Question about Canon PIXMA MX860 OFFICE AIO-2.5IN LCD 19.4X17.1X8.9IN All-In-One InkJet Printer
My Canon PIXMA MX860 stopped sending faxes. Now, when I try to transmit it sounds as it if it going through - dial tone, dialing, 'fax noise' - but then I just get an Incomplete Transmission error report with the NG result. I have checked all of my cables and all of my settings and cannot figure this out. I almost think the call may be hanging up during the transmission but I can't confirm that and the phone line itself is working fine. Any thoughts?
  • 3 more comments
  • indiefilm Mar 23, 2011
    I have tried lowering the transmission speed and that does not help. I have gone all the way down to 7200 and am still having the same problems.
    The "Check RX fax info" is set to OFF.
    I thank anyone for any light you can shed on this.
    Thank you, Rider. I tried turning off the ECM to no avail. I'm glad you
    detailed how to do it. Just one question - where is the paper feed
    button?
    I tried turning it on - waiting til it settles - then pressing the power button and the Two-Sided button at the same time. It just goes to the screen for one sided or two sided printing. I tried hitting one slightly before the other or both at the same time - and held them for a long time - but never got glowing LEDs. Am I missing something?
  • indiefilm Mar 24, 2011
    I press both of them down at the same time and nothing happens. I was holding them for a long time and tried several times. Do you know of any other ways to factory reset? Thanks.
    It was helpful but, unfortunately, it still does not work.
  • Canon Master
  • 1,679 Answers
Two Issues:
1. The Transmission Speed of the MX860 may be too fast.
Solution: on FAX Menu go to Settings>Device Settings>FAX Settings>Transmission Settings >"TX start speed" and change to 14400 or lower (14400 worked for me).
2. The recipient FAX machine may be receiving by a different number than the one you dial. This may occur if you dial a free-calling no.
Solution: Go to Transmission Settings as above>"Check RX fax info" and turn it to OFF. This disables the mismatch issue.
Regards,
Ron
Posted on Mar 23, 2011
  • 2 more comments
  • ONE-Touch-Solution
    ONE-Touch-Solution Mar 23, 2011
    Try to Turn off the ECM ( Error correction mode ) - This normally helps resolve any such issues.
    1. Press the FAX button, then press the <Menu> button .
      The Fax menu is displayed.
    2. Press the http://usa.canon.com/app/images/service_..." class="h_mi" />
      The Settings screen is displayed.
    3. Press the http://usa.canon.com/app/images/service_..." class="h_mi" />
      The Device settings screen is displayed.
    4. Press the http://usa.canon.com/app/images/service_..." class="h_mi" />
      The FAX settings screen is displayed.
    5. Press the http://usa.canon.com/app/images/service_..." class="h_mi" /> button to select Transmission settings, then press the OK button.
    6. Press the http://usa.canon.com/app/images/service_..." class="h_mi" /> button to select ECM TX, then press the OK button.
    7. Press the http://usa.canon.com/app/images/service_..." class="h_mi" /> Note: The default setting is [ON].
      • ON: With ECM ON,
        the output image quality for the machine receiving the fax will be
        much better than if ECM was off and there was noise on the phone line.
        However, the transaction time will be higher.
      • OFF: The transaction time will be less but image quality will suffer.
    8. Press the <Fax> button to return to Fax standby mode.
    If this does not work, You may need to do Factory reset.
    By doing the factory reset, your printer may loose information like speed dial no, network connection and you need to re-setup the printer again.
    To reset the printer, power on the printer and then press the power and
    paper feed button together. Keep the buttons pressed till all the LED's
    on the printer glow. Release the buttons and then let the printer
    restart. Check if the printer is working properly after restarting
    If None of this works, It could be a fax feature failure in your though rest other features are fine like copying/printing/scanning.
    Paper Feed Button also called the Two-Sided button - between the cross button and the keypad
    Try to press the button simultaneously .. this is the normal process to do so. Hope this should fix.
    ONE-Touch-Solution Mar 24, 2011
    Default Settings
    Instructions to change the machine back to its default settings.
    1. Press the button.
    2. Press the left right arrow buttons to select Settings, then press the OK button.
    3. The Settings screen is displayed.
    4. Use the left right arrow buttons to select [Device settings], then press the button.
    5. Use the up down arrow buttons to select [Reset setting], then press the button.
    6. Press the up or down arrow to select one of the below options and then press .
      • Telephone no. only
      • Setting only
      • Reset both
    Telephone no. only:Reverts the telephone number settings to default.
