I have a royal pl 2000 photo laminator. How do I unjam a document. Never exited rear partial showing in front. Full regular size paper.
galadhiren
  • 15 Answers
SOURCE: printing photos
Of course you can use 4x6 photo paper
you have select the paper size from page setup as 4x6
and put the paper in the tray after adjusting the tray size
Posted on Jan 02, 2008
Yazz226
  • 497 Answers
SOURCE: how do I unjam a rear passenger seat belt from a hyndai accent 2000
i strongly recommend you take your vehicle to your vehicle's local dealer and have the belt removed from the door and then inspect the belt for damage. A damaged seat belt might break when you need it most. Seatbelts and safety are the most important thing!
Happy to help
Have a nice day!
tc
Posted on Jun 07, 2008
  • 199 Answers
SOURCE: Laminator
ok we think again
Posted on Jun 22, 2009
  • 6 Answers
SOURCE: Can't Print Invitations
There is a workaround for this problem by tricking the printer.
The paper sensor, on my printer model hp4500 seems to only sense the paper at the beggining of the print job.
What I did to trick the printer to print on odd size paper is slide the paper adjuster to 8.5 and put a regular white sheet in. Then put your odd size paper under it. When you print your document set the number of copies to 2 and print. The printer is going to sense that the paper is correct, and start the job.
Here is the tricky part... once the first 8.5x11 sheet is almost all the way through quickly slide the paper adjuster over to match the size of your odd width paper. The printer should pick up the odd paper and print the second copy. Fool you printa! You should be able to do batches of odd paper size under the first 8.5X11. I hope this helps.
Deny
Posted on Jun 27, 2009
goodgold
  • 389 Answers
SOURCE: how do i unjam the paper in my canon pc 1061
I think, it's trouble for service. Please call them.
Posted on Jun 07, 2010
How do I print color photos on glossy paper with Canon Pixma MP 6
printer supports it. just you have to goto printing preferences or printer properties and set rear tray to accept glossy paper. it will accept size of paper ur using. so give the actual size.
Apr 23, 2009 | Office Equipment & Supplies
I cannot copy and print a document on 8"X14" plain paper. No problem with 8"X11 1/2" plain paper
Scanner: dot2.gif optical resolution: 2400 x 4800 dpi /19,200 x 19,200 dpi interpolated dot2.gif 48 bit color depth
maximum document size: 8 1/2 in x 11/11/16 in dot2.gif Copier: dot2.gif copy speed for text documents: up to 30 copies per minute in black; up to 20 copies per minute color dot2.gif reduction/enlargement: 25/400 percent dot2.gif Fax: dot2.gif color or black and white faxing dot2.gif stores up to 40 numbers in speed dial dot2.gif built in memory for up to 100 incoming fax pages General Features: dot2.gif automatic document feeder holds up to 30 originals for copying, scanning, or faxing multiple documents dot2.gif Ethernet port for connecting multiple users in a computer network dot2.gif 2 picoliter sized ink droplets for fine detail 4 individually replaceable ink tanks dot2.gif ChromaLife 100 inks for long lasting photos dot2.gif Full photolithography Inkjet Nozzle Engineering /FINE 1,600 nozzle print head dot2.gif paper sizes: letter /8 1/2 in x 11 in, legal, credit card /2/ 1/8 in x 3 3/8 in, 4 x 6, 5 x 7 in, envelope, photo stickers dot2.gif high speed USB interface dot2.gif 18 15/16 in W x 9/ 7/16 in H x 18/ 1/4 inD dot2.gif weight: 22.3 lbs. dot2.gif Part Number: 2186B002
you have to select the paper size from the computer while giving printout from computer and apply the changes you make.and while copying the page from the scanner you have to change the printersettings by clicking the menu button in the printer.
Oct 04, 2008 | Office Equipment & Supplies
Is it possible to unjam this shredder. It was allowed to get too full and I started eating it's own shredding . I have pulled all of the paper out that I can - but it still won't go.
If you have cleared all jammed paper out of the unit but its dead and wont run then its likely you have blown the PCB inside...replacement parts you can get from Royal at 1-800-524-0799.
Oct 16, 2010 | Royal 10X Shredder
The page prints to a small version in top left hand corner. everything is set to A4. Have tried all settings Have tried paper feed from back and front. Unable to get it to print a full size A4 page even...
Make sure on the Page Setup tab that the Page Layout says 'Normal-size' and not 'Poster' (poster tries to place four documents on a single printed sheet). If this is not the problem, try uninstalling and reinstalling the printer driver.
Feb 10, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
How do I exit from a zoom?
Not sure if you used the front panel controls of the printer of the HP software to change the settings but this page from HP may help you to correct the issue :
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu04818&cc=us&lc=en&dlc=en&product=57769
Mar 05, 2009 | HP PSC 750 All-In-One InkJet Printer
Can not set custom paper size in HP C7180
I had to seek Help several times, and then work through the steps a few times before I learned the overly complex HP method for setting custom sizes (I never thought I would have anything good to say about Dell printers, but it was MUCH easier to set custom sizes on my old Dell than on this HP C7180).
Anyway, it sounds as though you are nearly there. After you set the size and save the name, you must click OK, then click OK in the Document Properties window. Then close any open windows, like "Document Properties" or "Print Pictures", and start over from "Pictures" or whatever photo browser you are using. Chose an image and click "Print". Under Printer, chose "C7100 series", not "...series fax". Under Paper size chose "More". Your new custom size should now be the last size listed (although, it has shown up as the first size a couple of times, ...go figure). BTW, I am using Windows Vista.
Hope this helps.
Nov 23, 2008 | HP Photosmart C7180 All-In-One InkJet...
Paper Size Error
Hi there check that the printer properties have not been changed.
  • Click Start
  • Select Printers and Faxes
  • Right hand click on printer icon
  • Select Printing preferences
  • Check that the paper size matches that you have got in the tray
  • OK and exit and test
If the above doesn't work try the following
  • Open MS Word
  • Open the document that you are having problems with
  • Click File
  • Select Page Setup
  • Check that Paper Size is correct
  • OK close and test.
This is normally a driver issue as the paper tray on the printer doesn't know what size paper is in it until you tell it from the driver.
Hope this works for you
Thanks J
Dec 27, 2007 | HP DeskJet 5650 InkJet Printer
181 people viewed this question
jasbo
jasbo
