Question about Sigma APO 50-500mm F4-6.3 EX DG/HSM Lens
On 250mm onwards the auto and manual focus do not work correctly unless I support the front of the lens
  • Sigma Master
  • 3,289 Answers
That is some heavy glass.. it sounds like there is a problem with the drive mechanism in the lens when the lens is extended. The droop from the weight of the glass prevents the mechanism to function as designed.
Since this is a precision optic, I would send it to Sigma or other reputable shop for a repair estimate. Attempting to disassemble this or contaminating interior parts would worry me too much for me to try it. Unless you know what you're looking for - I'd arrange for service by calling (1-800-896-6858) or contacting Sigma Customer Support, package it up and send it out for repair. You might still be under warranty, too.
Posted on Mar 23, 2011
Why does the focusing ring on the efs 55-250mm not retract all the way when you turn the camera off
I doesn't return to it's closed position when the camera is turned off. You have to do it manually . Turn the zoom ring to the 55 position then turn the front focus ring fully to the left.
Apr 27, 2014 | Canon Ef-s 55-250mm F/4.0-5.6 Is Telephoto...
Pictures didnt develop
Hi Steph Johnson,
Numerous things could be the issue. 1, dirty lens, clean the front and back element, 2. The camera focus is not working properly not focusing on the correct spot. So, are you manual focusing or auto focusing? If it is auto then there could be an issue with that. If your are manual focusing are you sure your diopter setting is correct for your eyes, if not then it may appear correct in the viewfinder, yet be off focus.
Do you have a way to check the lens on a DSLR? If so you can try that lens on the DSLR seeing if there is an error with the lens or if it is your film camera.
Cordially
Oct 20, 2013 | Canon EOS Rebel XS 35mm SLR Camera
My lensmakes a sound when i video
The sound may be the result of the auto focus motor operating to keep the subject in focus. You may be able to shut off the auto focus by switch on the lens (if provided) or camera body menu and focus manually instead.
Apr 30, 2012 | Canon 55-250mm F/4-5.6 Ef-s Is Telephoto...
Auto focus stopped working
Try cleaning the contacts on the camera and the lens, this is what usually prevents AF from working correctly.
Jul 26, 2010 | Tamron 18-250mm F/3.5-6.3 AF Di-II LD...
Damaged Lense
does the camera recognize it? I mean when it is attached, does the camera show the Fstop etc?
Jul 11, 2010 | Tamron 18-250mm F/3.5-6.3 AF Di-II LD...
75-250mm F3.8-4.5 tamron lens compatible to a
As long as you can get the correct Tamron Adaptall 2 mounting for it, then it will fit. They're no longer made and not always easy to obtain at reasonable prices.
Adaptall 2 mounts for Minolta autofocus were never made, but the earlier MD mounts were, and they will fit any Minolta or Sony SLR. Obviously, there will be no autofocus but you will also find that you have to focus with the aperture ring wide open and then manually meter and take the shot after you have selected the aperture which you require.
Feb 16, 2010 | Konica Minolta Maxxum 50 QD with 28-100...
Canon 75-300mm USM III, was initially working fine
Hi
you seemed to have a problem with the camera (auto-focus) mode. I suggest you try shooting in manual focus only but consider taking it to a canon service outlet for proper checks and service as a long-term solution.
Apr 04, 2017 | Canon Zoom Telephoto EF 75-300mm f/4.0-5.6...
Auto focus problem
My first suggestion is to send it back if it is under warranty.
The grease probably got so thick, from the cold, that it caused too much resistance for the auto-focusing mechanism. You probably have damaged the focusing mechanism in the lens. You cannot repair this, yourself. I don't know how cold is too cold but it really shouldn't have done that.... Tamron makes cheap lenses. Try and exchange it for at least a Sigma.
Dec 24, 2007 | Tamron 18-250mm F/3.5-6.3 AF Di-II LD...
Sigma APO 50-500mm F4-6.3 EX DG/HSM Lens Logo
146 people viewed this question
Top Sigma Cameras Experts
M_Butkus
Steve
bhargav
Are you a Sigma Camera Expert? Answer questions, earn points and help others
