Question about Fellowes Powershred 280SC Shredder
Fellowes powershred 280. Has 2 position power switch. on/automatic and reverse. Need to put paper in to run forward, reverse switch activates reverse. PROBLEM: Try to shred by inserting paper, repeatedly push paper in/out/in/out/in/out until shredder activates and shreds paper.
fellowesrep
  • 102 Answers
SOURCE: shredder problems
Seems it could be a problem with one of your sensors Fellowes Customer Service can easily and quickly diagnose your problem. 1-800-945-4545
Posted on Feb 26, 2008
  • 105 Answers
SOURCE: won't shred
you have to replace the main power switch
Posted on May 14, 2009
  • 6 Answers
SOURCE: will not shred, but will go in reverse
Sorry don't mean to point out something obvious, but are you being shown any indication lights that the waste basket is not seated correctly in the bin or the head? If not, then you may want to try and check these connections anyway. Lights can burn out.
Posted on Aug 22, 2009
  • 250 Answers
SOURCE: shredder will shred about 3/4 of a sheet of paper
If your shredder has a feature where it won't run with the door open/shredder off the bin, you probably need to make sure that the safety is engaging properly. If the motor seems to sound very labored when it runs, unplug it, and check the blades to make sure there's not a lot of extra stuck in them. You may need to clean them and lubricate it with special shredder oil ONLY.
Posted on Nov 25, 2009
  • 41 Answers
SOURCE: not completely shredding. one side only makes
need bearing plate call cooks mobileshredding inc. or email cooksmobileshred@bellsouth.net or call bill cook or beverly miller 901-565-8188
Posted on May 10, 2010
How do I get top off to clear Paper Jam on Fellowes PS-12Cs
FELLOWES SHREDDER
In case of a paper jam , which may occur if the shredder is pushed beyond its specified capabilities, press the control switch to the off [O] position and empty the basket if full. Then:
1) Press and hold control switch in reverse [R] position and attempt to back paper out of shredder.
2) If shredder jams in reverse mode, press control switch to automatic [I] position and attempt to continue shredding operation.
3) If shredder jams again, alternate control switch slowly between reverse [R] and automatic [I] positions to attempt to move jammed paper completely through shredder.
If you are unable to clear the jam using this method, turn off and unplug the shredder; remove the wastebasket from cabinet and carefully remove any paper extending below the cutting cylinders; empty the wastebasket; insert wastebasket and repeat jam clearing procedure.
May 23, 2014 | Fellowes Powershred PS-12Cs, 12 Sheet...
Knocking noise when shredding paper
Cross-cut shredders require monthly oiling of the cutting cylinders to maintain proper operation. Failure to oil the blades regularly could result in excessive noise during operation.
Oiling Your Shredder's Cutting Blades:
To keep your shredder in top condition, the cutting blades need to be oiled every so often (for frequency, please refer to your owner's manual). We recommend using Powershred® Lubricant or a vegetable-based oil (such as corn or canola) in a non-aerosol container with an extension nozzle.
Caution: Never use flammable synthetic oil, petroleum-based, or aerosol lubricants to oil the cutting blades. Some agents may combust, causing serious injury. NEVER USE WD40.
1. Depress and hold the reverse button down.
2. Put the tip of the oil bottle in the paper entry and make one or two sweeps the length of the entry while squeezing the oil bottle.
3. Move the power switch to Auto (I) position, or depress the manual forward button (depending on model of shredder) and allow the blades to run at least three seconds.
4. Move the power switch to Reverse (R) position and allow it to run for at least three seconds.
5. Repeat steps three and four above at least three times.
I hope the above helps....
Good luck.
Apr 13, 2011 | Fellowes DM8C Cross-Cut Shredder
My fellows jbo1 jamed and then stopped running is there a reset buton?
Chances are it's over heated.
Ensure the wastebasket is empty then move power switch to the REVERSE position. This will reverse the jammed paper out of the shredder. If shredder jams again, alternate control switch slowly between REVERSE and AUTO (l) positions to attempt to move jammed paper completely through the shredder. If the shredder jams in reverse mode, move the switch to AUTO (l), depress the manual forward button located on the center of the shredder head and allow to run for five seconds. If jam does not clear, move switch to REVERSE again and allow to run for five seconds. Repeat this process until jam is cleared. If necessary, turn off shredder and use care to grasp the paper and carefully pull out to clear jam. Once cleared, move switch to AUTO (l) to continue shredding. The jamming may be happening because the cutting cylinder needs to be oiled. See oiling instructions below.
From fellow's website: http://www.fellowes.com/fellowes/site/support/support_troubleshooting.aspx#jammed
Dec 15, 2010 | Fellowes Office Equipment & Supplies
Fellowes Powershred PS 60CC stopped working
I own a Fellowes PS 60 shredder.
Here is a link to the manual for a Fellowes PS60 Shredder.
Maybe it will help you in resolving some of your problems.
https://app.box.com/s/q3r8jlatlfskvgyh5ne6
Fellowes Shredder PS60
Jan 14, 2010 | Fellowes Powershred PS-60 Shredder
The shredder is set on automatic. When I put
Most of these have an optical sensor to start them. Might need a wipe with a damp cloth (disconnect from power first!)
Nov 20, 2009 | Fellowes Powershred 4800CC Shredder
Shredder motor will run in reverse, but not
Sounds like a bad or dirty switch you can try to clean it with alcohol ( the switch that gets activated by the paper)
-Carl
Jul 06, 2009 | Fellowes Powershred 480 Shredder
Won't shred
Mar 31, 2009 | Fellowes Manufacturing FEL36055 Powershred...
Fellowes shredder will not work
Check the front door switch and the BIN FULL switch actuator.
Oct 22, 2008 | Office Equipment & Supplies
Fellowes powershred 320
seems to be an issue with the paper feed sensors i suggest you call Fellowes customer service. 1-800-945-4545
Mar 09, 2008 | Fellowes Powershred 420 Shredder
Fellowes Powershred 280SC Shredder Logo
151 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