    Setting only:Reverts the machine
    settings other than the telephone number settings, such as the page
    size, media type, and other settings, to default.
    Reset both:Reverts both the machine and telephone number settings to default.
    1. Use the up down arrow buttons to select [Yes] on the confirmation screen, then press the button.
    2. Press the button to return to the COPY menu.
    Note: Reverts all
    settings you made to the machine since purchase back to default.
    However, some data may not be erased, depending on the current usage
    state of your machine
    *Please rate this solution with thumbs up
Cannot send fax on Pixma MX328 error message redo operation
If it does it when sending to all no's then it could be a country code setting.make sur it is set to the south africa country code.
Oct 29, 2012 | Canon PIXMA Office Equipment & Supplies
Faxing
did u try to do a hard reset to clear this error?
if nt try it please
Jun 26, 2008 | Canon PIXMA MP780 All-In-One InkJet...
HOW TO SEND A FAX
You can send a fax in a variety of ways. Using the control panel, you can send a black and white or color fax. You can also send a fax manually from an attached phone. This allows you to speak with the recipient before sending the fax.
To send a basic fax (single- or multiple-page black-and-white fax) by using the control panel.These features allow you to control the pace of your dialing. They are also useful when you want to use a calling card to charge the call and you have to respond to tone prompts while dialing. NOTE: If you need printed confirmation that your faxes were successfully sent, enable fax confirmation before sending any faxes. TIP: You can also send a fax manually from a phone or by using monitor dialing.
1. Load your originals. NOTE: If you are sending a multiple-page fax, you must load the originals in the document feeder tray. You cannot fax a multiple-page document from the glass. 2. Enter the fax number by using the keypad, press Speed Dial or a one-touch speed dial button to select a speed dial, or press Redial/Pause to redial the last number dialed.TIP: To add a pause in the fax number you are entering, press Redial/Pause, or press the Symbols (*) button repeatedly, until a dash (-) appears on the display. 3. Press START FAX Black or START FAX Color. • If the device detects an original loaded in the automatic document feeder, it sends the document to the number you entered. • If the device does not detect an original loaded in the automatic document feeder, the Fax from glass? prompt appears. Make sure your original is loaded print-side down on the glass, and then select Yes.TIP: If the recipient reports issues with the quality of the fax you sent, you can try changing the resolution or contrast of your fax.
Send a fax manually from a phone You can send a fax from a telephone on the same phone line if you prefer to use the keypad on your phone, instead of the keypad on the control panel of the device. You can do this by plugging in a phone into the 2-EXT port on the back of the device. When you send a fax manually, you can hear the dial tones, telephone prompts, or other sounds through the handset on your telephone. This makes it easy for you to use a calling card to send your fax. Depending on how the recipient has their fax machine set up, the recipient might answer the phone, or the fax machine might take the call. If a person answers the phone, you can speak with the recipient before sending the fax. If a fax machine answers the call, you can send the fax directly to the fax machine when you hear the fax tones from the receiving fax machine.
1. Load your originals. NOTE: This feature is not supported if you load your originals on the glass. You must load your originals in the document feeder tray. 2. Dial the number by using the keypad on the phone that is connected to the device. NOTE: Do not use the keypad on the control panel of the device when manually sending a fax. You must use the keypad on your phone to dial the recipient's number. 3. If the recipient answers the telephone, you can engage in a conversation before sending your fax. NOTE: If a fax machine answers the call, you will hear fax tones from the receiving fax machine. Proceed to the next step to transmit the fax. 4. When you are ready to send the fax, press START FAX Black or START FAX Color. NOTE: If prompted, select Send Fax, and then press START FAX Black or START FAX Color again. If you were speaking with the recipient before sending the fax, inform the recipient that they should press Start on their fax machine after they hear fax tones.
The telephone line is silent while the fax is transmitting. At this point, you can hang up the telephone. If you want to continue speaking with the recipient, remain on the line until the fax transmission is complete.
