Question about Kenmore Oasis HE 27082 Top Load Washer
Roxyrogers.1@hotmail.comThe tub moves back and forth and makes a loud noise when spinning
    Brigadier General:
  • 6,277 Answers
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal suspension is malfunctioning.
Good luck,
John C
Posted on Mar 23, 2011
Aher on fast spin makes a really loadd clanking nois and sonds like it is off balance but only do it o that fast spin the onthher spins cyclesa are fine can you help me
If you can produce a similar noise by moving the empty tub around, back and forth, manually, one or more of the suspension points has failed.
You can probably spot the point by removing the back panel and using a good light while someone else moves the tub.
BTW, always include make and model info when posting a request for help otherwise the answer may not make sense for your machine.
Sep 18, 2011 | Washing Machines
Maytag washing mchine makes a loud noise when on spin.
It sounds like your main bearing has gone out. It's quite an expense to fix and generally isn't worth fixing even if you do the repair yourself as the parts run about $600 by themselves and it takes about 1/2 a day to replace them. You can't replace the bearing itself so you have to replace the rear half of the outter tub and the inner tub.
Mar 29, 2010 | Maytag Washing Machines
Makes loud noise during the spin cycle.
no loud noises water will drain, just belt broke plastic piece needs to come off so I can replace belt.
Sep 13, 2009 | Kenmore Elite 45986 Front Load Washer
Washer will make noise while spinning. Took clothes out of machine tried to turn basket by hand. Basket will catch however it does not make any noise. If I spin clockwise it spins fairly free spin...
There is a clutch on the bottom of the washer that the tub sits in. Most likely it is wearing out. The machine will get worse, as if the tub is out of balance.
Jul 08, 2009 | Washing Machines
Tub makes loud thumping noise when spinning
Good morning! It's common to hear a loud thumping noise during spinning because the load (clothes) are not properly place in the tub. Please try to put the load in order & compress it down. best regards.
May 02, 2009 | Washing Machines
Frig front load washer GLTR1670AS too much play in tub
Remove the kickplate and inspect the 2 tub shock absorbers, it sounds like they might be broken. If the tub is hanging to one side or dropped all together, remove the top and check the tub support springs.
Feb 23, 2009 | Frigidaire GLTF1670A Front Load Washer
Makes a loud banging sound when spinning clothes
check springs and shock absorber.try to put more laundry.
Feb 16, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Drum makes loud noise when spinning
HI thanks for the question. Frigidaire has a life time warranty. on that part .call them. thanks the appliance doc. please rate my answer. thanks.
Apr 29, 2008 | Frigidaire ATF6000ES Front Load Washer
Loud cliunking noise in beginning of spin then won't spin
get a flashlight and see if a foreign object has fallen down through one of the tub holes and is jamming the tub you have to look real close
Jan 11, 2008 | GE WJSE3110A Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
32 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
