Question about Philips 60PP9352 60" Rear Projection Television
Image appears to be darker than I recall when it was new. Don
  • 4,889 Answers
If the images are getting darker then its certainly an issue with the three CRT tubes that are dying. Slowly the images will get darker and darker till you can no longer see a pic. If the image level is viewable then a brigthness/contrast adjustment should resolve the problem atleast for now. Otherwise you will need to replace the three CRT tubes to resolve this problem. This being a high voltage repair its recommended that you seek the assistance of a qualified tech as we are dealing with 30,000V here. As my mentor always says your life and limb are worth much more than this
Posted on Mar 25, 2011
SOURCE:
Samsung LCD TV Problem with Video
If this is a LCD, you have a failing LCD panel. Typical of older Samsung sets!
Jun 10, 2013 | Samsung Televison & Video
Samsung Ln-T4671F screen is getting darker. The whole screen is darker, not only the right or the left. Also a red vertical line appeared about a year ago, haven't noticed since- don't know of its...
MOST LIKELY YOU HAVE A DEFECTIVE LCD PANEL. Try lightly squeezing the top of the TV. Start from one corner and work your way slowly to the other side. If squeezing the top of the frame clears up the screen problem, you have a defective LCD panel tab. The only true repair is the replace the screen. This cost for a replacement panel could cost more than a new TV set.
Sep 03, 2012 | Televison & Video
Left hand side of image appears darker than rest of image as if a shadow is caused from somewhere. Unsure if this is a lamp problem or a camera problem
If it looks like a dark orange/brown band, its likely to be a Light Tunnel Failure. The Tunnel can be fixed thru the manufacturer, but it will cost plenty. You can also do it yourself.
For additional info, go to www.avsforum.com and search for "4805 Light Tunnel" and you will see threads about the problem...as well as DIY repairs.
I also posted a DIY replacement option since new Tunnels are virtually non-existent:
www.avsforum.com/avs-vb/showthread.php?t=1304694
Dec 24, 2010 | InFocus ScreenPlay 4805 Multimedia...
I find that even in a reasonably well lit room my camera struggles to pick up a clear image and always appears to be a lot darker than in real life. I would assume that on automatic setting this shouldn't...
Try bigger ISO-setting (in a well lit room 400-600 and darker even 1600). Also try to fix the exposure according to the darker parts of the room.
Aug 05, 2010 | Cameras
Image split with one section darker colour
You are correct in assuming this is a shutter problem. Your camera needs service.
Jun 26, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Samsung syncmaster 914v monitor problem. right side of display is darker image. can see dots like a newspaper print or looking through a screen. when display is black it almost appears like an image is...
This is likely the LCD panel itself - you are describing a left/right image error that can be only created by the left/right division by the LCD driver wrapped around the outside of the LCD panel.
If your monitor uses a separate circuit board to drive the LCD, it could be this driver board.
Either way, it will require an LCD panel - $$$
Mar 29, 2010 | Samsung SyncMaster 914V 19" LCD Monitor
How can i adjust the scanner to scan DARKER?
From the scanner menu in the “Advanced mode settings”, you can find the buttons for color settings.
Using Color Settings buttons, you can adjust the brightness and contrast of the whole image, specify highlights and shadows, and adjust the contrast and balance in an image.
Favorite Settings enables you to save a set of settings (Input Settings, Output Settings, Image Settings, Color Settings and Preferences) made for the focal cropping frame. If there are no cropping frames, settings for the whole preview area are saved.
You can also recall the saved settings and apply them to the selected frames or the whole preview area.
And you can adjust the scanner to scan darker.
Please find the explanation pictures attached.
Hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 26, 2010 | Canon ImageCLASS MF4370dn Laser All-in-One...
Small dark area in corner of screen on Samsung HLP5085W
What you have is a lens that has been jarred loose or a plastic support melted. That's what it sounds like anyway. you may have a recall on this problem if it is common for your model. Not likely something you can fix yourself. if you are Gadget inclined you maybe able to though. check recalls first.
Jan 02, 2009 | Samsung HLP5085W 50" Rear Projection...
My HP printer 2420 leaves "ghost" prints on the pages.
This can be caused by one of two things.
1. faulty wiper blade on your toner so that the previous image in not being wiped off the drum.
2. worn fuser sleve.
To work out which it is you will need to do a half stop test: print off a normal document then when it is about half way through the printer ( unfortunatly you may have to repeat this to get the timing right) open the front cover. remove the toner cartridge. if you can see the ghosting on the page the it is the toner. if its not there then its a new fuser. to save on money and if your confident enouh you may be able to just chane the fuser sleve depending on the state of the fuser on a whole.
hope this helps
feel free to email me if you have any other questions:
pete@wedotoners.com
Oct 21, 2008 | HP LaserJet 2420 Printer
Screen is a darker black on one side compared to other side
this is a light engine problem and it is a recall for toshiba. Call them and they need to give u a new light engine.....even though u will have other problems after they do that.
Oct 21, 2007 | Televison & Video
Philips 60PP9352 60" Rear Projection Television Logo
27 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
