Question about Fuji Cameras
New camera finepixs4000a keep saying turn off and back on
    Brigadier General:
  • 3,006 Answers
If it is brand new then it's faulty. Take it back for a refund or exchange. If that option is impossible for any reason then please keep reading.
Your camera almost certainly has a lens error, this is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Fuji service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault. Although the article mentions Canon a few times, the advice applies equally to all cameras with lens errors and is not model-specific.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera, or at least are able to use the information to help decide whether to buy another camera. If you do decide that you have to throw your camera away then don't forget to remove the memory card as it can be used in other devices. Please take a moment to rate the free answer I have provided for you and any testimonial which you might wish to add is always welcome.
Posted on Mar 24, 2011
Turn camera on, lens comes out, goes back in ,and says lens error.
try these fixes
1.Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable nimh 2500mah or better) and turn the camera on. If using rechargeables, and they're more than a year old, consider purchasing new rechargeable batteries as they may not be providing sufficient power to startup the camera. If new batteries didn't work, try pressing and holding the 'Function' or OK button while turning the camera on.
2.If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
3.Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins back into their slots.
4.Insert the cameras audio/video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fix 3 as a means to provide extra power to help to this fix. Reinsert the cable only after tapping the camera.
Feb 07, 2011 | Nikon Coolpix S3000 Digital Camera
I have bought new camera, just tried it today and keeps saying error code 99? turn it off and back on and remove battery and reinstall, tried all of this and it keeps saying the same?
Error 99 is a catch basin for a number of problems I'm going to assume that because this is a new camera that you didn't format the memory card. Formatting a memory card makes it function perfectly with the camera it's being used in. Also after pictures have been downloaded to the computer you need to format the memory card, cleaning all the old pictures off the card and giving you a fresh clean medium to use to put new pictures on. You will see also that there is this little handy garbage can icon and this is or should be used only when you find you need more space on the card when you are shooting and not the way to clear the card. The memory card should always be formatted in the camera.
Dec 25, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Lens error :0x01110000 That's what it says when
Try one of these two fixes, if they dont work for you follow the link below for further troubleshooting.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
Jun 12, 2010 | Pentax Optio 60 Digital Camera
When i turn the camera on it says lens error
There are 2 fixes I know for this you can try.
1. Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
2. If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. You don't have a memory card installed, so turn it off, slip in the sd card and turn it on one last time.
Jun 07, 2010 | Nikon COOLPIX L18 Digital Camera
Jazz digital camcorder dv151 will not work
make sure its using the sd memory not cameras internal memory
Nov 30, 2009 | Jazz DV151 Camcorder
My Sony Cyber-Shot W200
Your camera needs Lens replacement.
Jul 29, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Battery Problem
These cameras have a internal battery that holds data for the camera to keep its settings. These batteries can be replaced but the camera has to be disassimboled to change it they should be able to be changed at a local camera shop pretty cheap.
Mar 21, 2008 | Nikon COOLPIX L12 Digital Camera
Change Batteries....?
Ok.. did you guys try a reset? Just remove the batteries, wait for 60 seconds then put them back in.. that should reset the camera..
Feb 22, 2008 | Canon PowerShot A95 Digital Camera
Cameras Logo
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
