Question about Car Audio & Video
I have a 2005 Chevrolet Venture van and the CD changer has stopped working. I am unable to eject the CD's or play them. The radio and the rear entertainment dvd player still works.
I would take the cd player apart to get your disc and just replace the deck itself. That goes for your speakers if they nedd to be replaced. I have a town and country van which i have a system in so if ya need any help just let me know.
Posted on Mar 23, 2011
OEM CD player is stuck
have you tried disconnecting the battery cables? if this does not work, a CD may be stuck in it! You will have to remove the changer and open it up to remove the cd!
Aug 15, 2012 | 2005 Chevrolet Equinox
My 2005 Chevy Malibu's 6 CD changer will not play CD's, and will not eject them either. When I press the eject button it appears to try and eject as I hear movement but after a short bit of clicks I get a...
Extreme heat can cause warping and the cd will not evenly eject or exit the slot. the player may have to be removed and the cd physically extracted from the player. Delco players have a lot of plastic cogs, flywheels and gears in them that get old and crack or split. Hence, the player can no longer spit out the CD.
Jul 26, 2017 | 2005 Chevrolet Malibu
Cd player is not reading cds what can i do to repair it.
Subject: Radio With Six Disc CD Changer Does Not Recognize Loaded CD And Displays An "INITIALIZING" Message, CD Will Not Play, CD Cannot Be Ejected, Or Disc Icon Does Not Illuminate (Reprogram Radio)
Models:
2005-2006 Chevrolet Avalanche, Suburban, Tahoe
2005-2007 Chevrolet Colorado, Express, Silverado Classic, TrailBlazer
2005-2006 GMC Yukon, Yukon XL
2005-2007 GMC Canyon, Envoy, Savana, Sierra Classic
2005-2006 HUMMER H2 with Six Disc CD Changer Equipped Audio System (RPO UC6)
Condition
Some customers may comment on any of the following conditions:
• The CD loaded in the radio will not play.
• The CD loaded in the radio will not eject.
• The disc icon on the radio will not illuminate.
• The radio displays an "INITIALIZING" message for approximately 30 seconds after vehicle start up.
Important: Do not attempt to play CDs with paper labels on them in this CD player. The labels may warp or wrinkle and jam the CD player mechanism. Refer to the Compact Disc Care and Cleaning procedure (Document ID# 1656123) in SI for more information.
Technicians are to reprogram the radio with new operating software using the following procedure:
1. If the radio has a CD(s)2008 General will be necessary to reset the radio and remove them
before the radio is reprogrammed. Remove and reinstall the radio fuse to reset the radio and then eject the CD(s). If cycling the power to the radio does not allow the CD(s) to be removed, the radio may have another failure that will not be corrected by the reprogramming procedure that follows. Refer to the Diagnostic Starting Point - Entertainment procedure in SI to begin your diagnosis of this failure to eject CDs concern before reprogramming the radio.
2. Reprogram the radio using the Service Programming System (SPS) with the latest software available on TIS2WEB. Refer to the SPS procedures and the Radio Programming and Set procedure in SI for more information. As always make sure your Tech 2® is updated with the latest software version.
3. Verify proper operation of the radio and make sure that all CDs can be ejected.
Hope helps (remember to rate this).
Oct 03, 2010 | 2005 Chevrolet Trailblazer Ext
2005 XTerra w/Roxford Fosgate stereo 6CD changer, unable to eject CDs,does not go into CD mode ,load or eject also reads "No CDs"
Hello and thank you for using FixYa!
There is some internal issues with your radio. The radio will need to be sent out for repair to correct this. Here is a place that can do it for you.c54c949.jpg
Thanks Jay!
Jul 14, 2009 | 2005 Nissan Pathfinder
2005 350Z 6 disc changer / error message
Use a Laser Lens Cleaner. Run it thru the player a couple times. Use one that has fluid with it, you can find them at any electronics retailer for 15-20. If it still has the same problem, the only thing to do is send it for repair, they will replace the transport. Average cost of 125-175 on a changer. Hope this helps
Jul 01, 2009 | Bose 3·2·1 II System
CDC-3 magazine will not eject nor play, error on receiver indicates magazine error
1998 porchea boxter cdc-3 cd changer, The cd changer keeps on changing tracks as if their are no cd's in the changer. keeps going from 1 to 6 and then changes to radio.
May 19, 2009 | Becker Car Audio & Video
2004 Chevrolet Tahoe cd player says changer full and won't work
Bad news. Your CD player isn't any good. I work for Chevrolet and this is a very common problem. The magazine inside the radio (the part that holds the cd's) starts going crooked. I think some real tiny springs that hold it break, causing this problem. Only fix is to replace the radio. First try this. Go to the fuse box under the hood and remove the 'Radio' fuse for 1 minute. This may reset the radio. You may be able to eject any cd's stuck in the radio. May be cheaper to put in an after-market radio. Sorry.
Dec 17, 2008 | 2004 Chevrolet Tahoe
RADIO CD problem
I found a solution on youtube...NatiGame.com
Sep 11, 2008 | 2005 Chevrolet Malibu
About every 2 months our 6-disc CD changer breaks down and we have to have the whole radio replaced they said it comes from playing burned cds in it but it has even broken down with store bought ones. So...
I had the same problem i just decided to pull the whole thing out and get a new radio and single disc cd changer put in and so far it works fine.
Jul 26, 2008 | 2006 Chevrolet Equinox
Car Audio & Video Logo
87 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