Send a fax using monitor dialing Monitor dialing allows you to dial a number from the control panel as you would dial a regular telephone. When you send a fax using monitor dialing, you can hear the dial tones, telephone prompts, or other sounds through the speakers on the device. This enables you to respond to prompts while dialing, as well as control the pace of your dialing. TIP: If you do not enter your calling card PIN fast enough, the device might start sending fax tones too soon and cause your PIN not to be recognized by the calling card service. If this is the case, you can create a speed dial entry to store the PIN for your calling card. NOTE: Make sure the volume is turned on, or you will not hear a dial tone. To send a fax using monitor dialing from the control panel
1. Load your originals. NOTE: If you are sending a multiple-page fax, you must load the originals print-side up in the document feeder tray. You cannot fax a multiple-page document from the glass. 2. Press START FAX Black or START FAX Color. • If the device detects an original loaded in the automatic document feeder, you will hear a dial tone. • If the device does not detect an original loaded in the automatic document feeder, the Fax from glass? prompt appears. Make sure that your original is loaded on the glass, and then select Yes. 3. When you hear the dial tone, enter the number by using the keypad on the control panel. 4. Follow any prompts that might occur. TIP: If you are using a calling card to send a fax and you have your calling card PIN stored as a speed dial, when prompted to enter your PIN, press Speed Dial or a one-touch speed dial button to select the speed dial entry where you have your PIN stored. Your fax is sent when the receiving fax machine answers.
Apr 01, 2011 | HP Officejet Pro L7680 All-In-One Printer
How do you send a fax on a canon mx340
try to download manual from the following site
http://support-au.canon.com.au/contents/AU/EN/0300299101.html
If above link does not work , clickon the below link to proceed....
http://www.canon.com.au/en-au/For-You/Printers/PIXMA-InkJet-Printers/MX340
If you like solution, please rate & vote...
Thanks
San
Mar 14, 2011 | Canon MX340 AllInOne InkJet Printer
I have new canon pixma mx 328. how to do fax operations of sending and receiving
Hi!
It is very easy
To Send Fax:
1. Place the documents facing down in the flatbed scanner glass or insert in the ADF unit with the documents facing up.
2. Press the Fax button
3. Key in the number of the receiver then press the black or color START button.
4. Listen to the dial tone and see in the lcd display the message "transmitted" to confirm that the documnets have been sent.
Using the phone is attached to your printer (documents is already load to the printer)
1. Call the number of the receiver.
2. Ask for a fax tone.
3. Once you heard the fax tone, press the Black or Color Start button
To Receive Fax (Set up first the number of calls before automatic giving fax tone to caller)
1. When someone is trying to send a fax to you, don't answer the ring on the phone, let the printer give the fax tone.
To receive the fax on the printer with the user's help.
1. When someone is calling, just press the Black or Color Start button.
To receive fax when you answer a phone
1. While the phone is lift up, press the Black or Color Start button to receive the fax.
Hope that information will guide you.
You can thank me by just rating this help.
Thank you for using Fixya.
Dec 14, 2010 | Canon PIXMA MX300 All-in-One Printer
TRYING TO SEND A FAX IM NOT SURE HOW TO OR WHAT
dial the fax number .. when some one answer ask for a fax tone... then press the send button..
some fax machine when you call the number it automatic give you fax tone ,, after that press the send button..
Sep 01, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Fax error message = TX cancelled:RX fax info mismatch???? Cannot send fax - How do I fix this error - Not all faxes return this message
Two Issues:
Hope this helps. aknz
Jul 31, 2009 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Fax with Pixma MP780
if you can hear it connecting and you can here fax tones then it sounds like it going. just place the page in the adf and dial your number and hit send button. how do youknow that the other person is not reciveing it? if you are in the uk then i can send you a page and see what we get?
Oct 21, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Faxes won't complete transmission
those noises you hear are line noises via your phone line, not machine related but they wreak havoc on faxing. first you need to replace the actual line connecting the fax machine to the wall. If this doesn't fix the problem then have your phone lines tested. also make sure your machine is set for digital or analog service, depending on which you have. Good Luck.
Sep 20, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Can not transmit faxes
do you have a seperate fax line? if so check the fax line.
also in the fax menu set up your fax to phone/fax mode, and set up all your fax info.
if you have distinq ring you need to set up your # of rings.
Feb 22, 2008 | Canon FAXPHONE L170 Plain Paper Laser
Canon PIXMA MX860 OFFICE AIO-2.5IN LCD 19.4X17.1X8.9IN  All-In-One InkJet Printer Logo
1,338 people viewed this question
old marine
old marine
