Question about Yamaha RX-V750 Receiver
Hi I am trying to program my Hitachi Plasma with a rogers provided universal remote. 5 button. I can program the TV but i cannot program the digital cable box. What am I doing wrong? Please help me Thanks in advance
The sat and cable boxes are like DIY items , just use a known set top box like dreambox e.t.c. ,i have a problem with my Logitech remote and pace HD sat receiver,evrey 2 -3 the sat receiver changes remote codes :) and its very annoing, but ill switch to a LED tv with integrated sat so for know acceptable i have a tip for you regarding receiver -change mylar and ceramic caps to film ones
Posted on Mar 23, 2011
My wave cable hd dta remote will not turn offandontv...repair guy said to ask vizio
Use the following instructions and code list to program your VIZIO Universal Remote Control. Press the TV (or device) button and hold for 5 seconds until the LED flashes twice. LED will remain lit. Find the programming code for your TV (or device) in the code list and enter it using the Number Buttons.
try a universal remote and program it, from the manual.
3 Digit Universal Remote Codes For TV Codes For Universal Remotes
4 digit GE universal remote control codes with code entering instructions
http://www.remotecodelist.com/
http://cdn.vizio.com/documents/downloads/vizio-universal-remote-codes.pdf
Feb 03, 2016 | Vizio P50HDTV10A 50 in. Plasma HDTV
Try to turn on via remote or button on set. Only a green flash on front. Nothing else. Can I fix it?
About 435,000 results (0.80 seconds) Search Results
    3 Ways to Program an RCA Universal Remote - wikiHow
    www.wikihow.com > ... > TV and Home Audio > Television
    wikiHow... Universal Remote. Are you tired of juggling three or four different remotes just to control your home theater setup? ... Log in via ... Turn on the device you want to control. ... Press and hold the button on the remote that corresponds with the device.... You will need to try another method in this article to program the remote.
    How to Program an RCA RCR312W Remote: 15 Steps ...
    wikiHowHow to Program an RCA RCR312W Remote. ... Log in via ... Press the PLAY buttonevery five seconds until the component turns off. ... If component does not respond or has limited functionality, codes in a different block list can be tried until you find the code that allows the remote to .... Set Up a Home Theater System.
    Your remote reprogramming woes solved - Rogers RedBoard
    redboard.rogers.com/.../your-remote-reprogram...
    Rogers CommunicationsJun 18, 2014 - Once the TV turns off, press the SETUP button once to lock the code.... You can always contact us via our Facebook page or tweet us ... Hi my TV is anRCA model # RLDED3258A-B I have tried 73 codes from Universal .... I have tried toset up my tv and home theatre with the Rogers remote but no luck...
    RCA TV: input channel/s-video - ecoustics.com
Jan 19, 2016 | RCA Audio Players & Recorders
I need a setup code for a all for one universal remote to operate a hitachi plasma tv
Set up codes for Hitachi with One for all remote control are: 0145, 1145
Jul 30, 2012 | One For All URC6131n Remote Control
Inputs will not change with remote with my Harmont reomte
Hello
It will be difficult to match any other universal remote with this model Hitachi set. You have to get the original remote control to select all the functions with this TV. If your original remote control doesn't work at all, just buy a new one. You can get it from the authorised service center for Hitachi at your town. OK.
Nov 04, 2011 | Hitachi 55HDS69 55 in. Plasma Television
Need universal remote control code for maxent 42" plasma tv?
I hope that you have gotten this resolved, but if not, or if you have any other questions, here are the codes and some simple steps to run through.
1. Hold down the clear TV button until all lights light up at the top of the remote
2. Punch in a 3 digit code (provided below)
3. Press the # (POUND) button
4. Try powering the tv on/off, and the volume. If one or more of these functions do not work, start over from step 1 with a different code
246
730
746
Becki Barned
DISH Network Customer Service
May 17, 2010 | Sampo PME-42V3 42 in. Plasma Television
Codes for universal remote
Programming Your RCA Universal Remote.
