Question about Garden
I bought a RAC HP132 pressure washer new used it for half an hour and the rubber washer has dissolved in the patio noozle so have changed the washer and now no pressure coming through and no detergent
  • 14 Answers
SOURCE: bosch aquatak 120i pressure washer/tetergent
Hi hope i can help!!
Try this empty the detergent tank then have your machine ready to work then half fill the tank with warm water and use the machine, this may take a few attempts so dont think its a 5 min fix! What happends is the detergent when left in the machine goes thick and gooy the warm water thins this and eventualy cleans it out but dont use boiling hot water this may damage the seals.before storing machine away do this method.
Hope this helps .Sean
Posted on Mar 04, 2008
  • 313 Answers
SOURCE: hooking up detergent to pressure washer
detergent can only be **** from the container only on low pressure.
Posted on Jul 08, 2008
  • 1388 Answers
SOURCE: Ryobi 3000 psi pressure washer detergent injector
Most detergent injectors work by the venturi system. That is that the detergent is drawn into the stream by the forward flow of the water thru a very narrow port after the water passes thru the pump. This system works best when the pressure at the tip of the wand is low. Trying using a very large tip to draw in and apply the detergent, then remove injector and rinse with high pressure. Not good for the pump but to apply soap reliably under high pressure the soap needs to be injected through the intake of the pump. enjoy
Posted on Dec 01, 2008
  • 97 Answers
SOURCE: Does not **** up detergent with the attached slim line hose
It only picks up under low pressure condition eather by adjusting wand or changing tip.
Posted on Mar 19, 2009
SOURCE: pressure washer - can't figure out soap
Use your mouth to get the siphon started. That's what I did and mine worked great!
Posted on May 23, 2009
Speed queen washer filling slow
The rubber of the filter stick to the hose due to time and heat of the water. Try to move "wiggle" it with your fingers to get it unstuck. Can even use the handle of a teaspoon for more leverage but try not to damage the rubber seal as it will not seal proper again when connected the tap. Clean with a nylon brush. If found impossible to remove, leave it as installed but immerse the hose end with the filter in a half cup vinegar for a hour or so to dissolved the chalk residue. Brush again with a nylon brush. Chalk remover can also be bought over the counter - same as the tuff sold to clean chalk inside electrical kettles. If every thing failed sit down with the hose end with the filter in one hand and a thin but strong/stiff piece of wire in the other hand and pry open each hole formed by the grid of the mesh.
Aug 01, 2014 | Speed Queen Washing Machines
I HAVE A RYOBI PRESSURE WASHER 3100 PSI WITH HONDA ENGINE PURCHASED FROM HOMEDEPOT USED IT 2 WEEKS AGO RAN PERFECT TRYED USING YESTERDAY AND I HAVE NO PRESSURE THE UNIT IS ONLY 10 MONTHS OLD ANY SUGGE
  • I have the exact same pressure washer..bought 10 months ago from Home Depot with the same problem..no pressure. Have you had any luck finding out what the issue is?
Jul 22, 2014 | Ryobi Gas Pressure Washer: 3100 psi 2.5...
Water doesnt flow through my pressure washer when the enging is running
But, does it flow through when the engine is off?
If no water goes through either way, it can be as simple fix as cleaning the noozle. Remove the noozle, or the gun, and finally the out flow hose. If water flows through, start adding components from there. Also make sure that your noozle is turned on with full flow.
May 04, 2014 | Briggs & Stratton Pressure Washer...
Rac washer on off swich
What is a Rac washer? Please provide more specific information. I recommend contacting your local authorized service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Nov 14, 2013 | McCulloch Electric Pressure Washer 1800psi...
O rings are splitting in half after about 1 hour of use continually happening
Like a lot of parts out there, there is cheap made parts. O rings fit and that category. Most your standard 0 off the shelf O rings are not made for high pressure. Take a little trip down to home depot, or Lowells or ace hardware. Tell them you need the high pressure O rings for a pressure sprayer. They have different kinds, thicknesses and made out of different rubbers/plastics. Hope this helps. Thanks mike
Jun 14, 2011 | Northstar Garden
When the patio cleaner is attached,the Karcher 5.68 pressure washer now keeps stopping and starting.It works fine on high pressure lance.It worked fine when bought from new a few days ago. We tried...
None of these fixes works for me and the original poster, like me what he's saying is when he swaps the high pressure lance for the patio attachment it pulses on and off, but when that happens, you can swap back to high pressure lance and it's fine. This means it's the patio attachment not any valves or power source, I have the same problem
Mar 09, 2010 | Karcher Garden
My washer wont spin out
I believe these are made by whirlpool and use a rubber coupling to connect the drive motor . they are five dollars and change in half an hour if your half way mechanical.
Oct 29, 2009 | Kenmore 24032\24036 Top Load Washer
Printer shows i have half full ink,but when i print it prints very light and half way down page there is nothing?
i think there is a prblem about the ink cartridge. the noozle maybe it doesnt flow the ink or maybe you filled the cartridge too much of ink. try a new cartridge cartridge but before that try to clean the noozle of your ink cartridge.. - **wanski cebu**
Oct 11, 2009 | HP DeskJet 3745 Printer
Garden Logo
361 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
