Question about John Deere 3010,3020 Tractor Basic Carburetor Repair
John Deere 3020 tractor with power shift: starts and runs well, but move the lever to forward or reverse, and motor looses power and shuts down
  • glenna_swier Mar 23, 2011
    Thank you! It is not a mower but a John Deere 3020 tractor with power shift; thanks again!
mhamlin63
  • 138 Answers
SOURCE: forward/reverse lever not holding in position on
Some come with a tension bushing underneath on linkage. Check that first
Posted on Jun 29, 2009
wilsodfarm
  • 986 Answers
SOURCE: 3020 carburetor ? john deere gas tractor, 3020
those carbs are real simple you will not have any problem
Posted on Jul 29, 2009
wireguy212
  • 1627 Answers
SOURCE: John deer 6400 Shuttle shift will not engauge
You have the old style reverser which has been replaced by one that beeps instead of kicking out.These are a known problem with Deere and that is why you can't buy them anymore.The fact that you can hold it in yourself indicates that the enable solenoid and the forward and reverse solenoid are ok and all safety switches are working.You need to replace the reversrer.
Posted on Feb 05, 2010
  • 420 Answers
SOURCE: john deere 300 garden tractor will not go forward or backwards
Make sure the neutral lever (rod) back by the right rear tire is pushed ALL the way in.
Posted on May 27, 2010
philwalker78
  • 608 Answers
SOURCE: I have a John Deere L120 tractor with a
Hi, your problem is caused by the transmission over heating. Remove the battery and battery carrier and clean all grass and debris from the hydro cooling fins and fan. Hope this is helpful, regards Phil.
Posted on Sep 08, 2011
John Deere 760-A scraper will not move forward but it will back up.
It is almost like a 4620 powershift farm tractor trans. When reverse goes clutch packs are shot. Sorry about that. Be sure the shift linkage is moving full range top to bottom.
Nov 21, 2016 | John Deere Garden
Why wont my john deere d140 move when I ngage the double foot pedal
The drive belt may be broken, or it may have slipped off a pulley.
Aug 03, 2014 | John Deere Garden
How to fix Stuck in reverse Clutch is Fine.?
Have you tried checking the linkage to the hydrostat/transmission? Are you getting full movement of the lever? If not, it might have just come loose and shifted so you only have reverse. If you have full movement of the lever and the hydrostat has the proper amount of fluid it could be fried. It's hard to tell without diagnosing the linkage. I'd suggest blocking the rear wheels off the ground so you don't run over yourself before you go messing with the linkage.
May 14, 2014 | John Deere 22HP VTwin Hydrostatic 42"...
John deere sabre 2354 hv moves slow forward, even slower in reverse
this hydrostat drive tractor is designed to max at 5.5 mph forward, 2.5 in reverse, check linkage at pedal if you dont think your achieving those speeds
Mar 23, 2013 | John Deere 420,1020,2010,2020,2510,2520...
It is a 1993 john deere 6100. there are 3 forwards and 1 reverse on one gear stick- 1, 2 ,3, r and the other is a, b ,c ,d ,e. the 1, 2,3, r gear stick has becoe loose and u cannot select gears 2 and 3. I...
The shifters do run cables to the transmission but you likely only need to remove the panel from the right side that covers the shift rods and then you can tighten the 13mm nut that brings the linkage rods together,the nut is on the shift lever not the range lever,Let me know how you make out and if i am wrong also let me know and i will dig deeper.
Sep 28, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 6420 shutting off
Take apart fuel line around tank and blow out. Might also be something in tank that is getting sucked over the outlet. Clean out fuel tank
Feb 23, 2010 | John Deere 6300,6300l,6400,6400l Tractor...
John deer 6400 Shuttle shift will not engauge . I can here a relay activat in the fuse panel. If I hold the lever up the tractor will move forward and the same for reverse. But the lever will not stay...
Feb 05, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Jul 04, 2009 | John Deere 3010,3020 Tractor Basic...
John Deere 3010,3020 Tractor Basic Carburetor Repair Logo
103 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
