Question about Hoover Washing Machines
My hoover washing machine (hnl6166, 4yr old) won't pump the water out. I have replaced the pump as it was not working and checked for blockages. But still it won't drain, I've drained it manually for now. It will operate all programs but the drain program. Any ideas as what is wrong, is it a electrical issue? And is it worth repairing or getting a new one.
  • 118 Answers
If you have replaced the pump with a new one and still no pump, check the hose from the washbowl to the pump. Usually a convoluted hose . It possibly has a blockage. Take the end of this hose off of the pump and check up it ....you might be surprised
Posted on Mar 23, 2011
  • csg1985 Mar 24, 2011
    Thank you for the reply, I've checked the hose again and there's no blockages. When the machine is on, water will come out the filter but it won't pump.
Problem Hoover 200m 4.5kg top loading Machine not drain water
no drain? do u have a spin cycle working? If so check the water pump and hoses for clogged blockage. or broken obstructed propeller, can u turn it (pump) by hand?
Mar 02, 2015 | Hoover Washing Machines
The water wont drain out of my hoover 750 la washing machine
Check all hoses for blockages, check pump for blockage. Make sure drip dry or sud save switch / push button is off. Check for clothing item caught between inner & outer bowl using torch.
Apr 10, 2014 | Kenmore 24032\24036 Top Load Washer
Have a hoover optima 1400 only a few months old. i
check u have not got any blockages in the pipe that leads 2 underneath ur sink
Jun 21, 2010 | Washing Machines
Hoover Zodiac 12 that won't spin.
possible filter blockage, or the pump has failed/seized, machine CANNOT spin while it CONTAINS WATER, the door interlock will not open for the same reason,WATER in drum.
manually drain excess water into a bowl now
1 clean filter, 2 check pump for objects that prevent impeller working may still need pump if seized
Jun 12, 2009 | Washing Machines
Washer not draining , the pump has been replaced and its still not draining , drained water hose in bucket, no blockage, is it the relay?
Check drain hose first.
If you do not find any blockage, then you will need to access the pump, remove pump hose and look for blockage in there.
If there is no blockage at all, then either the water level switch, a faulty pump, a wiring problem, or a faulty timer board can be cause the machine not draining.
Apr 06, 2009 | Hoover HF7 160E Front Load Washer
Hoover CA230 1300 Special Edition Washing Machine
I had the same problem. My husband checked the carbon brushes attached to the motor and ran the machine on spin. The brushes were sparking so he assumed they were worn and replaced them and hey presto machine works fine now. The brushes cost 23.99 and were just bought from a local shop but can be bought online cheaper. Hope this helps solve your problem. Essex
Mar 08, 2009 | GE S8000E
Water not draing away and machine is not spinning
Empty your machine manually by lowering the drain hose into a bowl or bucket. Then remove the kick plate and check the filter for blockages.Before replacing try the machine on drain to see if the pump is running, if problem persists there may be a blockage in the pipe from the drum to the pump.
Nov 15, 2008 | Hoover Nextra HNWL 3136 Front Load Washer...
Washing Machines Logo
274 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
