Question about Home
I have a Royal Whirlpool bathtub. After I fill the tub with water, I push the button for the jets to start and the jets only work while i am pushing the button. The button is a air button. Feels like I am pushing air into the motor. As sonn as the button is depressed all the way the jets stop. It used to work fine and now just stopped working? any advice?
  • 96 Answers
You have a bad neumatic switch. Or a small hole in the air line. Try pushing the button fast and hard to see if it will stay on. if so , it is a hole in the tube. if not it is your neumatic switch
Posted on Mar 24, 2011
Testimonial: "perfect! Thanks for your help"
We do not use our tub that often, but when we press the button it does not connect.
Air Tub - Air Jet Bath - Tubz.com
www.tubz.com/air_bath-air_tub.htm
It is not the sound of the pump that you here but a "bubbling & popping sound" that ...The air blown through the tub is warm, but it can feel cool on the skin. ... Quieter than awhirlpool or air bath, it can help relax both your mind and body. ... In the lines wecarry it is difficult to hear the motor over the sound of water movement ...
CG AIR - Whirlpool system
www.cgair.com/service_faq_tourbillon.aspx
Often, we already have the answer to your questions. ... Can the whirlpool pump be installed anywhere other than beneath the bathtub. ... The whirlpool system does notstart and a light flashes 3 times on the keypad. ... Fill the bathtub with warm water. 2.... I press on the air push button but the system does not turn on or off.
Dec 22, 2015 | Home
How do you install a new on/off switch in a royal whirlpool bath?
The switch is located on the back of the pump. If you have access to the pump and you can see the tube coming out of the black box on top of the pump you might have a chance of changing it without pulling the tub, If you do not have access to the pump, one will have to be made or pull the tub for repairs. If the pump can be removed this might also make the repair go easier. The switch is available at most pool or spa stores. If you are uncertain about doing this repair call a Jacuzzi certified repair technician to do the job.
Jul 06, 2014 | Whirlpool ROYAL BRB826 Corner Tub, Jacuzzi...
American standard jet bath tub black particles coming out of jets
The problem you are experiencing is common to many jetted bathtubs.It is a result of dried bathing water in the tub. There are a couple of solutions to resolve this ongoing problem.
  1. Use your tub more frequently as the water will not have time to fester in the pipes.
  2. Use a cleaning solution made for cleaning the pipes on jetted bathtubs once every three months.
You find Cleaning and Maintenance Products for jetted tubs at the following website. US Parts Center
Rod
US Parts Center
888-521-6183
Feb 25, 2013 | American Standard Evolution Oval Comfort...
Lasko pump motor in jetted tub comes on when switch is turned on but doesn't pump any water from jets. Unit has been used very little and is about 8 years old. Is there any such thing as priming these...
you can check to make sure there is water to the front of the pump. What they use on their tubs is called flooded suction pump i.e. there has to be enough water to the front of the pump end to **** it through and push it up and out of the wet end.
fill your tub up and loosen the discharge union on the top of the pump until water starts to come out, quickly tighten the union back down and then see if you can get the pump to start pushing water.
Dec 31, 2010 | Jacuzzi 8450-959 Tara Whirlpool Bath 5'-...
Jets don't work in the jetted tub.
First the obvious, most are electrically connected to a ground fault device, ether an outlet or a breaker. BEFORE ADDING WATER, check these out to make sure they are not tripped. Most all tubs have a minimum water level which must be reached before the jets will operate. This is usually a piece of trim located above the depth of the jets. Make sure the tub is filled to cover this part. If you cant identify the water level device fill the tub so that all the jets are covered by an inch or 2. Some tubs have push button switches or touch pads to control the motor, some have touch sensitive trim. There may be some sort of medallion from the maker on the tub, simply touching it will start the tub. Once you get it going most tubs have a built in timer that turns off the pump in 15 - 20 minutes. For more tub time just hit the switch again but keep in mind that extended exposure in a hot tub can mess with your blood pressure and cause you to loose balance or pass out, hence the 20 minute timer.
Mar 22, 2010 | Whirlpool Safety Bath Walk In Bathtub -...
Only used my Royal whirlpool bathtub about three times
My jetted tub will not work, and it used to work just fine. Nothing happens when i push the button to turn it on. Could this be a switch problem? Also do not hear the motor doing anything when button is pushed. Dou you think I just need to get a new pump??
Dec 30, 2009 | Home
My bathtub jacuzzi wont work. I reset the circuit breakers but nothing. I filled the tub but nothing comes out of the jets
make sure you have power to outlet that motor is plugged into,if so try pushing jet button in tub about ten times in a row quickly then on tenth push use as much force as possible and hold.if this does not work,air hose from back of button to pump motor may be disconnected.
Sep 30, 2009 | Maax URBAN 6032 HYDROFEEL AEROFEEL BATHTUB...
Bathtub jets will not start
Our reset for the jets were hidden in the master closet behind the tub. We also found another access point to the tubs inner workings in the same place. Also, make sure they open all the air intakes and the tub is filled prior to testing. On ours if water is not above a certain level it won't come on.
Aug 02, 2009 | Home
How do I use my Whirlpool bath?
youneed to make sure that the switch is on first .their should be a switch for the tub on the wall somewhere.find the switch than push the button on the tub,also make sure that their is water in the tub that is past the jets before pushing the button on the tub.
Feb 07, 2009 | Whirlpool Home
Home Logo
263 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
