Question about Sony Cyber-shot DSC-W55 Digital Camera
DSC W55bl: I can not start my Cyber. After pushing POWER : Acces and for monent TURN THE POWER OFF AND ON AGAIN. I do, bat without results. Same problem after INITIALIZE. Please,can you help me?
    Brigadier General:
  • 3,006 Answers
Your camera almost certainly has a lens error, this is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Sony service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault. Although the article mentions Canon a few times, the advice applies equally to all cameras with lens errors and is not model-specific.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera, or at least are able to use the information to help decide whether to buy another camera. If you do decide that you have to throw your camera away then don't forget to remove the memory card as it can be used in other devices. Please take a moment to rate the free answer I have provided for you and any testimonial which you might wish to add is always welcome.
Posted on Mar 24, 2011
When I turn on sony cyber-shot camera I get a screen display that states "access". The lens keeps going in and out and then it states,"turn the power off and on again" What's...
When I turn on sony cyber-shot camera I get a Problem with the Sony Cyber-shot DSC-W35 Digital Camera when I turn on sony cyber-shot camera I get a screen display that states "access". The lens keeps going in and out and then it states,"turn the power off and on again" What's wrong??
Oct 12, 2011 | Sony Cyber-shot DSC-W35 Digital Camera
Error Message: Access Turn the power off and on again. Lens will not collapse and remains extended. Cannot take pictures. Have replaced recharged battery with no results
TURN OFF THE POWER AND TRY AGAIN WAS THE PROMBLEM IN MY SONY CYBER SHOT DIGI CAM AS I DROOPED IT . BUT I GOT IT REPAIRED AT A REASONABLE RATE AT MATA CAMERA REPAIR AND SERVICES , NO 86, SP RD. CONTACT MR VIJAY 9035871324. NOW ITS AS GOOD AS NEW. THANX A TON MR VIJAY.
Mar 28, 2011 | Sony Cyber-shot DSC-W70 Digital Camera
DSC-W150 SteadyShot says turn power on & off & lens pops in/out
I had the same problem with my Sony DSC-W150 camera. It turned out to have an easy fix. At the same time, press the power button and depress the shutter button halfway (the one you snap to take pics) as if you were trying to engage the autofocus without pressing the button down entirely. The lens will attempt to autofucus, which in my case was enough extra power to dislodge whatever debris/sand had clogged the lens. Hope this works for you!
Jun 04, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
Aug 01, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
I have that same problem with my dsc w55
Hi!
The focus is stuck - could be sand or something. Contact your local Sony service center or me toms.safranovs@gmail.com
I work in a Sony service center and repair these every day.
Tom
Jul 28, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
SONY CYBER SHOT NOT WORKING
Hello samtx930, "turn off the power and on again" its a very commen problem and occurs when the lens block assembly start malfunctioning. Actually the slide motor not work properly and until the lens not come out completely the camera will not work, that's why the error message appears "Access" and then screen shows "turn off the power and on again". In this situation you have to replace lens block assembly.And the part No. is with description is given below: 1-788-363-11 OPTICS UNIT (ED13A) Thanks for using fixya.
Jun 14, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Sony cyber shot dsc-n2
There could be two things causing this problem.
1- some dirt somehow got on the outside of side of the lense. So the lense could not fully retract or open out. As a result you can take any picture. If the lense comes out even a little bit, try to pull it out NOT too hard a few times. If it does not retract, turn the camera off and push the lense in (up and down) NOT too hard foe a few times. If the camera opened up 100% or retracted 100%, your camera should be back to normal.
2- If you dropped the camera, some mechanical part of the lense is broken or dislocated or the cable may have come loose. In this case you need to take out the lense from the camera and inpect it for broken pieces or loose cable. clean the outside of the lense and push the lense in and out a few times. Put the lense back on and your camera would be back to normal.
Good luck!!!!!!
May 14, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
Sony Cyber-shot DSC-W5. Will not turn on.
try diffrent batteries even the ni-mh batteries go bad after so many charges also make sure you have the batteries in the right way
Mar 16, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
DSC W80.
Whenever you switch on the camera the lense comes out to a certain places, stops and the camera is initialized to take the picture. In some cases when there is a friction in the movement of the lense, it does not comes out fully up to the proper position. so the camera mechanism draws it back and again pushes it out. this happens 3-4 times and if still the lense does not reaches its position it displays "turn the power off and on again" and the problem continues.
Your camera needs a repair of the lense assembly.
Jul 08, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
15 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