The RCA universal remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes: TV-000, VCR-000, Cable Box-000, and AUX is programmed with VCR code 037. For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search: 1- Manually turn ON your device (TV, VCR, Cable Box) 2- Press and "HOLD" CODE SEARCH 3- Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once. 4- Release CODE SEARCH. 5- Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second). 6- Once the device turns off, press and release ENTER. 7- With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists: 1- Find codes for each device and brand below. 2- Press and "HOLD" CODE SEARCH. 3- Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step. 4- Enter the three digit code from the TV, VCR or Cable Box code lists. 5- Release CODE SEARCH. 6- With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists. TV Codes Admiral 005 MTC 011,019,027 Amtron 064 Multivision 081 Akai 002 NAD 018,023 Anam National 038 NEC 011,014,019,027,038 AOC 011,019,027,088 MTC 0017,0023 Bell & Howell 005 NEC 0017,0023 Candle 011,027,033 Panasonic 012,013,038,086 Citizen 011,027,033,064 Penny 000,008,011,019,027,068,086 Colortyme 011,027,084 Philco 006,007,010,011,013,016,019,027 Concerto 011,027 033,035,037,038,043,087,089 Contec/Cony 036,037,040,042,064 Philips 006,007,010,011,013,016,033,035 Craig 064 037,038,043,066,073 Curtis Mathes 000,011,015,027 Pioneer 011,027,045,062,093 CXC 064 Portland 011,019,027 Daewoo 011,019,027 ProScan 000 Daytron 011,027 Proton 011,027,037,072 Dimensia 000 Quasar 012,038,092 Electrohome 006,011,014,027,038 Radio Shack 000,021,025,036,037,059,064 061,068 RCA 000,006,011,019,027,034,038,044 Emerson 011,026,027,028,029,030 046,088 031,032,037,042,053,064 Realistic 021 065,067,075,076,079 Sampo 011,027 Envision 011,027 Samsung 006,011,014,015,019,027,036,037 Fisher 017,021,039,041 077 Funai 064 Sanyo 017,021,039,056,057,058 GE 000,008,009,011,012,027 Scott 028,037,064 038,068,086,089,091 Sears 000,006,011,014,017,018,021,023 Goldstar 003,004,006,011,019 027,039,040,041,051,071,083 027,037,050 Sharp 011,020,025,027,037,052,053,059 Hallmark 011,027 060 Hitachi 009,011,027,036,037 Signature 005,094 040,047,048,063,080 Sony 002 Infinity 013 Soundesign 011,027,033 JBL 013 Sylvania 006,007,010,011,013,016,027,033 Jensen 011,027 035,043,049,066,087,089 JVC 012,024,036,037,040,048,051,074 Symphonic 064,076 Kawasho 002,011,027 Tatung 038 Kenwood 006,011,014,027 Technics 012 Kloss Novabeam 035,043 Techwood 011,027 KTV 078 Teknika 011,019,027,033,037,040,066 Loewe 013 Telecaption 090 Luxman 011,027 TMK 011,027 LXI 000,013,018,021,023,054 Toshiba 018,021,023,071,085,090 Magnavox 006,007,010,011,013,016 Universal 008,009 027,033,035,043,066,087,089 Victor 051 Marants 013 Vidtech 019,027 Marantz 011,013,027,069 Wards 000,005,006,007,008,009,010,011 Memorex 005 013,019,025,027,028,035,043,059 MGA 006,011,014,019,022 066,076,082,089 027,041,056,061,068 Yamaha 006,014,019,027 Mitsubishi 006,011,014,019,022,027,041,055 Zenith 001 056,061,068
Jun 25, 2008 | RCA Universal Remote Control
I have a phillips 5 unit controller with no code seach button what button do i press
If it did not come with codesearch button AND it was the original remote that cam ewith the V, just point the remote at the TV and press the power button for 10 seconds - it should program
I'm just going based on the information that you provided.
Philips has a 7-day-a-week helpline at 1-888-philips
Jun 14, 2008 | Philips Magnavox Learning Universal Remote
Universal Remote iwave
I Have The Codes,But No instructions!! Big IWave . 0054-Philips Hitachi-0145 JVC-0053 LG- 0178 OR 1265
Jun 09, 2008 | Hitachi 50HDA39 50 in. Plasma HDTV
Hitachi Plasma
i have dish network different brand tv but have codes for hitachi they are 1004,1006,1012,1013,1059,1060,1063,1135,1136,1145,1148,1179,1185. hope one of these helps
Dec 13, 2007 | Jensen JER-422 Universal Remote Control
Mbr3447 remote code for samtron vcr
Up untill a few years ago they used to make a lot of universals with a "learning" function, that you aim the thing at a certain device untill it figures out the right code for it. I read that the technology was bought since so you dont see those quite as often in the market. ok, if yours is a learning uni, here's a tutorial on how to fix it, in general terms since it varies between remotes: If you cannot get the instructions - most "universal" remotes have a "code search" feature. Usually this involves hitting the "program", "select" or "function" button, then pressing the device button ("TV", "VCR", "AUX") then repeatedly pressing the "power" or "channel up" button until the set responds. The remote will cycle through each of the codes (01, 02, 03, 04) sending the "power" command for each. When you hit the right code - the set responds. When the set responds, stop and then press the "program" or "function" button to enter it (which button varies between mfgrs). If you count the number of presses - that should be the code (12 presses is "12" or "012" - or it could be 11 if the codes start at 00). If you do not have a "program" button (it might be hidden), then you may have to instead hold the function (TV, VCR, Cable) button down for a few seconds (until the light blinks). The usual manual sequence is: 0 1 2 It might also be: 0 1 2 If no program button: 0 1 2 Some remotes use a two digit code, some use three. It'll take quite a bit of trial and error without the manual. you can try getting the codes from the manufacturer, go to their site and see if you can figure anything out there... good luck
Jan 19, 2006 | Zenith MBR3447 Remote Control
Yamaha RX-V750 Receiver Logo
313 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
