I have been given a working dell fp1500 screen, have plugged it into my desk top, screen is reduced but working and displays a sign no video input. Is this simply not having the right driver or do I need an an updated video card. I am running XP and did not receive a disk with the screen
    Master:
  • 525 Answers
Heres what you do: Open up your tower. Take out the ram sticks. Put them back in. Make sure there is no power when you do this. Close your tower restart you computer with the monitor connected. You should then recieve a signal.
Posted on Mar 23, 2011
I was given a temporary password and I want to sign on
Please explain more - type of system, OS, Password for what ? Bios, Windows sign-on WHAT ?
Feb 24, 2014 | Dell Inspiron 580s Desk Top Mother System...
I have a new Sony VPCJ1 series desk top. When I make a slide show, the slides are much larger than the pictures in the video file and they don't show all of the picture. what can I do. I have tried...
Are you using the laptop screen or using a larger monitor or projecting the slide show? The screen resolution on the Sony may need to be adjusted.
Apr 15, 2017 | Arcsoft MediaImpression for PC
Reduce screen size on desk top
what you want to do is go to start>control panel>personalize> and adjust screen resolution and pick what you like
May 22, 2011 | Dell Computers & Internet
Need help my desk top monitor is showing a sign flashing saying no signal detected need to see how to fix or what might be the issue with desk top
This is the message shown when you power off your computer but you leave the monitor on. If your PC is on but you still see this message then it is a video problem. It could be as simple as a loose connection somewhere in your video cable (either where it plugs into the monitor or where it plugs into the PC). It could also be the monitor-many have different input modes and maybe the input mode changed somehow. Then again something could be wrong with the video card-are components loose on it? Check all of these, in that order (easiest to hardest), and I think you will have found the problem.
Hope this helps.
May 19, 2010 | Computers & Internet
Hi. I have a dell e310...and the desk top turns on but the monitor will not display anything...it has an amber light..sometimes.it will turn to green but then shuts off again Could this be a bad video...
depends . either the video card or motherboard see if the blue video connector is at the top or twords the bottom of the case and that will tell you if it's a card or integrated on the board.
May 13, 2010 | Dell Dimension E310 PC Desktop
Could I plug the computer into the televison to watch a movie I have download
yes you can, simply plug 15 pin vga cable into the vga output of laptop, where you connect your projector another end of the cable will be connected to the television. It will take few seconds to appear but the television should be LCD
In the case of crt television you can use s-video out put of laptop and same data cable .
Few setting has to be done as follows.
Right click on desk top
Properties ----- settings
Now sellect the display from drag down menu or click
on the visual display of icon 1 and 2 for relative screen.
Apr 14, 2010 | Dell Inspiron E1505 Notebook
Hook vga cord to hdtv and optiplex desk top get
Try a different display setting, for example, 1280 x 800 or 1024 x 768. Once you can see (computer) display, then move onto the best resolution which your display card support for your HDTV. Good luck..
(btw, if your dell has two vga sockets, get another vga cable. Then set your computer to a dual display mode, one for your computer and the other for HDTV. this way you will never lose your display.)
Dec 09, 2009 | Dell Computers & Internet
Hooking a PC to your laptop's screen
Unfortunately you cannot use a laptop screen to view output from other computer sources. As you are surely aware, you may plug another monitor into the VGA plug on the laptop to view the laptop's output, but the plug is only for the laptop's output.
Nice thought, though.
Sirwriter
May 23, 2009 | Dell XPS M1330 Laptop
No showing the full screen. Top + bottom 1 and half inches dark
your system display settings are set to a wide screen setting on desk top right click then properties, right had tab display then set the screen size to a square shape like 1024 x 768.
Feb 16, 2009 | Dell E153FP 15" LCD Monitor
My display does not show on the entire screen its just in the middle of my screen.Dell Latitude D800 PC Notebook pls assist.I re-installed the video driver it still does the same thing.
check the resolution settings, right click on the desktop if you are using vista then click on personalize and go to display settings and make sure that it is set to your desired settings.
If using XP then right click the desk top and go to properties then check your display settings from there.
I hope this helps
Nov 17, 2008 | Dell Latitude D800 Notebook
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
