741
Posted on Jan 08, 2010
SOURCE: Scan without replacing print cartridges on Epson Stylus NX410?
You actually can scan documents when you dont have ink. Instead you will have to activate the scan function from the epson driver/program instead of pressing the scan button directly on the printer. I had the same problem and it took a while to figure out.
Posted on Jun 30, 2010
  • 75 Answers
SOURCE: Have an Epson Stylus NX410
its on the epson scan software s35
Posted on Oct 05, 2011
How to change ink cartridge in epson nx215
1. Turn on your Epson printer. 2. If a cartridge is expended, you see a message on the printer's LCD display screen. The icon on the screen indicates which color to replace. Press ink.13.7.1.jpg Start (NX210 Series) or OK (NX410 Series). If you're replacing a cartridge before you see a message on the printer's LCD display screen, do one of the following: NX210 Series: Hold down the Scan button as you press the Index Sheet button, then release the buttons. Press ink.13.7.2.jpg or ink.13.7.3.jpg to select Ink Cartridge Replacement, then press ink.13.7.4.jpg Start. NX410 Series: Press Setup, press ink.13.7.5.jpg or ink.13.7.6.jpg to select Maintenance, and press OK. Then select Change Ink Cartridge and press OK. 3. Open the scanner. Note:
Your printer model may vary from the ones shown in this section, but the procedures are the same. ink.13.7.7.jpg Note:
Do not touch the white cable inside your printer.
Do not open the ink cartridge cover while the print head is moving. ink.13.7.8.jpg 4. Open the cartridge cover. ink.13.7.9.jpg 5. Squeeze the tab on the cartridge and lift the cartridge straight up to remove it. Dispose of it carefully. Do not take the used cartridge apart or try to refill it. ink.13.7.10.jpg Warning:
If ink gets on your hands, wash them thoroughly with soap and water. If ink gets into your eyes, flush them immediately with water. Keep ink cartridges out of the reach of children. 6. Before opening the new cartridge package, shake it four or five times. (Do not shake a cartridge after opening the package; ink may leak.) ink.13.7.11.jpg 7. Remove the cartridge from the package, but be careful not to touch the green chip on the cartridge. ink.13.7.12.jpg 8. Remove the yellow tape from the bottom of the cartridge. Caution:
Do not remove any other labels or seals, or ink will leak. ink.13.7.13.jpg 9. Insert the new cartridge into the holder and push it down until it clicks into place. ink.13.7.14.jpg 10. Once you replace all the necessary cartridges, close the cartridge cover and push it down until it clicks into place. ink.13.7.15.jpg 11. Lower the scanner. ink.13.7.16.jpg 12. Press ink.13.7.17.jpg Start (NX210 Series) or OK (NX410 Series) to begin charging the ink. This takes about 2 minutes. When you see a completion message on the LCD display screen, ink charging is finished. If you continue to see an ink replacement message on the LCD display screen, Press ink.13.7.18.jpg Start (NX210 Series) or OK (NX410 Series) and press down all the cartridges securely. Then press ink.13.7.19.jpg Start (NX210 Series) or OK (NX410 Series) again. Note:
If you replaced a cartridge while copying a document or photo, cancel printing and make sure your original is still placed correctly on the document table. Then copy your original again. Caution:
Never turn off your Epson printer while ink is charging or you'll waste ink.
(Taken from the Epson online manual available here)
Oct 16, 2012 | Epson Stylus Multifunction Inkjet Printer/...
Feb 19, 2010 | Epson Office Equipment & Supplies
Epson Stylus NX410 won't print in Adobe Illustrator CS
Try to print your file in jpeg or tiff format.Good luck!
Jan 12, 2010 | Epson Office Equipment & Supplies
I cannot get my epson stylus nx410 CD to load my driver. Went to epson centre no listing for printer
Jan 08, 2010 | Epson Stylus NX400 InkJet Printer
We are trying to install an Epson NX410 on a HP dv6-1362 running Windows 7 Home addition but can not get it to install. The HP will only see the scanner. We could install the Epson NX410 on a white box...
hi there..
if you are downloading the combo package driver, and your having an issue. thats normal. combo package driver of epson usually have issues, so they suggest to download the driver separately. since you already download the scanner, download the driver and make sure that you select the right driver, because there are 2 types of windows 7, 32bit and 64 bit, if you are downloading 32 and you have 64, it wont work and vice versa, so double check.
download the driver from this link according to your os.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=128287&prodoid=63083741&BV_UseBVCookie=yes&infoType=Downloads&platform=Windows&x=26&y=10
pls come back and give me a vote. I would really appreciate that,thanks in advance. good luck.
Dec 08, 2009 | Epson Stylus NX400 InkJet Printer
I cannot get my epson stylus nx410 CD to load on my computer
hi there this is the set of instruction on how you can install the cd on your computer
http://files.support.epson.com/pdf/nx410_/nx410_bb.pdf
hope this 1 will help
Nov 28, 2009 | Epson Stylus NX400 InkJet Printer
Epson Stylus NX400 InkJet Printer Logo
444 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
