Question about Canon PIXMA iP90 InkJet Printer
My printer won't draw in paper. It starts to and even engages like it wants to draw but even when I help it a little it won't draw in. I transported it in a suitcase full of only soft clothing and cusioning. it worked fine prior to that. I'm thinking it got jarred somehow during travel. Please help!
  • Canon Master
  • 1,679 Answers
Hello there gave it a go this may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping
Regards,
Ron
Posted on Mar 23, 2011
HP deskjet 1056 won't feed paper
I just fixed mine. The paper would feed part way then jam and twist a little off center. When I pulled the paper out there was a crinkle on the bottom edge, left side, about 2 or 3 inches in. I did some looking with the scanner removed a saw a plastic tab like the ones that hold and feed 1 sheet at at time. This tab was located inside a little "box-like" thing on the underside of the printer. I turned the printer over. There are several openings/ holes in the 'box'. You can take a pencil or similar object and slide a flat 'tab' that is inside the 'box'. You will see a small spring in one of the holes. Slide the flat tab toward the spring until it locks in place. My printer now works fine. To me the 'box' mechanism looks suspiciously identical to an analog counter wheel. If it is, then it is counting the pages and then engaging the tab to cause a paper jam so you will buy a new printer. Similar things happen electronically to my HP psc 1210 & my Officejet 5610. They will stop scanning or printing, give "no cartridge" error codes, etc... I unplug them for a few weeks and it's like they are new again. PS, if the printer can't talk to HP it will work longer.
Apr 16, 2013 | HP DeskJet Office Equipment & Supplies
Won't load paper
Clean the paper feed with alcohol and a paper towel by rubbing and rotating the drum. Wait for it to dry completely then it should grab the paper. Also make sure paper is free from dust. Good luck!
Jan 25, 2013 | Kodak EasyShare Photo Printer 500
No paper pickup problem in system printer (HPLaserjet 3050 models)
open back & side covers.. start diagnosys..
chech paper pickup unit trying to picking up the paper?..if yes.. clean/replace pickup roller..
No. check solonoid acting proprly,,
Paper passing little bit?..if yes..check paper sensor flag strucked?
check transfer roller gear properly engaging with the catride? 1.Replace catridge..2. Transfer roller check..
Good luck..
Sep 05, 2011 | HP LaserJet 3055 All-In-One Printer
HP G85 PAPER JAM ERROR ,but still prints from scanner fine
Remove the rear cover...clean the rubber rollers with alcohol
Feb 17, 2009 | HP OfficeJet G85 All-In-One InkJet Printer
PAPER WON"T LOAD
The problem is software rather than mechanical operation. Uninstall the printer driver from the Add/Remove section of the Control Panel. Pull out the USB port and replace it back. This will prompt you pc to install the driver of the newly found hardware. Reinstall the printer driver. Should your printer be observed to have the usual problem, replace both cartridges with a one. "Loading paper" problem feedback is the same prompt as what you get when cartridges are old or refilled with unauthentic ink.
Feb 03, 2009 | Canon PIXMA iP1600 Printer
Paper won't load. and Stops printing before it can start.
Try turning the paper around. Some times the corners of the paper get slightly bent and the paper wont load.If turning the paper around does not work, switch your paper. Hope this helps.
Kyocera KM-3035 - Paper Jam 00 error. Paper removed, still not working.
Check to make sure that their is no paper that is jammed in the paper draw. Also open the main panel where you would change the toner and pull out the little draw underneath the toner, I believe it is marked A2. Make sure that there is no paper there as well. Another place that paper will sometimes hide is in the left panel by the duplex system. Sometimes a little piece of paper gets left behind and this can cause the system to think there is still paper jammed in the machine. If all else fails try restarting the system. If you are still experiencing a problem than I would recommend you call your servicing dealer.
Hopes this helps.
Henry
Jul 20, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
Canon PIXMA iP90 InkJet Printer Logo
41 people viewed this question
old marine
old marine
